funkyfarm
Posted: Sat Jul 26, 2008 7:16 pm Post subject:
MoogerFooger MF-102 switch weirdness Subject description: "my big orange cat broke my ringmod." |
my moog ringmodulator felt down on the floor (because on my stunting cat...).
It made a short pleasant sound.
But now the main switch is "glitchy" (flip-flop between bypass and active...) ; some bounce occurs.
So I've bought another switch at Smallbear
Momentary SPST "Soft-Touch"
Rugged enough to be stomped. Normally Open, short, light stroke, with positive action.
It did not change anything.
Press Bypass, it bypasses for half a second and return in active mode.
on the third or forth try , it operates right...
So I look at the pcb :
This Bypass switch briefly connects +5v to a pin of a CD40xx.
So i've swapped it for a new one with no success.
I've also changed both 100nF capacitor lying around around this 5volts triggering (not decouplling ones)...
The whole pcb (amp, ringmod, carrier vco, mixer, vc lfo...) is full of LM13700, that's sure, but i can't figure out which IC could be wrong for bypass...for sure a semiconductor is involved here ?
this pedal sound fantastic, really.
devilish animal... |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Mon Jul 28, 2008 9:38 am Post subject:
Re: MoogerFooger MF-102 switch weirdness Subject description: "my big orange cat broke my ringmod." |
funkyfarm wrote: |
...It made a short pleasant sound....
It wasn't a scream of death, anyway...
I don't know anything about this pedal...but I'd be looking for a broken/cracked solder joint.
Hope you find it - good luck
bruce |
doctorvague
Posted: Thu Jul 31, 2008 8:16 am Post subject:
RF wrote: | funkyfarm wrote: |
bruce |
Excellent advice. The last time I repaired something similar it took a REALLY strong magnifying glass to see the broken PC traces. I would never have been able see it with the naked eye.
Best of luck
Phil _________________ doctorvague's youtube channel |
funkyfarm
Posted: Sun Aug 03, 2008 5:41 pm Post subject:
thank you very much for reading.
i'll get a magnifying glass and check. |
funkyfarm
Posted: Sun Sep 14, 2008 6:10 pm Post subject:
argh...don't find anything...
thank you.
(i was about to sell this wonderful module because of money ; i'll keep it, and always in ACTIVE mode ! ) |
