 Forum index » News... » Gear News
MidiOverLAN !!!!!
Page 1 of 1 [9 Posts]
PostPosted: Mon Aug 02, 2004 3:35 am    Post subject: MidiOverLAN !!!!! Reply with quote  Mark this post and the followings unread
MusicLab has been working hard to make their MIDIoverLAN communicate not only between several MIDI apps on a single machine, but between those on several computers, which finally led to creating a new enhanced version of MIDIoverLAN. It's now called MIDIoverLAN CP, a cross-platform solution for communication between MIDI applications both local and over network.
The new solution can now communicate between PC and Mac computers on a network.
MusicLab MIDIoverLAN CP features:
Transformation of a MIDI device into multi-client one with just a single mouse click
Convenient control panel
The most MIDI time accuracy possible
Mac/PC compatible
System requirements:
Minimum:
PC: Windows XP SP1, Pentium III 500 MHz, 128 MB RAM
Mac: OSX 10.2.4, G4 400 Mhz, 128 MB RAM
Suggested:
PC: Windows XP SP1, Pentium 4 2 GHz, 512 MB RAM
Mac: OSX 10.3, G4 800 Mhz, 512 MB RAM
MIDIoverLAN CP for up to 2 computers costs $129. MIDIoverLAN CP in a bundle for up to 4 computers costs $199, and an 8-computer bundle is available for $299.
http://www.musiclab.com.
Audio files: 231
PostPosted: Mon Aug 02, 2004 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure this is very good software. If anyone is interested in jamming with other people using MIDI over the internet, I think TJT has written some software to do this. Maybe we could drag him out of the woodwork, but we should probably start another tread...
DrJustice
PostPosted: Mon Sep 13, 2004 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
On a slightly more general side of the matter:
I've just been trying to find out about standards efforts, manufacturers support and such for "MIDI over LAN". I found out about IEEE P1639 (http://www.plus24.com/ieeep1639/), but a quick search landed me no documents on the hard facts. Mostly some news flashes from 2003, a few blind alleys and dead links. There's a few other protocols; info here: http://www.openmuse.org/transport/mip_oview.html. Then there's a few products which seem to use proprietary protocols.
In the end I'm a wee bit confused. Does anybody know what the general state of "MIDI over LAN" is and where it is going? It would be good to know where to start if one wanted to support this (in a product), and indeed if it is even worth considering.
A concerted effort to bring MIDI over LAN (ethernet) would be Good IMO. Fast, cheap and simple.
Any info or views on this subject would be greatly appreciated.
DJ
play
PostPosted: Mon Sep 13, 2004 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've had some experience with OSC (open sound control) which is built in to reaktor and I think also traktor. I've synced clocks successfully with relatively low latency on a LAN. Apparently it is possible also to do this with MAX:
http://www.randominterface.com/forum/forum_posts.asp?TID=63&PN=1&TPN=1
Here's some links to various implementations of OSC:
http://www.cnmat.berkeley.edu/OpenSoundControl/
There is even a php OSC class but it can only send messages so it's not a full implementation.
I'll have to check this program out because it sounds a lot more flexible than having to use only programs with built-in OSC support.
DrJustice
PostPosted: Mon Sep 13, 2004 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks play!
OSC looks very interesting. I like the idea of being able to send a float to //somehost.net/studioX/synthY/partN/osc1/fm_amount Smile Also nice that it already is eastblished in some solid projects. Got the docs and sdk - now I got some reading to do.
DJ
jksuperstar
G2 patch files: 18
PostPosted: Mon Sep 13, 2004 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
There used to be a few more programs available on the IEEE Proposed website. The idea is not necessarily to push MIDI of WAN, like people jamming over the NET, but to connect multiple computers, and eventually other gear, using readily available Ethernet. Scale to Gigabit ethernet, and your talking FAST response.
The only problem, is that they have to shoe horn it into TCP/IP, which is a free for all when it comes to bandwidth allocation & synchronizing things to time. For running MIDI, it's not too bad, as long as your running a small number of nodes, or have everything on switches. Gigabit solves much of the problems, only becuase it's faster. Had they been able to use just UDP, things would have been alot more efficient, but then it wouldn't run nicely over your already used computer network, with plug & play networking. Definitely not driven by studio mentality, but by home user mentality.
I do love the idea...MIDI is just *way* to outdated to continue much longer.
play
PostPosted: Mon Sep 13, 2004 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep.
tcp/ip and midi are both pretty primitive but if al you need is a clock sync then you're set. UDP wouldn't work for that anyway.
tjt
PostPosted: Mon Sep 13, 2004 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
If anyone is interested in jamming with other people using MIDI over the internet, I think TJT has written some software to do this. Maybe we could drag him out of the woodwork...
Sure, keykit has a tool called "Konnect" which lets you send MIDI
back and forth between two (actually any number of) computers.
It doesn't attempt to work in absolute realtime (since the tool
was intended to work over the internet), but it resynchronizes the
transmitted MIDI to match the local clock, on N-beat boundaries.
What this means is that if you've got a 4-beat drum pattern going,
and both sides (call them A and B) have musicians that are
improvising to it, side A will hear what side B played in response
to what side A played 8 beats ago. I developed this back in 1995,
and demonstrated it over a dial-up (28.8) connection at the time.
Like many of the tools in keykit, it's not well documented.
It relies on TCP/IP support in keykit, which only works on the
Linux and Windows versions of keykit. I used it in a one-way mode
to play a remote concert from San Jose to St Louis, a few years ago.
The last time I ran it was a year or two ago, in a mode where a Linux
server served as a central server, and a friend and I connected to
it and jammed through it - three copies of keykit were running and
communicating, 1 on Linux and 2 on Windows.
ocp
Audio files: 9
PostPosted: Sat Oct 23, 2004 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
For those of you using MacOSX, there's iMIDI: http://www.grantedsw.com/imidi/
Still under development though, but it's free!
Wink
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
