Bending Devices with Crystal Clocks
Page 1 of 1 [5 Posts]
scabrabbit
PostPosted: Fri Mar 27, 2009 1:25 pm    Post subject: Bending Devices with Crystal Clocks Reply with quote  Mark this post and the followings unread
Hey,
I'm relatively new to circuit bending and I'm not sure how to go about messing with (over or under clocking) crystal clocks in things like Yamaha keyboards.
Do you remove and replace them with something? Is there a standard way to go about this?
Thanks
stolenfat
PostPosted: Sat Mar 28, 2009 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
well an easy thing to do is find another crystal osc and set it up so you can use a switch to switch between the original clock and the new clock.
Maybe get more crystals and a roto switch
scabrabbit
PostPosted: Sat Mar 28, 2009 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Instead of having multiple crystals, is there some sort of chip that acts like a voltage controlled oscillator that I could just hook up to a pot that would do the same thing?
Sam_Zen
PostPosted: Sun Mar 29, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, there is. The 74LS624. You can find the circuit description here
scabrabbit
PostPosted: Sun Mar 29, 2009 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Exactly what I was looking for.
