today> Twyndyllyngs Chez Mosc
PnP HELP!!!
Page 1 of 1 [14 Posts]
crazeydazey
PostPosted: Thu Nov 06, 2008 12:56 am    Post subject: PnP HELP!!! Reply with quote  Mark this post and the followings unread
Hi.
I did my first attempt at Ironing a PnP onto a PCB yesterday and as you can see I wasn't very successfull..
can anyone tell me where I went wrong.
I'm not too sure that I had the iron set on the right setting for a start (the instructions I followed said put on polyester setting, my iron doesn't have a polyester setting, so I used wool????)
they also said that the transfer should be at the same heat as the iron and turn black when ready .. (it wasn't black and I wasn't touching my iron or PCB to see if they were at the same temp Shocked )
I'm sure I'll get there eventually but these PnP's aren't cheap...
as for this PCB I think I'm just gonna touch it up with a sharpie and hope for the best..
Daz
 Filesize:  71.64 KB
 Viewed:  325 Time(s)
Luka
PostPosted: Thu Nov 06, 2008 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
read the other thread, there were great tips in there
http://electro-music.com/forum/topic-29554.html
problemchild
melbourne australia
crazeydazey
PostPosted: Thu Nov 06, 2008 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Luka..
I noticed this thread and started reading it, but after reading a few posts, it just seemed to mention Printers (I have no problem with the printer, I use works which is a HP laserJet 4050 Series PCL 6 and it does a great job), I guesss if I should have read on... Embarassed
Your right there is some cool tips in there I will try these next time..
Thanks
Daz..
numbertalk
PostPosted: Thu Nov 06, 2008 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
This is probably all mentioned in the other thread but make sure you:
1) Clean the copper very well. I use those green Scotch Brite pads and some Comet or Bon Ami cleaner. Then do not touch the copper with your fingers - dry with a paper towel.
2) Make sure your iron is getting hot enough and that you are distributing the heat well (getting the iron to all the parts of the board that need the transfer). Also I put a piece of paper on top of the whole thing and iron the board and trasnsfer paper through that.
3) If using PnP, let the board cool down for a while before peeling the paper off. I've seen others say differently but mine have always come out splotchy that way. Usually if I let it cool down for 30 minutes or more then carefully peel away the transfer paper there are usually only a few minor spots, if any, that need to be touched up.
fluxmonkey
PostPosted: Thu Nov 06, 2008 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
as above and from the previous thread: cleaning the board thoroughly is th single most important thing, i think. ironing long enough (especially with such large areas to cover) will also help, i think... err on the side of ironing too long and too hard (but not too hot).
the good news is: all of the traces look like they are at least partially transferred, so i think you'll have good luck with the sharpie touchup.
b
www.fluxmonkey.com
crazeydazey
PostPosted: Fri Nov 07, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
cool.. cheers everyone
I will follow all your instructions and should hopefully have a more successful second attempt..
I think your right bbob, everything looks like it's there, so it should touch up nice with a sharpie...
thnx
Daz
Pehr
PostPosted: Sun Nov 16, 2008 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
It is also good to apply some pressure with the iron so that the black traces stick to the copper.
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Luka
PostPosted: Sun Nov 16, 2008 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
funny thing happened yesterday when i was ironing on a transfer
i had heated the blank pcb and was is the final stages of orientating the pnp so that it fit exactly within the bounds and i accidentally let the pnp drop ( i think i rubbed up against the hot pcb ) onto the hot pcb. the pnp was only down for a second and i quickly ripped it back up in panic and when i pulled it up it left a perfect transfer :0
i couldnt believe it. so much for ironing with all your pressure and for 15 minutes. it was only down for 1 or 2 seconds and the toner just ripped off the pnp and stuck perfectly to the pcb
crazy
problemchild
melbourne australia
Pehr
PostPosted: Sun Nov 16, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll try that next time Very Happy
YouTube channel
flickr photostream
Luka
PostPosted: Sun Nov 16, 2008 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
i wish i could accidentaly drop my drill onto the etched board and it completely drill all the holes! hehe
problemchild
melbourne australia
fluxmonkey
PostPosted: Mon Nov 17, 2008 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
crazy
that's the art of invention: happy accidents made repeatable.
how hot was the pcb? i preheat mine, partly to make sure it's dry after washing a partly to minimize to get a jump on the actual transfer... but only in a warm oven, up to 150 f or so, not to hot to touch...
b
www.fluxmonkey.com
Luka
PostPosted: Mon Nov 17, 2008 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
i had the iron on the pcb to warm it up for a minute or two
(iron was on just below maximum setting)
problemchild
melbourne australia
bubblebunz
PostPosted: Sun Nov 23, 2008 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I cant get pnp to work with my printer and I did a total botch of the Oddy pcb today trying my usual method of ironing the toner off a photocopy. Then I remembered this old technique for lifting magazine images; basically you tape the image face down and rub acetone into the back of it and the image is transfered across. I tried it using a photocopy of the Oddy pcb and it carried over beautifully, although it was probably too light to etch directly (I traced over it using a fineliner). I think next time I will try using a bit more acetone and leave it a bit longer and see if I can get something that I dont have to touch up. It gave me the best board I have done so far (which is really not saying very much).
Luka
PostPosted: Wed Dec 10, 2008 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i totally flunked out on my latest batch of pcbs Embarassed
standard technique and they all came out horrible
i have no idea where i went wrong
im thinking perhaps they changed the toner in the copiers at uni
so dissapointing, it was about 15 pcbs too
grr
on the bright side at least it is only the ink transfer and not the final etch
i wish pnp blue grew on trees
perhaps we should do a electro-music group bulk buy on pnp
problemchild
melbourne australia
