Nord lead 2 msb and lsb?
Page 1 of 1 [8 Posts]
brick_in_the_wall
PostPosted: Thu Jan 29, 2009 8:20 am    Post subject: Nord lead 2 msb and lsb?
Subject description: what numbers?
Hello,
I am trying to control nord lead via midi from another synth...everything works fine,but MSB and LSB don't (I can't change banks from on nord rack from keyboard).
So,anyone knows what numbers are in game?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jan 29, 2009 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, normal, I think... MSB = 0 and LSB = 32 [Manual Page 92]
Only be sure the message is send by the Global Midi Channel [Manual Page 72]
Wout
brick_in_the_wall
PostPosted: Thu Jan 29, 2009 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
no,its just lsb 1,2,3,4....
But I don't get how to enter performance mode?
Someone with knowledge?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 30, 2009 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sending over the Global Midi?
Recording Program and Performance changes works fine sending from the synth, so may you can monitor what is being send?
Wout
brick_in_the_wall
PostPosted: Fri Jan 30, 2009 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello,
I am trying to send this message from motif xs...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 30, 2009 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
And this is sending on the same Global Midi channel as the NordLead?
Wout
brick_in_the_wall
PostPosted: Sun Feb 01, 2009 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Feb 02, 2009 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe to see what messages are send from the NordLead could help you.
Program
B0 20 00 (= Program mode) (=Bank location)
C0 00 00 (location of Program in Bank)
B0 20 00
C0 01 00
B0 20 00
C0 02 00
etc
Program Bnk 1
B0 20 01
C0 00 00
B0 20 01
C0 01 00
B0 20 01
C0 02 00
etc
Performance
BF 20 00 (= Performance mode) (=Bank location)
CF 00 00 (location of Performance in Bank)
BF 20 00
CF 01 00
BF 20 00
CF 02 00
etc
Performance Bnk 1
BF 20 01
CF 00 00
BF 20 01
CF 01 00
BF 20 01
CF 02 00
etc
Percussion Bnk 1
B0 20 00
C0 63 00
B0 20 00
C0 64 00
B0 20 00
C0 65 00
etc
NB This is the result of a reading of the NordLead2. When two Leads are linked together, this works!
IMPORTANT!!! The Program/Performance mode button doesn't send any Midi. If your controlling synth can send these messages (on a Global Midi channel), it will work...
More NB Wink The B02 000 could also be the bank locator...
Wout
