CALL FOR PARTICIPATION: A WINTER STREAM 09
Page 3 of 5 [103 Posts]
ylla
PostPosted: Thu Feb 19, 2009 8:00 pm    Post subject: NiceCast on MacBook OSX
Subject description: Help from anyone running this config
Hi, I've been digging into NiceCast. It give a library not found & no image found for IceCast. NiceCast sends its stream to IceCast to broadcast. As far as I can tell, without IceCast I can't get out.
The RogueAmoeba server checker cannot connect in, either.
IceCast claims it needs Darwin Port to install it. Darwin Port 1.7 says it needs Mac OSX 10.5 (I have 10.4).
If anyone can point me at something to get the "dominoes" falling, it would be great. I am good from keyboard to Mac.
Or should I just spring for NiceCast on a Windows XP Asus Eee PC? Or is there something I failed to download from the Amoeba?
ylla (on EM) aka Slate on Different Skies
EdisonRex
Audio files: 172
PostPosted: Fri Feb 20, 2009 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Nicecast can connect to the electro-music.com server. There is no need to connect to the Icecast server, and you can configure that away.
But you need Nicecast to be able to output Shoutcast. It is likely your installation has failed.
In the Server window you can see Built-In Server, click that to test with. You might need to open out the wing window, there are little buttons near the top to do this with. Assuming that works you then add radio.electro-music.com as a server, server type is Shoutcast, the username is blank, and the port is whatever you were assigned. With broadcast off, you can switch servers, and then you can try to broadcast.
Detailed descriptions of actions and error messages would go a long way to helping you.
Garret: It's so retro.
PostPosted: Fri Feb 20, 2009 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Connected ok to the stream on my new port. Going to test with actual sound tomorrow.
/Stefan
Inventor
Audio files: 267
PostPosted: Sat Feb 21, 2009 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I would post a photo of the Y cable that I use for audio routing... We tested it today and even if I wiggle it, it does not lose signal or break up. An alternative to software audio routing, it only costs seven bucks. Sweet, eh?
The amazing Y cable
 Filesize:  247.89 KB
 Viewed:  401 Time(s)
shanemorris
Audio files: 92
PostPosted: Sat Feb 21, 2009 11:06 am    Post subject: GOT STREAM? Reply with quote  Mark this post and the followings unread
18:00 UTC exactly here...feb.21
my new studio arrangement for streaming/chatting while playing....
 Filesize:  607.3 KB
 Viewed:  397 Time(s)
ElectroCasa
Inventor
Audio files: 267
PostPosted: Sat Feb 21, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
That is way too neat, lol! Maybe you cleaned up for the photo. Looks like an awesome studio! BTW, see that cabling photo above? That's my studio. I'm a PC ChucKist now, haha.
shanemorris
Audio files: 92
PostPosted: Sat Feb 21, 2009 11:14 am    Post subject: GOT STREAM? Reply with quote  Mark this post and the followings unread
playing....
 Filesize:  591.99 KB
 Viewed:  403 Time(s)
ElectroCasa
ocp
Audio files: 9
PostPosted: Sat Feb 21, 2009 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my little corner Smile
photo stitched
 Filesize:  213.73 KB
 Viewed:  399 Time(s)
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
Inventor
Audio files: 267
PostPosted: Sat Feb 21, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is me with headphones on. I'm wearing the Oodles of Noodles contest prize necklace.
Me, a ChucKist, photo taken with netbook webcam
 Filesize:  23.31 KB
 Viewed:  390 Time(s)
Audio files: 297
PostPosted: Sat Feb 21, 2009 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
My current streaming setup, couple of computers, G2s, mixer and some FX
shanemorris
Audio files: 92
PostPosted: Sat Feb 21, 2009 2:06 pm    Post subject: view Reply with quote  Mark this post and the followings unread
here is a webcam of a view not far from where i live.....
http://www.weatherbonk.com/weather/camDetail.jsp?id=cam_1173189458904
ElectroCasa
jono
PostPosted: Sat Feb 21, 2009 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Things are tested and working.
Ready to start Cool
Here is a picture taken with my cell phone not very good but illustrative of what I will use tomorrow.
 Filesize:  595.97 KB
 Viewed:  370 Time(s)
telstarmagikistferrari
Audio files: 43
PostPosted: Sun Feb 22, 2009 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
listening in.. thanks for participating to all the musicians!
marck
View user's profile Send private message Visit poster's website Yahoo Messenger
shanemorris
Audio files: 92
PostPosted: Sun Feb 22, 2009 4:37 am    Post subject: A WINTERSTREAM 2009 Reply with quote  Mark this post and the followings unread
A WINTERSTREAM 2009
 Filesize:  672.66 KB
 Viewed:  358 Time(s)
ElectroCasa
shanemorris
Audio files: 92
PostPosted: Sun Feb 22, 2009 4:43 am    Post subject: EdisonRex Reply with quote  Mark this post and the followings unread
EdisonRex
 Filesize:  36.29 KB
 Viewed:  18095 Time(s)
ElectroCasa
Inventor
Audio files: 267
PostPosted: Sun Feb 22, 2009 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I stopped by the injection molding factory and visited Plastixman. Here is a photo of him taking a break from work.
plastixman at work
 Filesize:  271.2 KB
 Viewed:  18090 Time(s)
ylla
PostPosted: Sun Feb 22, 2009 5:15 am    Post subject: Slate's Studio at The Friendly House, Bloomington, IN
Subject description: This is the setup for streaming to Winter Stream 2009
Performance Gear, Clockwise from Lower Left:
Korg M50
Red Sound DarkStar XP2
Fostex MR16HD
Mackie 1402-VLZ3
Asus Eee PC (streams mixer output)
[Apple iPod for bird song, not visible]
Korg Kaossilator (played independenty & set up temp loops)
Virus TI Snow
Korg padKONTROL, left bank synths
Clock! Watch the time for the set!
Korg padKONTROL, right bank synths
Waldorf Blofeld
Roland Fantom X6
Alesis Micron
Production Gear, Left to Right:
Fostex VF80ex (final mastering & level control)
TC Helicon Finalizer Express (top, pre-mastering, compression, limiting)
Behringer 1502 EQ (equalization & coarse level control)
The Friendly House Studio
 Filesize:  150.36 KB
 Viewed:  476 Time(s)
Production Gear
 Filesize:  81.58 KB
 Viewed:  364 Time(s)
ylla
PostPosted: Sun Feb 22, 2009 5:22 am    Post subject: Slate His Own Self
Subject description: The hair has grown back, lookin' serious...
Pretty grim cuz there's 18 inches of now out there & the Blazer is stuck. Guess I wasn't gon' to work that day! Cool
So, you guys want the bald/shaved head "Crimes Against Music" Pic? It's got the Photoshopped tattoos & is re-e-e-ly scary. Looked like a serial murderer during cancer therapy...which seems to have worked! Very Happy
Slate, his own self
 Filesize:  130.99 KB
 Viewed:  385 Time(s)
ylla
PostPosted: Sun Feb 22, 2009 5:36 am    Post subject: SlateAKA Shamaniaq in "Crimes Against Music"
Subject description: During radiation treatment, summer 2009
This pic ain't *bad*, it's just UGLY!
How about those tats? Photoshop is amazing... Cool
 Filesize:  458.7 KB
 Viewed:  456 Time(s)
PostPosted: Sun Feb 22, 2009 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are my main tools for the evening: the monome and Behringer controllers. I'll be gating and tweaking sounds produced by a Nord Modular G2 and a Poly Evolver.
/Stefan
 Filesize:  819.21 KB
 Viewed:  388 Time(s)
mystahr
PostPosted: Sun Feb 22, 2009 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
After the last stomps found their way into the chain
The studio as it is now
 Filesize:  1.06 MB
 Viewed:  368 Time(s)
an older image of me
 Filesize:  1.1 MB
 Viewed:  350 Time(s)
M<
Ganzha
Audio files: 27
PostPosted: Mon Feb 23, 2009 3:29 am    Post subject: here I am Ganzha
Subject description: my equipmnt during streaming
Hi!
Here I am
 Filesize:  968.58 KB
 Viewed:  360 Time(s)
http://ziart.kz
DrJustice
PostPosted: Mon Feb 23, 2009 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the wonderful Winter Stream Event!
Unfortunately I couldn't listen to everything, but the sets that I did catch were very good Smile
DJ
ocp
Audio files: 9
PostPosted: Mon Feb 23, 2009 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to thank all for making this wonderful night possible Wink
It was great fun (and it's becoming a habit) Smile
For those who missed my set, you may download it here (85.56 MB).
And for the curious, I used:
MacBook Pro
Apogee DUET
MOTU MIDI express 128
Butt streaming tool (also used to record)
Numerology 2
Macbeth M3X
AS Red Square
Clavia micromodular
Red Sound Dark Star XP2
Novation K-Station
Akai mfc42
Akai G-Drive
tc electronic m300
Boss DD3
TL Audio Fat1
dbx 266XL
Behringer Xenyx 1002
Behringer DI 100
Philips turntable and scratched, cut and taped vinyl
 Filesize:  533.42 KB
 Viewed:  355 Time(s)
shanemorris
Audio files: 92
PostPosted: Mon Feb 23, 2009 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
WINTERSTREAM09 was a blast!!! Thanks to all that helped make this event possible...including players, engineers, and listeners. It takes all of us to make events like this possible.
It was a great audience of a consistent 20 to 30 listeners from beginning to end. It's wonderful to play for people that appreciate and understand the direction of the music. I look forward to the next one!!!
ElectroCasa
