macumbista
Posted: Wed Nov 26, 2008 5:02 pm Post subject:
Anyone with the CAD files want to post them? The original poster seems to be MIA.... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
macumbista
Posted: Wed Dec 10, 2008 10:47 am Post subject:
In case anyone else was looking for a free CAD program, I just checked out http://sketchup.google.com/ and it seems pretty easy to work with, and imports DXF and other CAD files. _________________ Esoteric drones and nonlinear distortion
macumbista.net |
Posted: Sun Feb 01, 2009 8:37 am Post subject:
I owe you guys an explanation as I've been away from the forum for a while (7 months! ).
I'll have another look at the CAD drawings soon- and the final product will be in PDF format, as well as STL files (so no expensive CAD packages to shell out for). But it will take a while.
Okay?
Tom |
Spir4L
Posted: Sun Feb 22, 2009 3:58 am Post subject:
Hi! Very Good Job... I'm interested in trying to make a case similar to yours to start my first eurorack modular synth! (So I think I'll use the A-100 diy kit)
Is the pdf file ready?
Can I have the cad files?
Thank's to all you =) |
Posted: Sun Feb 22, 2009 7:14 am Post subject:
I won't be posting CAD files, only 2D files in PDF format.  _________________ ACHTUNG!
ericcoleridge
Posted: Sun Feb 22, 2009 7:09 pm Post subject:
| v-un-v wrote: | I won't be posting CAD files, only 2D files in PDF format.  |
Did you decide which format to design this case for. I'm hoping to find/make/buy one for 4 unit Buchla size modules. |
Posted: Mon Feb 23, 2009 3:42 am Post subject:
Before I do anything, I'm going to have to up the hard drive size in my computer, so I can run XP in bootcamp. My PC's graphics capability simply isn't fast enough to cope with the assembly I made, but my Mac is (spin on that unkle k! ).
I will be going for the euro/frac design, but I will try and modify it to 7" for you eric- because I said I would.
When you say 4 unit modules, do you mean 4U high (7") or 4 panels wide?
Tom _________________ ACHTUNG!
seraph
Editor
Audio files: 33
Posted: Mon Feb 23, 2009 3:54 am Post subject:
| v-un-v wrote: | spin on that unkle k! |
Tom, go on  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
macumbista
macumbista
Posted: Thu Jul 09, 2009 2:43 am Post subject:
Second tip: if you want to leave your cables plugged in when you close the case, make sure you leave enough space at the point where the upper or lower boats swing over the edges of the middle boat. Looking at photos online, the real 200e doesn't look like you could leave the cables plugged when it closes. Can anybody confirm or deny that?
D. _________________ Esoteric drones and nonlinear distortion
macumbista.net |
TekniK
Posted: Thu Jul 09, 2009 6:51 am Post subject:
| macumbista wrote: | Wish me luck!
D. |
Can't go wrong imo,it looks already very good |
ericcoleridge
Posted: Thu Jul 09, 2009 11:05 am Post subject:
| This is really great; what are planning to put in the boats? |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Thu Jul 09, 2009 11:41 am Post subject:
You do have to unpatch the 200e to fold it up. Given that bananas can stack arbitrarily high, I'm not sure that a folding case could be designed that would allow for closing, while patched, on a banana system. _________________ Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job) |
macumbista
Posted: Thu Jul 09, 2009 12:04 pm Post subject:
| Quote: | | This is really great; what are planning to put in the boats? |
Main items still under construction, but here is the master plan:
* 4 x dual Thomas Henry XR-VCOs set up to imitate the Buchla 259 Programmable Complex Waveform Generator (prepatched AM, FM & PWM)(under development, one prototype 3/4 finished)
* Quad joystick 4 x 4 CV matrix mixer (drawing up schemos now)
* 4 channel quadrophonic spatializer (drawing up schemos now)
* Dual Polyvoks VCF (boards finished, about to get paneled)
* Dual Steiner VCF (boards finished, about to get paneled)
* CGS Waver multiplier (finished)
* CGS Super Psycho Modulation Source (finished)
* Maybe some kind of sequencer (have boards for Klee)
* Random LFOs (noise/sample&hold driven)(drawing up schemos now)
* Tellun Neural Agonizer (have boards/parts)
* Tellun Doomsday Machine (have boards/parts)
* More distortions/waveshapers?
* Output panel (banana to minijack & 1/4" jack converters)
So I guess this is where I'll need the luck!!!!!
macumbista.net |
macumbista
Posted: Fri Jul 10, 2009 10:50 am Post subject:
OK, I shaved a bit off the angle of the side pieces, but I'm still not happy. Initially I figured it would be ~45 degrees, but then the top boat still stands pretty much straight up, when it should lean back.
I guess any owners of a real 200e probably won't be reading this thread, but if they are, could you please measure the angle of the top and bottom boats respective to the middle one? This part is driving me crazy!
You can see in the pics that it stands very straight up. That has a couple drawbacks:
--the legs in the back have to be longer
--the middle boat isn't entirely stable. By pushing on it's lower edge it tilts...although I did finally see the flanges for the locking bolts on those little metal tabs at the rear of the middle boat: http://www.synthi.se/bcab/b4.jpg.
The wood I used it a bit thin for that, I had hoped proper balance would do the trick Actually considering a rubber foot in the back to keep it from tilting when open...
Hmmmmmm........
D.
| Description: |
| Buchla 200e clone case rear view |
| Filesize: |
55.31 KB |
| Viewed: |
399 Time(s) |
| Description: |
| Buchla 200e clone case closed view |
| Filesize: |
59.14 KB |
| Viewed: |
404 Time(s) |
macumbista.net Last edited by macumbista on Fri Jul 10, 2009 11:02 am; edited 1 time in total |
cbm
Posted: Fri Jul 10, 2009 10:55 am Post subject:
I don't have any easy way to measure the angle. Would an end-on picture help you? _________________ Chris Muir
macumbista
Posted: Fri Jul 10, 2009 11:03 am Post subject:
Hi Chris,
sure, if it's directly end-on then I could work it out. Thanks!
D.
...wondering why a real Buchla owner would be checking up on people trying to fake it...  _________________ Esoteric drones and nonlinear distortion
macumbista.net |
ericcoleridge
Posted: Fri Jul 10, 2009 11:07 am Post subject:
| Not sure if you're trying to make this exactly like your model, but are your boats the same depth as Buchla? Can that also have some effect on angle, weight and balance? I've read that the middle boat on these cabinets is deeper than the top and bottom to accommodate the PS. |
macumbista
Posted: Fri Jul 10, 2009 11:18 am Post subject:
| Quote: | | Not sure if you're trying to make this exactly like your model, but are your boats the same depth as Buchla? Can that also have some effect on angle, weight and balance? I've read that the middle boat on these cabinets is deeper than the top and bottom to accommodate the PS. |
Actually I don't know the original dimensions of the boats, but if you look here
http://www.synthi.se/bcab/b2.jpg
you'll see that there isn't much PS to accommodate!
No, the angle isn't "right" because I didn't think it through enough when I was drawing it up. I could have easily made it sharper. Of course, the case still functions just fine and I could easily use it just as it is. Perfect is the enemy of just-good-enough.
macumbista.net |
cbm
Posted: Fri Jul 10, 2009 12:21 pm Post subject:
| macumbista wrote: | | sure, if it's directly end-on then I could work it out. |
Hopefully this is end-on enough:
| Quote: | | ...wondering why a real Buchla owner would be checking up on people trying to fake it... |
You do a search for Buchla, and you never know what you're going to find
- C _________________ Chris Muir
cbm
Posted: Fri Jul 10, 2009 12:25 pm Post subject:
| macumbista wrote: | | Quote: | | Not sure if you're trying to make this exactly like your model, but are your boats the same depth as Buchla? Can that also have some effect on angle, weight and balance? I've read that the middle boat on these cabinets is deeper than the top and bottom to accommodate the PS. |
you'll see that there isn't much PS to accommodate! |
That's because it's hidden under the power distribution boat in the middle cabinet. Buchla uses a couple models of Cincon switching supply mounted to the underside of the power distribution board, using the case as a heat sink. Very slick system, IMO.
The middle boat is about 3/4" deeper to accommodate this.
ericcoleridge
Posted: Fri Jul 10, 2009 2:02 pm Post subject:
| cbm wrote: |
Chris,
As long as we're on the subject , I'm guessing the middle boat is 3". Is that about right? |
macumbista
Posted: Fri Jul 10, 2009 5:08 pm Post subject:
| Quote: | | Hopefully this is end-on enough |
That's great, I'll see what I can get out of it. That's one stacked system, my friend! Can't even count the cables there...
If I could request one more photo, it would be a close-up of the set screws on the back side, that you mentioned lock it into place (where I thought maybe gravity would do the job by itself).
Also....are those audio jacks coming out of the backside of the top boat?
Thanks much + best!
macumbista.net |
macumbista
Posted: Fri Jul 10, 2009 5:28 pm Post subject:
And my other question is...with all those cables, and the fact that you have to unplug them before closing the case, what do you do when you have to pack it up for a gig? _________________ Esoteric drones and nonlinear distortion
macumbista.net |
cbm
Posted: Fri Jul 10, 2009 6:05 pm Post subject:
| ericcoleridge wrote: | As long as we're on the subject , I'm guessing the middle boat is 3". Is that about right? |
It's about right, for some values of about. The depth measured from the top of the mounting rail to the inside back of the boat is 3.2165" according to my calipers.
The top and bottom boat are 2.575", measured the same way. _________________ Chris Muir
