today> Various Artists NYE concert
My old AS synth project...
Page 1 of 1 [7 Posts]
marinedalek
PostPosted: Tue Sep 30, 2008 6:41 pm    Post subject: My old AS synth project... Reply with quote  Mark this post and the followings unread
Well, hello there! My first post here after lurking for several weeks... thought I'd share the synth that I built for my AS Design & Technology project.
It's a triangle-core synth based on a simple op-amp integrator design. Not having time for lots of prototyping I took the rather odd route of making it resistance-controlled rather than voltage-controlled. Each keypress on the copper touch-sensitive keyboard triggers a reed relay that switches in the tuning pot corresponding to that note. There's also a variable rate and length "sequencer" which plays each note of the keyboard in turn - by entering non-standard tunings various riffs can be programmed in.
As far as sound shaping goes, there's a PWM section with its own LFO driven by the triangle core, as well as pure triangle and square waves, with divided -1oct and -2oct square waves also included. Filtering is very basic, just two 6db/oct buffered passive lowpass/highpass combinations, which can be chained in series for stronger filtering.
Initially there were going to be two additional oscillators with non-keyboard-controlled tuning for fun swoopy sound effects, which is why I included 2 filter sections (one for osc1, the second for the other 2 oscillators). The first of these was to be a saw/pulse oscillator, and the second a sine/square oscillator - however time constraints meant these were never built Sad .
Here's a flickr set with images of the project taken on my camera phone a few months ago.
http://www.flickr.com/photos/marinedalek/sets/72157607621408769/
During construction a fault developed which means the output is extremely distorted (~infinite gain) with a lovely DC offset just to make it even more unpalatable. I'm hoping to fix this some time when I get some equipment set up.
RF
Audio files: 28
PostPosted: Wed Oct 01, 2008 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey nice job - Congrats!
PostPosted: Wed Oct 01, 2008 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice, indeed.
what circuits did you use for this cute and sweet little handheld touchkeyboard? why did you etch the keys not as filled planes?
marinedalek
PostPosted: Wed Oct 01, 2008 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
To detect keypresses I used a simple potential divider circuit based around the 4071 OR chip. Each touchpad consists of a copper "fork" which is connected to the touch circuit, and a surrounding area of copper connected to the positive voltage rail. Touching a pad pulls the voltage of the fork up and activates the OR gate, giving a clean digital gate signal.
I didn't do solid pads, because the keyboard relies on detecting conductance, rather than detecting induced EMF in someone's finger.
PostPosted: Wed Oct 01, 2008 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i see. thanks.
oh, and it's realy cute, the keyboard.
Mubo
PostPosted: Wed Oct 01, 2008 1:17 pm    Post subject:  sound clips!
Subject description: sound clips!
we want sound clips!
marinedalek
PostPosted: Wed Oct 01, 2008 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
The synth's currently residing at my grandparents' house due to lack of space here, so sadly there are no samples at the moment Sad
