waz
Posted: Mon Oct 20, 2008 10:22 am Post subject:
help: using sequencers with drum pads/triggers Subject description: how can you 'move on' a sequencer with a trigger connected to input 1? |
i'm a drummer and new to NORDing, i have a G2 engine.
i have a couple of drum pads and a full set of kit triggers and i want to control my G2 (via the sequencer modules) without using a drum brain (that turns the pulses into MIDI data. I recently saw a drummer (andre duracell) doing this with the same equipment.
I've tried doing what seems 'logical' (i.e. input - logic pulse - sequence - osc - output) but when i hit the pad it jumps three or four sequencer steps or more depending on how hard i whack the drum pad or drum with a trigger attached.
does this make sense to anyone?
can anyone help me?
thankyou
Waz |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Mon Oct 20, 2008 12:06 pm Post subject:
You could try going Input>Env Follower>Compare to Level (set high)>Seq clk input.
I've never really tried this but the the envelope follower should smooth the signal down in to a contour rather than a full audio waveform.  _________________ iP (Ross)
Joined: Apr 03, 2004 Posts: 24670 Location: The Netherlands, Enschede
Re: help: using sequencers with drum pads/triggers Subject description: how can you 'move on' a sequencer with a trigger connected to input 1? |
| waz wrote: | | (andre duracell) |
Maybe try to PM or mail him : http://electro-music.com/forum/profile.php?mode=viewprofile&u=707 _________________ Jan
waz
Posted: Mon Oct 20, 2008 3:32 pm Post subject:
thankyou very much that worked with a level amp too.
thanks again guys
waz |
waz
Posted: Tue Oct 21, 2008 4:20 am Post subject:
it totaly works but every time i press a key on the virtualy keyboard it changes the osc to that pitch (thus changing all the notes my sequencer plays, they are the correct intervals but not the right notes)
should i just not use the virtual keyboard or is there a default note i can press?
can't find any help in the manual... sorry!
cheers
waz _________________ www.myspace.com/superadventuremusic
Super Adventure Club - Chalk Horror! OUT NOW!
available from online store via myspace |
iPassenger
G2 patch files: 78
Posted: Tue Oct 21, 2008 7:38 am Post subject:
Well there are two options.
1. Change the OSC's to KBT to off. This wil set the OSC to the default pitch or centre pitch (which is E4). Now as the sequencer sends notes to it, they will add or subtract from this centre value and thus sound the notes/keys you have programmed.
2. Hit E4 on the Virtual Keyboard and thus achieve the same effect.
Option 2 gives you the freedom to change the key/root/centre note of the piece if you need to, Option 1 makes sure it sounds the same every time u load it up.
If you do anything clever with yr new drum synth, get it posted on here.
R. _________________ iP (Ross)
waz
Posted: Wed Oct 22, 2008 4:41 am Post subject:
thanks again, its making more and more sense now!
my band (Super Adventure Club) are working on having synth sounds that we all control (drummer, bassist and guitarist) without using MIDI, we already use a G2 that is tracked by the guitar and controled by him with an expression pedal, so i'll post some patches up if we succeed!
thank you so much for your help, i don't doubt i'll need more at some point though,
Waz _________________ www.myspace.com/superadventuremusic
