today> Bill Fox solo tonight! Chez Mosc
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Distanizer
Page 1 of 1 [3 Posts]
Rix
G2 patch files: 25
PostPosted: Thu Oct 14, 2004 6:51 am    Post subject: Distanizer Reply with quote  Mark this post and the followings unread
I was looking for a way to make sound more distant, ambient.
The following simple patch is based on multiple delays (each with different time to simulate miltiple reflections) followed by some differently tuned comb filters ( to simulate random absorbtion in a room, say by objects and people).
The patch can be used to feed any audio thru, or use it as a second slot on a performance to add 'distance' to a synth patch....
Variations 1 ..3 are increasingly distant.
Richard.
Distanteaser.pch2
To make sound more distant, broader.
 Filename:  Distanteaser.pch2
 Filesize:  1.47 KB
 Downloaded:  1865 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Sun Oct 24, 2004 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it. For me, variation 3 is a bit too much for instruments with sharp attack (like piano sounds), as you start to hear multiple delays there. For strings: nice! Thanks thumb up
Rix
G2 patch files: 25
PostPosted: Wed Oct 27, 2004 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hoi Fozzie, bedankt. (thanks)
The patch could probably be improved by adding a bandpass (or higpass) filter for each channel - because bass signals tend to drop of with increasing distance - and maybe adding very little phasing.
I am also thinking of a similar patch were the audio signal starts in the left corner (far away), then comes foreward to the middle (including doppler effect) and then goes to the far right (distant again), with doppler.
Richard
