today> Twyndyllyngs Chez Mosc
No need to emulate a 303 & New "Love, Haagen" Set mp3
Page 2 of 3 [54 Posts]
cappy2112
PostPosted: Mon Sep 29, 2008 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
and now the x0xb0x assembly is 20% done, with some amazing work from Andrew Martens (on livepa.org). Now we have all the parts sorted, and sorted by module in zip lok bags, and the Power module, and 1/2 of the Osc module done. The x0x came alive with a buzz and we could change it's pitch ... coool ....
Now the only problem I could have with the Kit is the Kat. or Kit Kat. If the Kat eats any rare piece, the Kit and the Kat are in trouble.
Shoo... stay away from the big chips boy, they are not treats ... well, actually, they are... but for the ears ...
/Dasz
It looks like your k@t knows how to use the autofocus. That second picture is krystal-klear Wink
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Oct 01, 2008 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
and we're almost halfway done. i have the power, vco, vcf, and env module assembled and tested ...
iPassenger
G2 patch files: 78
PostPosted: Fri Oct 03, 2008 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Dasz,
I bet yr itching to have it finished and start squeeking it?
Slightly OT: I got quite somthing similar to a driven TB sound by accident using a couple of DIY Saw's, one sync the other but keeping both in the mix and then using envelope to control the pitch of sync'd osc. Certainly not a traditonal approach to making a 303 sound but it seemed to certainly have a 303-ish quality.
I'm pretty sure I saved it, I'll dig it out if anyone is interested?
BobTheDog
PostPosted: Fri Oct 03, 2008 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Still on the list, looks like I am not in the latest batch. Crying or Very sad
iPassenger
G2 patch files: 78
PostPosted: Fri Oct 03, 2008 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Poor old Bob. Sad
I feel for you dude. If I had my name down the wait would be murder.. slow painful murder...
iP (Ross)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Oct 03, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Ross,
my x0xb0x played it's first notes through the complete signal path (VCO-VCF-VCA + Env, I/O Midi and audio) ... big grin ... this sunday we're putting in the sequencer, LEDs, etc and the CPU, etc ... we're over 60% done and it's taken about 11 hours so far.
aaaaand .... now I have a recording of my new Love Haagen set, but it is 30MB and I cannot upload it here at e-m due to the attachment file size limit. Can you recommend a good place to upload it so others can download it without having to sign up? I don't want to use myspace ...
Re Bob's spot on the list ... as you know, lady ada mentioned that they sourced chips for 500 more units! and that the tags will be laser etched ...
http://forums.ladyada.net/topic-7109-0-0.html
so have faith and no expectations ... that did it for me ... (Heck, I have someone who is knowledgeable soldering it for me, I did not expect that either)
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Sun Oct 05, 2008 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know of any host Dasz that will hold a file for an indefinite length of time for you, without signing up for an account (although most a free), like say fileden or whatever.
iP (Ross)
mother misty
G2 patch files: 130
PostPosted: Sun Oct 05, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dasz,
maybe you can try MegaUpload, YouSendIt or RapidShare?
misty.
http://www.myspace.com/mariodemeyer
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 06, 2008 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks mother misty... I'll look into that.
Yay!!!!! and here is my new x0xb0x #853 alive and well after 18 hours of assembly work with Andrew Martens. Acid and squeltchy ....
Tuning is still a bit off, I can't get MIDI in to work (but midi out works and plays and slaves my g2), and we have not put in the mods yet (res mod, vco-out/vcf-in).
Demos of the combination of x0x and g2 at this point is attached to this email. it is a simple fx patch with a kick drum and the x0x is going into the g2, and can be crossfaded between dry and od (and it is running through OD module and shaper and then some eq for color) and a delay (well, of course).
when the mods are done. i intend to use x0xb0x (vco out and cvf in mod) in the following way -- the x0x vco itself to use for pitch tracking control in the g2 which will, ahem add a few more oscs and other things before going into the vcf, and then back in the g2 for more flourish) ...
i suppose this is a good way to use a g2 with analog synths as the pitch of the analog synth may be slightly drifting and this should be picked up by the g2 pitch tracker of course ... hmmm ...
more to come... Smile Smile Smile Smile
/Dasz
ps.: Still grinning ....
 Filesize:  98.61 KB
 Viewed:  332 Time(s)
x0xb0x853_fx_dz.mp3
 Filename:  x0xb0x853_fx_dz.mp3
 Filesize:  5.61 MB
 Downloaded:  1414 Time(s)
BobTheDog
PostPosted: Mon Oct 06, 2008 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounding good to me already!
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 06, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got more stuff in the g2 now and the x0x is finally slaving to my g2 (it was pretty easy to figure out). even without the mods, DAMN!
G2 overdrive ideas -- The G2 od (with eq's) and shapers and comb filters are fed by my xoxboy (the name for x0xb0x #853) for total techno insanity ... it just can't sound bad .... DAMN!
griiiiiiiiinnnnnnnn ....
so, uhm, to keep this discussion on topic, i have not been able to get my effects to sound so smooth as when they are driven with the xoxboy (when I run the audio sources internally)
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Oct 07, 2008 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just recorded some takes of A/B comparison (x0xb0x and a g2 303-like patch crossfading into one set of g2 od / comb / eq / sat etc)
http://www.electro-music.com/forum/post-209245.html#209245
Enjoy.
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Tue Oct 07, 2008 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahh 303 goodness.. great sounds on this and in the link especially.
iP (Ross)
mother misty
G2 patch files: 130
PostPosted: Wed Oct 08, 2008 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or you can try SoundCloud
(it''s going public in 1 day!)
http://soundcloud.com/
They have a damn good player and people are able to listen/download.
misty.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Oct 08, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks mother misty!
That one looks the nicest ...
btw, now I am running a patch (3 voice poly for more phat) which plays the x0xb0x from the G2 (midi notes, and then the x0x is fed back into the G2 which then processes it all and adds another filter ...
all I can say is whoa.... the analog osc and filters add so much more presence...
just as with my waldorf xt, the x0xb0x is a good fit for the g2 ...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Oct 10, 2008 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
aaand last night the x0x was modded and now has boosted resonance, a power switch, and vco out vcf in mod (with a switch to engage or disengage the curcuit for on-the-fly switching between the internal osc and external input for live situations)
audio demos of this combination with the g2 integrated between the osc and the filter, will follow
 Filesize:  95.09 KB
 Viewed:  187 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Oct 10, 2008 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished connectecting the vcf out and vco in cables and created a test patch. The layout is as follows
x0x-vco-out
-> G2 in4 (with pitch tracking, and more oscs, and a few more fx) then out4
-> x0x-vcf-in-vca-mix-out
-> G2 in1
I turn the effect on and off and I add and remove oscs and fx on the oscs before the filter in this recording.
I think this little monster adds a lot of warmth to the g2 sound. I have a lot to learn, but I think in time and with more work, it can sounds like a hell of a decent 1+ (as many as you need) osc 18db synth Smile, with a filter than can be shaped within a G2 to add more character) Smile
and it does have a MIDI play mode which means it can be played by a g2 synth and it's modules)Smile
The resonance boost is very nice and sharp (and turned on in the mp3 when you hear the percussive sound with heavy Q)
Joy! The x0x is a great deal if you can score one for your G2 ...
/Dasz
 Filesize:  251.64 KB
 Viewed:  183 Time(s)
x0x-vco_G2_x0x-vcf-vca_G2 _DZ.mp3
 Filename:  x0x-vco_G2_x0x-vcf-vca_G2 _DZ.mp3
 Filesize:  6.24 MB
 Downloaded:  1248 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Oct 10, 2008 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
and here is the new "Love, Haagen" set!
http://soundcloud.com/dasz/love-haagen-performance-dasz-shaw-ca
Thanks mother misty Smile
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Oct 16, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
i must say I feel drained ... too much xoxboxing ... phew ...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 20, 2008 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
One thing I noticed while passing the x0xb0x through the G2, is that the x0xb0x loses some of the meat/presence and sounds a bit thinner than when it is hooked up to my mackie mixer directly. no big surprise, i guess due to the g2 dac's ...
I did try this while running the vco out vcf mod through the g2, and it sounded fat while it's vca out was connected directly to the mackie...
now I'm thinking I'll use my fx sends (pre-fader) and run the x0x on it's own dedicated channel. oh well...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Oct 25, 2008 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
now the x0xb0x sounds cleaner (running through the mackie) and can be used without running through a left g2 exp (not the right g2 exp which acts as master this and master that)
... bliss ... transistor bliss ...
joy! yeah!
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 27, 2008 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
and now for some results of my experiments now back in the G2 land.
http://www.electro-music.com/forum/post-212337.html#212337
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Jan 08, 2009 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am working on the new template for sets "3, 4, 5 ...", I have the x0b0x doing really cool stuff, but then a big part of this is the G2 as a sequenced oscillator for the xoxbox. and it sounds bad ass. but my sound card is not co-operating. will post result when I get it running.
Jason
PostPosted: Thu Jan 08, 2009 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
pretty interesting
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Jan 08, 2009 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
the real idea for a good 303 osc is use a shape osc A on the 3rd wave (curved saw), then connected 2 saturate modules in series and set their curve to 4 and knob to max (for both in the chain).
this is close to the x0x osc. if you use the wave shape knob to morph the shape osc A wave to a sine, it will sound like a sweeping a saw to a square due to the extra amps ...
very close to the x0xb0x osc sound ... but meatier
