how do i assign vocoder to separate output
Page 1 of 1 [8 Posts]
ashevillenord
PostPosted: Thu Nov 06, 2008 4:59 pm    Post subject: how do i assign vocoder to separate output Reply with quote  Mark this post and the followings unread
I use the vocoder a lot, and would like to assign it to its own output, so I can have the vocals go through their own line on my PA. How do I split the vocoder, even if I'm using the vocoder on 2 slots and something else on the other 2 slots. I ONLY want the vocoder to go through its own output. Is this possible? Is there a way to set it up so that no matter what performance I'm in the vocoder patches will always go through their own output?
Fozzie
G2 patch files: 49
PostPosted: Thu Nov 06, 2008 5:12 pm    Post subject: Re: how do i assign vocoder to separate output Reply with quote  Mark this post and the followings unread
No other way than patching the vocoder in all patches to the correct output yourself.
Spinning at ~0.0000115740740741 Hz
ashevillenord
PostPosted: Thu Nov 06, 2008 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
how do i do that? send a patch through output 2?
G2 patch files: 626
PostPosted: Thu Nov 06, 2008 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
or output 3 and 4 for stereo. Use 1 and 2 as main stereo out.
babasynth
PostPosted: Thu Nov 06, 2008 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
so how do i send the vocoder through an output by itself?
Fozzie
G2 patch files: 49
PostPosted: Fri Nov 07, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ehmmm, by drawing a cable in the editor from the vocoder signal output to an output module. This is very basic G2 patching; have you read the manual? If not, I'd encourage you to do so as it is very informative.
babasynth
PostPosted: Fri Nov 07, 2008 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I was actually wondering if there was a way to do it in the machine itself -- rather than on the computer.
G2 patch files: 626
PostPosted: Fri Nov 07, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, if you have a G2 key or G2X, push the patch button, navigate to the 2-Out module with the arrow keys. If the patch uses the FX area then you will want the 2-Out module in the FX area. You can then select output 3/4.
You cannot change any virtual patch cords without the editor, but this is just pressing a button on one of the modules.
