Posted: Sat Jan 31, 2009 5:05 pm Post subject:
Two Pickups, Two Pots? Subject description: How to wire this correctly? |
Hi everybody,
I feel like I should know this, but a friend asked me to re-wire his bass, and I'm kinda unsure about how to do it right.
The problem is there are two pickups, and two pots. No selection switch, no active circuitry. He wants it so each pickup has it's own volume control. The obvious, 2 volume style voltage dividers across the output, will short the other pickup out when when is turned down. I thought of reversing the pots, (wipers towards the pickups) but this puts a large impedance across the output. Doesn't it?
Any advice would be very appreciated. _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Sat Jan 31, 2009 5:09 pm Post subject:
That is a tough one. Perhaps try isolating the pots with series resistors on the wipers? It will be interesting to see what your solution is. _________________ "Let's make noise for peace." - Kijjaz |
Joined: Apr 03, 2004 Posts: 24673 Location: The Netherlands, Enschede
Posted: Sat Jan 31, 2009 5:43 pm Post subject:
Hmm ... but then again ... a guitar always has high impedance ... _________________ Jan
Posted: Sat Jan 31, 2009 5:58 pm Post subject:
I'm kind of happy that I saw putting a high impedance across the output as bad.
A typical volume pot on a guitar is about 500K, so with two of them turned around there would be a constant 250K (or less) across the output.
I still don't instinctively understand the input/output impedance thing, so I don't know if this is good, or why.
The other possibility is to go with 1 volume pot (500Klog) and a smaller passive balance pot (10Klin). This wouldn't allow completely muting either pickup though.
If it helps at all, a typical pickup has an impedance of about 5K to 15K. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sat Jan 31, 2009 6:11 pm Post subject:
| Uncle Krunkus wrote: | | an impedance of about 5K to 15K. |
DC, but AC it would be higher ... can't find any numbers quickly ... but saw that guitar electronics are assuming a load impedance of around a Meg Ohm. Max energy transfer would occur when the guitar impedance would be around that Meg as well, not counting phase shifts (freq. dependent behaviour) there, ... whatever you do though without active stages it would always be a compromise ... but you seem to be discovering the boundaries quickly  _________________ Jan
Inventor
Audio files: 267
Posted: Sun Feb 01, 2009 1:52 am Post subject:
This article
http://buildyourguitar.com/resources/lemme/
has a table that lists pickup impedance values. Typical are 2.5 Henries of inductance in series with 5k of resistance followed by a shunt 100pF cap. There's your source model, it's a second order low-pass filter.
This is normally followed by the volume and tone pots and cable capacitance as you are aware. Whatever you come up with, you can do an AC simulation of it if you like. Good luck! _________________ "Let's make noise for peace." - Kijjaz |
Posted: Sun Feb 01, 2009 3:47 am Post subject:
| Inventor wrote: | This article
This is normally followed by the volume and tone pots and cable capacitance as you are aware. Whatever you come up with, you can do an AC simulation of it if you like. Good luck! |
I'm thinking that you have probably over-estimated my understanding of "second order low-pass" filters by a long way.
As for an AC simulation, that means I wire it up and have a listen doesn't it?  _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Sun Feb 01, 2009 3:52 am Post subject:
| Uncle Krunkus wrote: | I'm thinking that you have probably over-estimated my understanding of "second order low-pass" filters by a long way.
As for an AC simulation, that means I wire it up and have a listen doesn't it?  |
Maybe I'll run a simulation for you, Krunkus! But first you'll need a topology that works. Let me draw something up, then I'll post it. _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 267
Posted: Mon Feb 02, 2009 8:16 pm Post subject:
Okay, I've changed my mind again. It should be a Log pot.
I've dicovered a bigger problem though. The main reason he wanted it re-wired is that the 10K pot "seems" back to front. Because,... he's got those gold hat type knobs which show "10" when the pot is fully counterclockwise.
So,... short of finding a 10K antilog pot (I don't like my chances there!) I think I should sub a linear 20K with a 20K resistor around one side to simulate an antilog pot. This actually could result in a far smoother log response than you can get from any "log" pot anyway.
Does that make sense to anyone else? I hope it does. _________________ What makes a space ours, is what we put there, and what we do there. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Tue Feb 03, 2009 3:51 pm Post subject:
| Why not just flip the wires on the pot? |
Posted: Tue Feb 03, 2009 4:04 pm Post subject:
That's fine if it's a linear pot. But if it's a log pot it doesn't work, as the curve in the response is right for the higher volumes to be at the clockwise end.
That why we have (although they can be hard to find) antilog pots. They have a similar taper, but the other way around.
Log taper are designated "A"
Linear are designated "B"
And antilog are "C" _________________ What makes a space ours, is what we put there, and what we do there. |
Danno Gee Ray
Posted: Tue Feb 03, 2009 4:32 pm Post subject:
Roger that...DUH...Bummer.
Knobs without numbers?
...Bummer. |
Posted: Tue Feb 03, 2009 4:53 pm Post subject:
| Danno Gee Ray wrote: | | Knobs without numbers? |
Hmmm,..... That's what I'd do.
Something tells me you don't do much work for guitarists.
I must admit, bass players are usually a lot more laid back, but I still see changing the knobs as the last resort.  _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Tue Feb 03, 2009 6:13 pm Post subject:
Krunky Uncle, why are you using log pots? My thought is that linear pots would work best here. Also, no comment on my differential suggestion - it would have a balance pot and a volume pot which would be really easy to set, more intuitive I suppose. _________________ "Let's make noise for peace." - Kijjaz |
Posted: Tue Feb 03, 2009 6:59 pm Post subject:
I only used the log pots 'cos they were there when I opened it up. I must admit that the differential idea is looking better all the time. _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Tue Feb 03, 2009 7:10 pm Post subject:
| Uncle Krunkus wrote: | | I only used the log pots 'cos they were there when I opened it up. I must admit that the differential idea is looking better all the time. |
Yeah, what you're doing is the same thing in reverse really. You're tapping one pot with a volume control, then sticking this on one side of a mixer pot. But the problem is that the first pot will have a high source resistance at mid position, and the second pot will be all quirky and nonlinear in response.
By comparison, the suggestion I made is just like your idea, but it does the differential first and the volume second.
Now that you mention that the original equipment had a log pot, I'd say that the volume pot should be one of those log pots. The balance pot should be linear to get linear balance, but apparently there is reason for a log pot in the volume position. Also, I would make the balance pot fairly low in value compared to the volume pot.
I can hand-code some equations for you if you like, but basically I'd say give it a try and report any problems. Good luck with it! _________________ "Let's make noise for peace." - Kijjaz |
Posted: Tue Feb 03, 2009 7:50 pm Post subject:
I just found out (from a guitar site) that the reverse pot concept (pickup to wiper, full value across the output) is fine, and is the way jazz bass wiring is done. When the volume is up you have a much smaller impedance (the pickup) across the output, and you want the pot to be in the region of 250K-500K anyway so that you don't lose too much top end to ground.
So now I'm thinking of trying that with two 500K linear pots. A fixed resistor (about 680K) between the wiper and the top should logarise(?) the control.
Man,... I never thought getting this stuff right would be so fraught with hard decisions!  _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Tue Feb 03, 2009 8:01 pm Post subject:
Uncle, I'm surprised that that's what works, but OK whatever. Let us know how it works out! _________________ "Let's make noise for peace." - Kijjaz |
