Adding GATE to Utility LFO
Page 1 of 1 [4 Posts]
whomper
PostPosted: Sun Jan 25, 2009 1:04 pm    Post subject: Adding GATE to Utility LFO Reply with quote  Mark this post and the followings unread
Is there any simple way to add a gate to CGS's Utility LFO in order to re-trigger it?
Erez Yaary
Buy my CDs at http://www.mellowjet.de
whomper
PostPosted: Tue Feb 10, 2009 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, saw no response.... Sad
Isn't there any way to add, maybe a small circuit, a trigger/gate input to retrigger the LFO as well as voltage control it?
Erez Yaary
slacker
PostPosted: Tue Feb 10, 2009 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you briefly short out the 47n cap in the integrator that will reset the LFO.
You could use a FET in parallel with the cap in the same way as in the CGS VCO, then you just need trigger/pulse generator to control it.
whomper
PostPosted: Tue Mar 03, 2009 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just found some time to try this idea out. Would I need to build a small circuit in the lines of the 2 yellow circles in the attached diagram or just connect the FET and connect the in trigger to it?
 Filesize:  167.75 KB
 Viewed:  344 Time(s)
Erez Yaary
