Unable to Load Sysex. Help!
Page 1 of 1 [8 Posts]
anza
PostPosted: Tue Dec 16, 2008 9:53 pm    Post subject: Unable to Load Sysex. Help! Reply with quote  Mark this post and the followings unread
Hey there all,
I'm having an extremely frustrating issue trying to load some sysex files into my Nord Lead 2x in a Logic project--where they are dumped as midi regions. I have not opened these projects in many months, but the setup has not changed much in that time.
I'm able to dump new patches and receive them on the Nord within these projects, but the synth won't seem to take the old patches that are currently saved.
I've exported the regions with the messages as midi files, and tried to load them into the Nord via Sysex Librarian. This does not work either. The midi appears correctly in SL-- recognizes Clavia as the manufacturer,4 msgs, the right number of bytes..but when I send to the Nord it just does not acknowledge anything. It will receive other patches with no problems, just not these olders files--so I know it's set up properly.
I know for a fact that these worked in the past. I've attached one here. Perhaps someone else could try loading it? Otherwise I'm at a total loss here--and really upset! I have probably 40 of these older projects and none of them will recall anymore Sad
Any suggestions would be hugely appreciated. Thanks!
04.12.08.mid
 Filename:  04.12.08.mid
 Filesize:  683 Bytes
 Downloaded:  276 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 16, 2008 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome anza
I tried your files in my machine and they work fine (rather heavy bass, a synth sound, a cello like sound and a Rhodes...)
Your files have been in my machine, I converted them into single SysEx files, which are all Global Midi 16.
First suggestion: change the Global Midi channel [Shift+Midi(2x)] and scroll to channel 16. Send your Midi file as usual. If this doesn't work, try the 15 other ones Smile
See also
http://electro-music.com/forum/post-218113.html#218113
Second suggestion: If you are on a Windows machine go to
http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
NordGen is able to handle *.ngf *.syx and *.mid files. If you drag&drop a Midi file into it, it opens all the Programs at once.
Read about it on
http://electro-music.com/forum/post-209876.html#209876
Wout
anza01.syx
No Comment
 Filename:  anza01.syx
 Filesize:  139 Bytes
 Downloaded:  216 Time(s)
anza02.syx
No Comment
 Filename:  anza02.syx
 Filesize:  139 Bytes
 Downloaded:  227 Time(s)
anza03.syx
No Comment
 Filename:  anza03.syx
 Filesize:  139 Bytes
 Downloaded:  205 Time(s)
anza04.syx
No Comment
 Filename:  anza04.syx
 Filesize:  139 Bytes
 Downloaded:  229 Time(s)
anza
PostPosted: Wed Dec 17, 2008 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoa, Wout. Thank you!!! What a welcoming. That is extremely kind of you.
Is there something within the original sysex I posted that would require my Nord to be set to Global 16 to receive? I may have changed that at some point.
Edit--hrmm, just tried that myself and no luck. I'll read the threads you posted and see if I can't figure something out. Otherwise I may have to enlist your help again Smile. Thanks again so much.
anza
PostPosted: Wed Dec 17, 2008 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahah. That must be it!
Now that I've changed the Global Chan to 16..some of the new ones I dumped last night are not being received--so that definitely changes everything!. I read that first thread, but can you help me decode for sure--what global midi channel was used initially for the file posted? Thanks!
Edit: Ok..so it looks like I must've had the Nord set to Global Chan 1 for all of these. Oops! I thought this was a big no no. Perhaps thats why recalling patches sometimes sounded different than when they were dumped? If you can tell me again what to focus on to determine global midi chan in the sysex file, that would be a huge help.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 17, 2008 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The old ones will load now? I mean, not the ones I converted to Global Ch 16, but those 36 Program which were also 'wrong'.
Those new ones were saved on another Global Ch, weren't they?
I use Global Ch 16 by default, because it won't interfere with other channels, like using Program Change.
I think you used Global 11
4D 54 68 64 00 00 00 06 00 00 00 01 01 E0 4D 54 72 6B 00 00 02 95 00 FF 03 0F 4E 6F 72 64 20 4C 65 61 64 20 32 78 20 20 31 00 FF 04 0C 4E 6F 72 64 20 4C 65 61 64 20 32 78 00 FF 58 04 04 02 18 08 00 FF 59 02 00 00 00 FF 54 05 21 00 00 00 00 00 FF 51 03 07 62 1E 00 FF 51 03 07 62 1E 87 09 F0 81 0A 33 00 04 00 03 0F 04 06 04 0B 02 00 00 01 01 09 05 05 02 00 00 00 00 00 00 08 05 0E 07 00 00 08 01 06 06 04 05 00 00 07 05 00 00 06 01 03 06 0B 03 09 05 0A 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 02 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 00 00 08 00 F7
But what the 81 stands for... Shocked
Wout
anza
PostPosted: Wed Dec 17, 2008 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout, correct--I am able to load the old ones now which I thought were corrupt!--the ones I uploaded. All I had to do was change the Global Channel back to 1--which I guess was what it was set to when I originally dumped these.
I did not realize that had an impact. Likewise, the ones I was dumping last night that were working--the synth was set to global channel 8. So when I changed it from 8, those ones no longer worked either! Unless of course that synth was set back to 8. So I think I'm all good now. Thanks so much for the tips!!!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 17, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last tip:
Better upload all those strange files in the Global Midi that they need, change the Global to 16 and save again. I know, it's a bit of work, but you'll work uniform and are able to upload all the programs in the Archive too. Will keep you busy with Christmas Very Happy
Wout
anza
PostPosted: Wed Dec 17, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Wout! That's a great idea. I will do that--and since I've added a new interface, all the input channels are a little funny on these projects too--so I've got to get all that back in order too. Definitely will keep me busy, but totally worth it.
