see a message indicating we are on the new server.
Strange dried ooze...
Page 1 of 1 [16 Posts]
Surgeon
PostPosted: Mon Apr 07, 2008 11:34 am    Post subject:  Strange dried ooze...
Subject description: Coming out of my electronics.
Well, I'm new to circuit bending. I've only been fooling around with it for a few days. But today, when i looked at the circuitry in this Yamaha SHS-10 that I've been fooling with, I noticed some strange dried up yellow-brown goo around some of the metal pieces. What is this stuff? Is it battery acid or something? Is this normal? Am I harming the circuitry? How could I properly clean this off?
PostPosted: Mon Apr 07, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome,
do you have a picture?
PostPosted: Mon Apr 07, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you might have harmed the parts and in that case you can compare this to the goo that results from dropping a 13-ton weight on top of someones grandmother. Shocked
Anyways, welcome to electro-music.com
Flickr
PostPosted: Mon Apr 07, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
However, it could be old resin residue or something from the soldering...
Does it smell?
Flickr
Surgeon
PostPosted: Mon Apr 07, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunatley, I don't have a camera so I can't take a picture, and infact I never actually soldered anything yet. The only thing I've done up to this point is take off the casing and explore the circuitry with my test leads.
The odd part is that the goo, which kinda looks like dried honey/wood glue, isn't anywhere near the batteries.
PostPosted: Mon Apr 07, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
In that case I'd go with elektro, old resin Cool
PostPosted: Mon Apr 07, 2008 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I´d go with me too..
Flickr
Surgeon
PostPosted: Mon Apr 07, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
well in that case, i guess i have no choice!
I guess I'll clean the stuff off and then take note if it ever comes back.
Thanks for the help!
PostPosted: Mon Apr 07, 2008 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
What you really should be looking out for are those moments when the magic smoke is trying to escape from the components.
Flickr
RF
Audio files: 28
PostPosted: Fri Apr 18, 2008 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
This brown goo just sounds like glue around the base of electrolytics...
If it ain't broke, why mess with it?
bruce
Inventor
Audio files: 267
PostPosted: Fri Apr 18, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could be electrolytic juice leaking out of an old capacitor. Or it could be dried up electron sweat. Those little e's move at half the speed of light, so they sweat a lot. Apply some strong deodorant and don't turn the knobs so fast anymore. Then again, it could be flux from a flux capacitor, in which case you can use it to build a very small time machine.
otherunicorn
PostPosted: Fri Jun 20, 2008 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
A rusty yelow color in amounts substantial enough to stick electros to the circuit board is in all likely glue. They use it to stop heavier components wobbling, thus breacking their connections to the PCB.
Two things should be noted about it though.
1) it is corrosive, and sometimes will cause circuit failure (yes, even when dry)
2) it is known by the rather amusing name "gorilla snot".
http://www.cgs.synth.net/
badstatic
PostPosted: Wed Sep 03, 2008 2:06 pm    Post subject:   Reply with quote  Mark this post and the followings unread
It's called 'Ectoplasm' and it occurs in the presence of ghosts/ghools/spirits.
The best thing you can do is to get a white haired catholic priest to perform an exorcism on the machine. Just be sure to disconnect the power supply before he drenches the machine in holy water.
PostPosted: Wed Sep 03, 2008 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
imaguitargod
PostPosted: Fri Sep 05, 2008 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
"Who ya gunna call?"
Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page)
badstatic
PostPosted: Sat Feb 21, 2009 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you seen a rather amazing film called PI ?
The main character has a custom computer system, which briefly becomes alive and self aware (skynet style) ..... It dies shortly after, but not before producing some strange sticky gunk, and a 216 digit number.
You may have just stumbled upon on the 'true name of god'.
