today> Twyndyllyngs Chez Mosc
LM324 vs TL074?
Page 1 of 1 [12 Posts]
andrewF
PostPosted: Thu Sep 04, 2008 4:27 am    Post subject: LM324 vs TL074? Reply with quote  Mark this post and the followings unread
Finally finished my stash of 100 of so TL074s pulled from an old mixer.
but still have a big tube of LM324, can I use these on the analogue board in place of the TL074s?
Or is the jfet difference relevant?
Scott Stites
Audio files: 96
PostPosted: Thu Sep 04, 2008 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
It will probably work - I've never tried it is all. I had a stash of TL074s when I was working on the Klee, so the part pretty much chose itself.
Give it a whirl - I'd be interested to know if it works or not.
My Site
andrewF
PostPosted: Thu Sep 04, 2008 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers Scott - will let you know
Peake
PostPosted: Thu Sep 11, 2008 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tube of 25 quantity TL074CN DIP, $5.95. .238 each. And you'll find many other neat things to get to the minimum order, such as bunches of mylar caps:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16266
andrewF
PostPosted: Thu Oct 09, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
LM324 works just fine
and I have two Klees
 Filesize:  75.76 KB
 Viewed:  1138 Time(s)
zthee
PostPosted: Fri Oct 10, 2008 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you please post a close up on that panel? Very Happy
andrewF
PostPosted: Fri Oct 10, 2008 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
some pix here
http://www.sdiy.org/pinky/emsyn/emsyn.html
it used to be a mixer
zthee
PostPosted: Fri Oct 10, 2008 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
It's bizarre! I love it!
Scott Stites
Audio files: 96
PostPosted: Fri Oct 17, 2008 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for letting me know about the 324s - that's good info to have.
Bitchin' Klees Cool
My Site
andrewF
PostPosted: Fri Oct 17, 2008 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
and many Thanks to you for all your work on developing this project!!
i've yet to mate my two Klees, am hatching a plan to have them penetrating each others Random inputs Shocked
Paradigm X
PostPosted: Sat May 19, 2012 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
some pix here
hmm... ive got a broken mixer... wonder how easy it would be to use the sliders and case?
PostPosted: Sat May 19, 2012 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make sure you pump some Barry White into one of the references to get them in the mood! Laughing
