Tube Stereo Panner
Page 1 of 1 [8 Posts]
frequencycentral
PostPosted: Wed Oct 01, 2008 12:52 pm    Post subject: Tube Stereo Panner Reply with quote  Mark this post and the followings unread
I just developed this on the breadboard tonight. I like it a lot. It needs developing in terms of adding a depth control - I'm thinking about how to implement that at the moment. I designed it for guitar really - easily adapted for any CV input though - just replace the phase shift oscillator with a CV input.
Soundclip: http://www.aronnelson.com/DIYFiles/up/Tube_Panner.mp3
http://www.frequencycentral.co.uk/
andrewF
PostPosted: Wed Oct 01, 2008 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good stuff, indeed it would be easy to convert to a CV input
happy to see more low voltage tube projects.
anyone care to do an oscillator? Very Happy
for a complete low voltage tube synth...
andrewF
PostPosted: Thu Oct 02, 2008 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
spoke too soon - this is the mean sucker's big brother
http://experimentalistsanonymous.com/board/post-10077.html&sid=218f12277ff3a352208b314012cba590
(thanks for the link Fernando)
frequencycentral
PostPosted: Thu Oct 02, 2008 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's mine too - I'm having a crazy time with low voltage tubes at the moment.
Certainly not stable oscilators though, but good for making a racket! I will develop it further at some stage but I can't see it being 1v/oct.......
Did you check the soundclip: http://www.aronnelson.com/DIYFiles/up/Crushed_Glass_Sample.mp3
andrewF
PostPosted: Thu Oct 02, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure did, thats why I called it the mean sucker's big brother Smile
you get some great sounds out of that cct!
Luka
PostPosted: Thu Oct 02, 2008 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
mad, i have some spare 5672s
might have to make a whole tube machine
problemchild
melbourne australia
frequencycentral
PostPosted: Thu Oct 02, 2008 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think if used as a modular panner with CV input instead of the LFO I would consider a unity gain buffer at the CV input.
Maybe the 10uf caps could be lowered too? They do slew a little - but also stop LFO ticking, so it's a trade off.
Maximum CV input is 6 volts - any higher and it starts to have the reverse effect.
frequencycentral
PostPosted: Fri Oct 03, 2008 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a clean soundclip: http://www.aronnelson.com/DIYFiles/up/Rhodes_Panner.mp3
Signal path: Rhodes Stage Piano 73 MK1 > Tube Stereo Panner > Soundcard > Wavelab
I've noticed some subsonic pumping -inaudible, but it registers in Wavelab - and I can see my speaker cones moving even when I'm not playing - so I've changed the two output caps from 1uf to 0.01.
