Guitiar Negative Impedance Converter
Page 1 of 1 [5 Posts]
Inventor
Audio files: 267
PostPosted: Sat Sep 27, 2008 8:42 am    Post subject: Guitiar Negative Impedance Converter
Subject description: Just an idea
Hi, I came up with an idea for a guitar pedal box. It is very simple, you build a negative impedance converter and in place of one of the resistors you put a duplicate of your guitar's pickup. In my paper calculations, the negative impedance can be made to cancel out the source impedance of your pickup, thereby leaving a flat pickup response. What do you think of this idea? Will it work? Has it been done before? Stoopid or kewl?
PostPosted: Sat Sep 27, 2008 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
What's a negative impedance converter?
PostPosted: Sat Sep 27, 2008 10:21 am    Post subject: Re: Guitiar Negative Impedance Converter
Would it not oscillate easily?
PostPosted: Sat Sep 27, 2008 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Some info on it : http://en.wikipedia.org/wiki/Negative_resistance - impedance would be generalized resistance, adding an "imaginary part" to it - making the numbers complex.
Inventor
Audio files: 267
PostPosted: Sat Sep 27, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Aye, this be the beastie:
http://en.wikipedia.org/wiki/Negative_impedance_converter
You can replace either R1 or R3 with the pickup. In my calculations I put the pickup in place of R3, though that might not be the correct place. R1 might be better.
It might be prone to oscillations, yes. That could be it's Achilles heel. It might be possible to dampen those oscillations. Perhaps the tone control knob would dampen them.
The beauty of using a pickup to cancel a pickup's source impedance is that all impedance characteristics, including the distributed nature of the impedance, could perhaps be accounted for automatically. Or not, I'm not certain but that's my guess.
