disable autopower off on Casio SK 1, anyone?
Page 1 of 1 [15 Posts]
maxime
PostPosted: Sun Jan 25, 2009 12:54 pm    Post subject: disable autopower off on Casio SK 1, anyone? Reply with quote  Mark this post and the followings unread
hi you all,
It's my first post on electro-forum!!!
Do you know about a hack to disable the autopower off feature on the Casio SK 1 or SK 5? I tried to tie T5 to the ground unsuccessfully, the main chip seems to shut down after 8 minutes anyway, even when the general psu circuit stays active.
thanks
best
Maxime
PostPosted: Sun Jan 25, 2009 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Maxime, not sure if it was the same keyboard but I remember some discussion about an auto shutdown feature somewhere here on the board ... IIRC it had to be solved by repeatedly simulating (using some electronics) some button press. Maybe search the forum for auto power off ...
maxime
PostPosted: Mon Jan 26, 2009 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your reply blue hell!
damn, it seems like this feature isn't easily bendable!
best
maxime
gmeredith
PostPosted: Mon Jan 26, 2009 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Maxime,
The original site with the SK-1 auto power off disable is here:
http://www.electri-fire.com/sk1pagesoverview.htm
As for the SK5/SK8, they can't be disabled by this method - i've tried in vain over a long time. The reason is that the SK5/8 have a "smarter" processor than the SK-1 that, although you can do the same mod to them to disable it, will still fall asleep after the allocated 7 mins. The rest of the keyboard will be awake still if you do the mod to it, but it's useless without the processor awake to operate the keyboard.
The best workaround method for the SK5/8 is to activate a key or button every 6 or so mins - just before the APO shuts the keyboard off. This can be done automatically by using a simple 555 timer circuit and a tiny reed relay or something that is hooked up to a relatively unused button on the keyboard - such as the STOP button on the rhythm (this assumes you don't use the internal sequencer/rhythms - otherwise choose another button). The circuit "pings" the switch every 6 mins or so. This will keep the keyboard awake.
Cheers, Graham
maxime
PostPosted: Tue Jan 27, 2009 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
HEllo Graham,
I will try your route on the sk1. the same circuit as sk5/8 is used on it. the keyboard shuts down at 8 minutes, even if the psu is kept awake..
the electri-fire mod doesn't work on my sk1, because of the smart processor also.
thanks a lot
Maxime
gmeredith
PostPosted: Wed Jan 28, 2009 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Maxime,
I found some more info on the apo bypass. I can't remember where it is from but I saved it as a web page to my computer ages ago for reference. I turned it into a pdf document for you (attached). It gives some info about getting it to work.
Cheers, Graham
SK1 APO bypass.pdf
 Filename:  SK1 APO bypass.pdf
 Filesize:  243.45 KB
 Downloaded:  696 Time(s)
gmeredith
PostPosted: Wed Jan 28, 2009 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is also the design for a simple "pinger" circuit to close a relay switch to attach to the SK5 (or SK1 if the APO bypass mod doesn't work). I haven't tried this circuit out, so it may need some tinkering with the resistor values to get the ping time to what you want.
Cheers, Graham
 Filesize:  379.19 KB
 Viewed:  511 Time(s)
maxime
PostPosted: Thu Feb 05, 2009 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
I used a 1 sec on/ 120 sec off 555 oscillator as in the schematics attached. Connected to a reed relay playing the "clear" key works like charm!
many thanks
Maxime
 Filesize:  24.3 KB
 Viewed:  574 Time(s)
gmeredith
PostPosted: Thu Feb 05, 2009 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that's great news! Glad that circuit worked out - thanks for posting the 555 schematic.
Cheers, Graham
PostPosted: Thu Feb 05, 2009 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumleft
electri-fire
G2 patch files: 4
PostPosted: Wed Sep 30, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the dead link, I seem to have changed something at my site, so for those browsing the archives: Auto Power Off disable is here:
http://www.electri-fire.com/sk1autopoweroff.htm
Sam_Zen
PostPosted: Wed Sep 30, 2009 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks a lot electri-fire ! Years ago I modded my sk1s a lot, but didn't find a solution for the dreadful APO.
Other than bridging the 'fill' button, because I almost never use the percussion.
Your site looks very interesting. I will check it out.
electri-fire
G2 patch files: 4
PostPosted: Thu Oct 01, 2009 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
gmeredith wrote:
I found some more info on the apo bypass. I can't remember where it is from but I saved it as a web page to my computer ages ago for reference. I turned it into a pdf document for you.
I updated the link for convenience.
The info was already in gmeredith's pdf. It started as a thread at the forum of sk1.org (Jesse "Tablebeast" Savage's sk1 related site, but this site is no longer available).
PostPosted: Thu Oct 01, 2009 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow! I used to be on the sk1 forum all those years back. Do you remember Freya?
Anyway, thanks electri-fire for such a great site. Shame the samples don't seem to do anything though.
A great mod on the VSS-30 (and 200?) is to starve it of voltage and amps (ie a dead battery). Some beautiful sounds can be created that way. Idea
ACHTUNG!
Lorenzo
PostPosted: Sun Oct 04, 2009 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks... for these links and mods!
Yes!
Oh Yeah!
Wow!
