NTE912 as a replacement for CA3046
Page 1 of 1 [7 Posts]
akorbeti
PostPosted: Thu Nov 20, 2008 1:23 pm    Post subject: NTE912 as a replacement for CA3046 Reply with quote  Mark this post and the followings unread
Hi all,
mouser, when queried, states that NTE912 is a Cross Reference Match For: CA3046
This is the spec sheet of NTE912.
http://www.nteinc.com/specs/900to999/pdf/nte912.pdf
is this a direct replacement, pin compatible thingy or I should grab some CA3046 from ebay?
Thanks in advance,
Aris
yusynth
PostPosted: Fri Nov 21, 2008 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
From the datasheet, the NTE912 seems to be a replacement for CA3046.
Other substitutes are : CA3146 and CA3086.
Yves
akorbeti
PostPosted: Fri Nov 21, 2008 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for your answer! I will get some of both to check out the differences. If they are compatible, the CA3046 sourcing problem might be solved!
(BTW Mouser also lists me NTE based ICs as direct replacements for CA3146 and CA3086 which are unavailable too at their site)
Thanks again,
Aris
guitarfool
PostPosted: Fri Nov 21, 2008 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
You can get the CA3086 at Smallbear for $2.35 as opposed to $5.18 for the NTE part at Mouser.
http://www.smallbearelec.com/Categories.bok?category=ICs+-+Op-Amps+and+Linear
yusynth
PostPosted: Fri Nov 21, 2008 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
cheaper at bridechamber's : 1$
http://www.bridechamber.com/bridechamber.com/Hard%202%20Find%20ICs.html
and even cheaper at futurlec
http://www.futurlec.com/cgi-bin/search/qty_price.cgi?part_no=CA3046N
Yves
akorbeti
PostPosted: Fri Nov 21, 2008 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
WOW Thanks!! I was left to think that international shipping still costs over $50.
Thank you very much guys, this was a real eye opener.
gabbagabi
PostPosted: Mon Dec 01, 2008 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
My Favorit is Banzai
0,60€ http://www.banzaieffects.com/CA3046-pr-16748.html
they got some other good stuff, and the most prices are hard to beat:
example the Alpha Pots
http://www.banzaieffects.com/Mono-Split-Shaft-c-399.html
P.S.:anyone got a good source of CA3096?
