Ian Fritz Sawtooth VCO
Page 1 of 1 [4 Posts]
PostPosted: Mon Sep 01, 2008 4:30 am    Post subject: Ian Fritz Sawtooth VCO
Subject description: just a few short questions...
hello ian, hello all,
looking at your schematic of the sawtooth VCO i see a 237K resistor (R6) at the summing node of the control voltages going to ground.
what is this resistor for? when i use a 1k termistor, will i have to lower this value as well?
you use a LM329 as voltage reference. if i wanted to use a say 5V reference, what should be changed? the 33K resistor? or said things different: why 6.9V? how has this value been calculated?
frijitz
Audio files: 54
PostPosted: Mon Sep 01, 2008 12:36 pm    Post subject: Re: Ian Fritz Sawtooth VCO
Subject description: just two short questions...
Ummm ... actually it's going to the -6.9 V supply. It sets the overall range.
Could you clarify that? You are using 1 k for the feedback resistor and 50 k for the 1 V/Oct input? If so, then you also need to halve all the other input resistors (R2, 4, 6, 7, 9).
You need to scale all the resistors that are supplying current by a factor of 5/6.9. These are R2, 6, 15. You need to make R21,2 provide 4 V, e.g., R21 = 22k, R22 = 100k.
The LM329 is inexpensive and used to be available in a premium grade (but no longer). I now use 5 V subregulators.
I'm actually right now working on upgrading this design again. Several people have indicated interest in having a barebones saw vco (no waveshapers) for stacking, for polysynths, or for using with external waveshapers. So boards may be made available if there is enough interest.
Ian
PostPosted: Mon Sep 01, 2008 1:27 pm    Post subject: Re: Ian Fritz Sawtooth VCO
frijitz wrote:
Ummm ... actually it's going to the -6.9 V supply. It sets the overall range.?
ahh, i didn't se that. mixed the symbols.
Could you clarify that? You are using 1 k for the feedback resistor and 50 k for the 1 V/Oct input? If so, then you also need to halve all the other input resistors (R2, 4, 6, 7, 9).?
yep, 1k in the feedback path and okeydokey
You need to scale all the resistors that are supplying current by a factor of 5/6.9. These are R2, 6, 15. You need to make R21,2 provide 4 V, e.g., R21 = 22k, R22 = 100k.?
okay, i will take a look at the schematic again.
The LM329 is inexpensive and used to be available in a premium grade (but no longer). I now use 5 V subregulators.?
i had a hard time sourcing the LM329/129 but eventually found it (minimum order of 10 pieces, so i could build some VCOs)
Ian
huh, i am still planning my keyboard synth. i still have this EFM wildcat PCB but finally decided not to use it Wink
so i started planning a synth built it from various circuits. i decided to use you VCO. furthermore i had the feeling that i am in need of some reliable, top notch VCOs for my modular, VCOs i can rely on. nevertheless i will etch my own PCBs, though. i want to use PCB mounted controls as much as possible.
however thank you very much for your patience and the clear answers, ian. very appreciated.
PostPosted: Thu Sep 04, 2008 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
one more question.
if i wanted to add a sync input, where should i apply the signal? at the negative input of the comparator (U1 pin 5) as seen on the ENS-76?
