Please Help!
Page 1 of 1 [5 Posts]
Sound Maniac
PostPosted: Thu Feb 12, 2009 8:42 am    Post subject: Please Help! Reply with quote  Mark this post and the followings unread
Im not sure of what the problem is but one thing i can say is im totaly lost,
and it has being freaking me out for a long long time.. I do anything to get rid of it..
I think is arrrangement but im not sure.. because i cant finish a damn track everything i do sux.. I just delete all the time..
I apreciate all kind of help, and would be very greatfull if anybody can help me because im sick of it.
PLUR
EdisonRex
Audio files: 172
PostPosted: Thu Feb 12, 2009 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Start with deep breaths. Smile
All tracks sound sucky on their own. It is only as part of the whole that the production sounds whole.
One thing I do is start a production by recording all the tracks I think I should have. They usually have faults, but I can hear them all together. Which allows me to think in the context of the whole production, not lose myself in the detail of a single track. It is unproductive to get too focused on a single track, especially early in the production. There is time for that much later.
If you are hearing something and it isn't happening when you record it, record it anyway, and then do the other tracks you think you need. You can always record extra tracks too. I do that a lot. Then figure out what you want from the production, and then re-record or edit tracks as you think. You might be surprised.
Garret: It's so retro.
Sound Maniac
PostPosted: Thu Feb 12, 2009 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
you mean to make first full track in bass and kick for example
then make full track in percussion
and then make full track in each synth sound sepearatly and record them seperatly and same with the fx etc etc..
And final step put them all together, if i havent missudnerstand you thats how i got it.. And Big Thanks! Apreciate your advice.. PLUR
Sound Maniac
PostPosted: Thu Feb 12, 2009 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ofcourse its not important how they sound seperatly its important how they sound together, specially if you use sidechain alot Very Happy
EdisonRex
Audio files: 172
PostPosted: Thu Feb 12, 2009 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that is the idea. Build up. Unless you are very experienced, you can not hear the missing tracks in your head to compensate for the track you are recording. And if you are experienced, you will do them in an order that builds the production.
Yes, your second post shows you understand. I usually do a scrap piano track to run the song, then add kick/snare, bass, the rest of the drums, rhythm, maybe lead or backing, maybe backing or lead, and then finally the vocals or leads. But the point is there is a process you should follow and the early parts sound like crap and don't worry about it, because you can record more tracks later. Or you can fix the parts of the tracks you don't like later.
Main thing is to get some context from the whole recording.
Wink
