today> Twyndyllyngs Chez Mosc
Thomas Henry's SN76477 Super Controller Module
Page 8 of 10 [232 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10 Next
Is there an interest in Super Controller PCBs?
Yes, by all means.
95%
 95%  [ 23 ]
No, it just doesn't cut the mustard, i think.
0%
 0%  [ 0 ]
I don't know. I mean, i... er...
4%
 4%  [ 1 ]
Total Votes : 24
PostPosted: Sat Sep 22, 2007 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
SOLD OUT
Wink
oh, and welcome
Tronato
PostPosted: Sat Sep 22, 2007 7:04 am    Post subject: SN76477 Reply with quote  Mark this post and the followings unread
Hello again!
Sorry to hear the PC boards are sold out.
Will there be a new batch or that's it?
Does anybody have an extra board?
Thanks in advance!
Tro
julianw
PostPosted: Sun Sep 23, 2007 4:07 am    Post subject:   Reply with quote  Mark this post and the followings unread
Darn, Sad Knew I should of ordered some of these, got caught up in some other projects and completely forgot - If you plan another run, I'd definately take two, I don't mind paying upfront either.
Julian
janvanvolt
PostPosted: Mon Dec 03, 2007 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
@fonik:
i finished my MOTM version of the 76477, however i am curious how the INITIAL and SWEEP should work on that module.
i tried to adjust T2 according to documentation, but i just don't see a change on the oscilloscope. cabling is correct now (fixed some wrong wires) and should be working IMHO.
All of the rest is working.
Thanks for the great module !
Photos here: http://www.flickr.com/photos/jczmok/sets/72157603370942917/
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
serenechaos
PostPosted: Mon Dec 03, 2007 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
SWEET!
Where'd you get the panel?
(I need a MOTM format one, that looks real nice).
Robert Smile
PostPosted: Tue Dec 04, 2007 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
hi jan,
congrats on your nice module. you did a neat job as usual!
the SWEEP switch (S3) selects the CV source for the noise clock: internal LFO or external CV.
with the INITIAL control you set the base noise clock freq.
T2 adjusts the noise clock offset. for setting up the noise clock CV you have to select external sweep. then follow the instructions. yo won't need an oscilloscope, just your ears (sound yes/no?).
if there is no change in noise sound at all, there is good news and bad news (as usual). the bad news: there must be something wrong. the good news is: both the circuit and the PCB is proven to be correct so you will get it working in the end.
when S3 set to internal, does the noise sound change following the internal LFO? it should do so, independent from the noise clock CV circuitry around U7 5-7.
philpeery
PostPosted: Thu Apr 10, 2008 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Unit-sound! Excellent looking MOTM panel! I am going to be working on a few of my FONIK modules over the weekend, and was wondering if you would be willing to post details on your panel design. Did you use Front Panel Designer for it? Looks sweet!
Phil
janvanvolt
PostPosted: Fri Apr 11, 2008 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Phil
yes. I can make the FPD file available. I'll update my diy pages to have the files listed as well.
synthmonger
PostPosted: Mon Aug 18, 2008 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't you add a simple mod of voltage control over the noise filter by connecting an NPN as a current sink to pin 5? Or expo control?
Tronato
PostPosted: Mon Sep 15, 2008 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Is there anyone of you fine gentlemen interested in a brand new unpopulated PCB of the Supercontroller?
PM me please....
TRON
EDIT!
SOLD less than 2 minutes after I posted this!
andrewF
PostPosted: Sat Oct 18, 2008 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Turned this module on today for the 1st time - works perfectly
Well done Thomas for the design and Fonik for the PCB.
The noise is really different and useful, flicking thru the range switch really changes the waveform.
S&H...I have never appreciated S&H before but my opinion has now been inverted Embarassed
This is a super module!!
Appliancide*
PostPosted: Sat Oct 25, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
If anyone has a pcb that they are willing to part with, I'd be happy to take it off your hands.
camelneck
PostPosted: Fri Nov 14, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The portion of the schematic involving the Noise Sweep is very perplexing to me. I have no doubt that this circuit works, but I'm having trouble understanding how it works.
Some time ago, I experimented with this IC. Although I didn't use a CV to sweep the noise clock, my circuit did have a pot which controlled the frequency of the internal noise clock, and this circuit was connected to pin 3 (and I think pin 4 also).
On Fonik's schematic, the Ext CV input, which is used to sweep the noise clock, is applied to pin 16 (Ext VCO Control). How can this pin be used to sweep the noise clock when it is for Ext VCO Control? Why not use pin 3? (Even the SN76477 datasheet recommends pin 3 for this purpose.)
Can somebody please explain how it is possible to sweep the noise clock using pin 16?
Thanks,
David
PostPosted: Fri Nov 14, 2008 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's just because thomas henry used the sn76477 VCO to clock the noise Shocked he mentioned it would give way better results (therefore this module does not provide a audio VCO as the SN Voice does).
Tronato
PostPosted: Fri Nov 14, 2008 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Is there a document somewhere explaining exactly what it is that this module does or can do?
TRON
PostPosted: Sun Nov 16, 2008 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
just see 1st post in this thread. technical details of how THs circuit actually works can be found in the polyphony article and in the book.
intellijel
PostPosted: Thu Feb 26, 2009 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
I just wanted to clarify which controls reset/restart the LFO?
e.g.
With the delay trig in, after the delay time does the LFO always start at the beginning of it's cycle?
When you assert a gate signal, does the LFO start it's cycle? etc..
thanks!
PostPosted: Thu Feb 26, 2009 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
intellijel wrote:
e.g.
yes.
yes.
you are absolutely right, and it didn' occure to me until this moment: we have a syncable LFO here! Shocked
concerning the gate/delay function: these are alternate modes, not simultanious.
intellijel
PostPosted: Thu Feb 26, 2009 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Not enough designs take into account the need for syncabe/resettable parameters so that we can do rhtyhmic stuff Smile
While I have your attention, I couldn't see anything in the notes about 12V (eurorack) operation. Do I need to change any resistor values?
PostPosted: Fri Feb 27, 2009 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
if anyone build his super controller for 12V operation he might chime in here.
maybe you won't have to change anything. most critical parts are referenced to the onboard 5V anyway. however, you could adjust R55 and R56 (schematic page 3, page 6 of documentation). lower their values to widen the range of the potentiometers if needed.
aerogramma
PostPosted: Wed Mar 04, 2009 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
just wanted to express my appreciation here for the excellent job done, once again, by mr. fonik
excellent project, excellent comms, excellent delivery speed, first quality PCB and docs
just shows things CAN be done differently!
thanks
Wink
aero
PostPosted: Wed Mar 04, 2009 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for the kind words, aero,
however, i have to say one word about quality. these boards are just a reorder of the 1st run from expressPCB. it is leadfree ROHS and i strongly recommend to store it not too long, or if you want to put it on the shelf for a longer time, store it in a small bag with silicon if possible, in order to keep it dry as possible.
i you one day find the pads have become dull just sand it carefully.
that's part of the ROHS-deal?!
aerogramma
PostPosted: Wed Mar 04, 2009 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
no worries it wont be on the shelf for long Wink
Luka
PostPosted: Sun Mar 08, 2009 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey matthias
i'm just designing my panel at the moment
im wondering if you can confirm all the normalised connections in the panel
since im am using bananas i need to add a switch for each
so far i have noted
+5v > Gate in
noise out > s&h in
also your panel suggests to me that all of the pots are reversible attenuators/control. is this correct?
i have also noticed you do not have the hold function on the lfo any more?
was there a reason for removing this?
and lastly is the much difference between the gate and square output on the lfo?
here is my current design
would appretiate any hints on functional errors
problemchild
melbourne australia
PostPosted: Mon Mar 09, 2009 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
nice panel, luka!
so far i have noted
+5v > Gate in
noise out > s&h in
that's it.
and you do not have to normal the s&h in to the noise. you could patch it with your banana anyways. Wink
no. it is my old affliction: the +/- means nothing but more/less for me. not related to any actual measurements/voltages.
i just don't need/want it. Very Happy
yes, it is. the gate and trigger is uni-polar, above GND only. the triangel and square waves are centered around GND.
furthermore the phase of the gate is shifted by 180 degrees in relation to the square. i don't know why thomas designed it this way. any ideas anybody?
concerning the LEDs: you show one LED for the tri/square and one for the gate/trigger outputs. it is actually a good idea to have a separate LED for the gate out at least (see above: phase, now that we talked about it i will perhaps add it to my module in future). the PCB/design does not provide this, though. there is one LED for the tri/square out and one for the current LFO status (on/off).
