Filter Help
Page 1 of 1 [6 Posts]
Silas
PostPosted: Tue Sep 23, 2008 2:50 pm    Post subject:  Filter Help
Subject description: What filter i need ?
Hey, I need to put a filter on a mixer so I have the mid and high on one output and the bass in its own.. Am i looking for a Passband filter or am I way off ?
To clearify, I need the filter to split the mid and high range from the bass..
Help me out please, THANKS..
bubblechamber
PostPosted: Tue Sep 23, 2008 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
it seems like you could do this with a high pass, for the mids and highs. and a low pass for the bass.this would give you 2 output.
3 band passes would work too, and that might give you more control in the long run. but would require 3 outputs.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
urbanscallywag
PostPosted: Tue Sep 23, 2008 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
A state-variable filter would be cool since it has simultaneous low pass and high pass outputs (with a single cutoff frequency).
Silas
PostPosted: Wed Sep 24, 2008 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, both suggestions sounds just fine... Problem is I've spent the last hour looking at filters and I don't understand much.. Certanly none of the calculations.. whoa.. Really I guess i just wan't to be spoon fed, can you link me to somewhere theres schematics that also tells me what the values of the components ?
Looking at the state-variable filter, I'm guessing it's no problem having the mid and high on one output and the low on it's own?
Also, I have no internet at my place so I have to commute 30 min, to get to some internet, so I would really apriciate if you could help me out in one go..
THANK YOU VERY MUCH!
Scott Stites
Audio files: 96
PostPosted: Wed Sep 24, 2008 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Buchla 194 sounds like a good start for what you're shooting for.
Marjan Urekar's redraw is here:
http://members.tripod.com/urekarm/synth/download.html
An SDIY thread about it is here:
http://dropmix.xs4all.nl/pipermail/synth-diy/2008-April/006679.html
It may fit the bill. I've got one on perf, pretty cool.
Cheerios,
Scott
My Site
Dave Kendall
PostPosted: Wed Sep 24, 2008 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a thought - is it for a DJ-type use, or for a P.A. crossover use?
If it's for DJ use, you might want to look at a type of filter, or pair of filters (lowpass and highpass), that can have the frequency swept via a pot or control voltage.
To filter out all but the "real" bass, you will often need a relatively low cutoff frequency, around 100Hz or lower, and need to tweak the cutoff frequency according to the track you're playing through it. The same holds for the mid-high frequencies.
The steepness of roll-off (sharpness at the cutoff point) is probably an issue too. For example, a 6dB/octave filter will sound very different to a 24 dB filter in this application....
In the end, just use your ears to decide what filter type to go for - if it sounds good, it *is* good. Smile
just my .02 pence worth....
