Let's see your Lunetta!
Page 1 of 22 [526 Posts]
Goto page: 1, 2, 3, ..., 20, 21, 22 Next
RF
Audio files: 28
PostPosted: Tue Nov 25, 2008 7:11 am    Post subject: Let's see your Lunetta!
Subject description: More audio would be fine, too....
Here's mine in its current form
* Quad 40106 Osc with starve pots, synch and ext power inputs.
* Dual 40106 Osc with starve pot and ext power input
* 4094 Shift register
* Dual 4015 Shift register
* 4024 Divider/Sub Osc.
* 4051 CV generator
* 4051 Pulse Pattern generator
* Passive 3 input mixer
* 4011 Ring Mod
* 4011 NAND gate
* 555 VCO
* Six 40106 Osc with two voltage control inputs
* 6 input R/2R Ladder
* 4017 Pulse Divider/Sub Osc
* Simple Portamento
* Passive tone control
* 1/4 inch outputs
* Built in 110 volt power supply
bruce
 Filesize:  103.22 KB
 Viewed:  1807 Time(s)
www.sdiy.org/rfeng
telstarmagikistferrari
Audio files: 43
PostPosted: Tue Nov 25, 2008 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, that thing is dazzling! really, really nice work. do have any schematics handy for these circuits?
View user's profile Send private message Visit poster's website Yahoo Messenger
RF
Audio files: 28
PostPosted: Tue Nov 25, 2008 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Most of the schematics can be found here within the Lunetta forum.
Not really much to see - most of them are one chip, a few passive components and I/O's to the front panel....
bruce
www.sdiy.org/rfeng
Audio files: 43
PostPosted: Tue Nov 25, 2008 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
my fault.. shortly after I posted that request,
I started poking around the other posts. lots of resources here. Thanks RF.
synthmonger
PostPosted: Wed Nov 26, 2008 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where'd ya get the case and Banana jack and cords?
synthmonger
PostPosted: Wed Nov 26, 2008 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
P.S.
Nice work homeslice Wink
RF
Audio files: 28
PostPosted: Wed Nov 26, 2008 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got the case holding a bunch of cheap tools for under $20. Smile
The Pamona stacking plugs I got from E-bay. (http://stores.ebay.com/CemPhoto-WorkShop-LLC)
The EF Johnson non-stacking plugs were from Mouser. (Part #530-108-0310-1). The EF Johnson colored jacks were from Mouser (Like Part #530-108-0903-1)
www.sdiy.org/rfeng
slacker
PostPosted: Sat Jan 03, 2009 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my first lunetta module nothing fancy it's just 6 40106 oscillators. 2 sub audio LFOs, 2 that go from fast LFO speeds to low audio and 2 audio ones.
Just waiting for my banana jacks to arrive to finish it off.
slacker
PostPosted: Mon Feb 16, 2009 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Work in progress inspired by RF's Lunetta.
The power connection's just temporary until I figure out something more permanent.
Audio files: 43
PostPosted: Mon Feb 16, 2009 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, slacker.. inspiring.
After I have RFs machine for awhile, I may build a couple add'l modules (once I decide if I need them/what I would want). Right now I'm just spazzing around with the myriad options as is and will likely be for SOME time. Smile
I like that you used reg. stainless steel for the faceplates too. Very cool.
RF
Audio files: 28
PostPosted: Mon Feb 16, 2009 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oooh!
That's puuuurdy!
Congrats slacker - I can't wait to see it all filled up and making good sounds.
bruce
www.sdiy.org/rfeng
scriptstyle
PostPosted: Mon Feb 16, 2009 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
my lunetta project has been a long time in the making. but give me a month and i should have the first module mounted and i will post up some pics. by the way slacker very nice and clean looking! where did you get those fancy pots(nice) Wink ?
slacker
PostPosted: Tue Feb 17, 2009 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks folks Smile
It's actually aluminium, the photo makes it look much shinier than it is. It's stuff the you use to make splashbacks for your kitchen work tops. It's cheap and it's just about stiff enough.
scriptstyle the pots are from Rapid Electronics in the UK. They're a lot more expensive than the 16mm Alphas that I normally use, but they made wiring it up a lot simpler.
Audio files: 43
PostPosted: Tue Feb 17, 2009 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
yeah stainless steel might be a tad hard to drill holes into at home..
(or would it be? fuck if I have a clue about fuck)..
Mark
synthmonger
PostPosted: Wed Feb 18, 2009 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is all lunetta minus the CA3080 VCA and op-amps used for the EF, EG and mixer....which could've been done with a 4069 ;x
 Filesize:  322.63 KB
 Viewed:  3351 Time(s)
Audio files: 43
PostPosted: Wed Feb 18, 2009 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
*jaw dropping*
RF
Audio files: 28
PostPosted: Wed Feb 18, 2009 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's great - Nice layout!
Sounds?
www.sdiy.org/rfeng
synthmonger
PostPosted: Thu Feb 19, 2009 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds coming soon. I posted a sample of two vcos being CV'd by the sub-oscillator/sequencer in this thread:
http://www.electro-music.com/forum/topic-27239-25.html
it's the ultra_blee_machine.mp3 file.
FYI I built it specifically for a show that I had recently. I wanted stereo sound that I could process through a modular synth as well as control it. That's why there are two Envelope Followers with gate outputs. It worked out pretty well.
As for audio/video sample I will be posting a video by this weekend of it in action with the sound recorded directly to the computer.
The case was built rather quickly with MDF which was the only spare wood I had. I'd like to rebuild the case for it, but I don't have time as I'm so caught up in other projects.
I decided to sell it too. Being that the case is a bit of an eyesore I'm selling it pretty cheaply on my etsy store. If anyone is interested you can check it out here http://synthmonger.etsy.com
synthmonger
PostPosted: Thu Feb 19, 2009 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where'd ya get the panels?
synthmonger
PostPosted: Thu Feb 19, 2009 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to mention that I did make the layout but my friend cut the panels and the layout which is why they look half-assed. If you want something done right, do it yourself! Wink Smile
Adam-V
PostPosted: Thu Feb 19, 2009 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my lunetta layout - I'm in the process of making the panel in bakelite but it's real bastard to drill so progress is slow.
Adam-V
Lunetta Layout
 Filesize:  230.11 KB
 Viewed:  2300 Time(s)
synthmonger
PostPosted: Thu Feb 19, 2009 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've earned a standing ovation from me for that layout!
I can't wait to see it ready to go. Please do a build progress!
scriptstyle
PostPosted: Thu Feb 19, 2009 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow thats awesome!!! now i feel like my jam packed design needs some of the cool stuff you have. i have a acouple questions?
1. what is the dual monostable design?
2.the manual logic, is it constant 1 or 0?
3.the logic constants are these similar to the manual logic but the red ones output a 1 and the green output a 0?
4.what ic are you using for the magnitude comparator.
5. and are you using banana's? im guessing no cause you have the multiples.
well it looks great cant wait to see more i second the build report!!
Adam-V
PostPosted: Thu Feb 19, 2009 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the compliments guys.
To answer your questions scriptstyle:
The dual monostable is just that: two monostable mulitvibrators or one shots. They work just like gate/trigger delays or gate extenders in a modular synth.
The manual logic module is just a set of 3 position toggle switches that can set logical levels. Up = 1, Centre = 0 and Down = 1 but is momentary.
The logic constants work exactly as you guessed, red = 1, green = 0.
I haven't built the magnitude comparator yet but I was planning on using the 4063.
I am using banana jacks but I dislike the stacking function as they stick out too far when stacked and I find the stackable plugs to be too bulky for use where the jacks densely packed.
Adam-V
fluxmonkey
PostPosted: Thu Feb 19, 2009 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
beautiful thang... now matrixsynth, so i'll bet someone snaps it up. what circuit did you use for the envelope follower?
b
www.fluxmonkey.com
