Filament
Posted: Wed Feb 11, 2009 7:01 am Post subject:
Resonator, delay, reverb or comb filter? Subject description: Looking for metallic/elastic/ring/resonation effect for drums |
I'm looking for a vst to make my drums sound like they resonate. Autechre have the effect i'm looking for on quite a lot of their music LP5 EP7 etc. Nord modular had something called a string oscillator that had a damper which you could feed drums through which gave a good replication of what I need but I no longer have my nord modular. The comb filter on the nord wave was also close to what I am after.
I am looking for a vst effect that will make my drums stand out like they have bounce/ring/metallic/elastic/resonation.
What do autechre do for this effect? Is it a short delay? Is it some sort of resonator? or is it a comb filter, or something else?
Thanks |
Posted: Wed Feb 11, 2009 9:13 am Post subject:
There is something in Ableton Live that's called resonator (I think). Googling around a bit I found that people seems to be using it for drums. I'm not by my computer at the moment so I can't check it out.
I'm guessing you can built this sort of thing using delays with feedback, if you have that kind of toolbox at hand.
Edit: if you haven't checked out Live you can download a trial version where you can have a look.
Filament
Posted: Thu Feb 12, 2009 2:10 am Post subject:
| Antimon wrote: | There is something in Ableton Live that's called resonator (I think). Googling around a bit I found that people seems to be using it for drums. I'm not by my computer at the moment so I can't check it out.
/Stefan |
I tried Live's Resonator, but its too over the top. It doesn't give what I am looking for. I'm thinking it is more like a comb filter effect that i'm looking for maybe.
I am particularly looking for exactly the same as what autechre have used on a lot of their drums. It gives a rubbery kind of punch to the percussion sounds they use. |
bencodec
Posted: Mon Apr 06, 2009 2:18 pm Post subject:
| well autechre use the elektron machinedrum and monomachine quite a lot like and both of these boxes have a nice delay line built in that can quite easily be used as a comb filter. I'd start there with a simple comb filter and see where that gets you. |
