how to substitute CA3080 with LM13700
Page 1 of 1 [6 Posts]
creekree
PostPosted: Fri Apr 18, 2008 8:10 am    Post subject: how to substitute CA3080 with LM13700 Reply with quote  Mark this post and the followings unread
hi all,
i am working on a double thomas henry vco-1.
i want to use a single LM13700 instead of two CA3080, but i am a little unsure about what to do with the pins of the LM13700 that the CA3080 does not have:
buffer input, buffer output, diode bias.
am i supposed to connect them to ground of should i leave them floating? (i suspect the latter is not the case)
also, is "input (+)" (pin 3 / 14) the non-inverting or the inverting input on the LM13700?
Clack
PostPosted: Fri Apr 18, 2008 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
you can leave the diode bias unconnected ive seen it done in many circuits as for the buffers , In the datasheet it mentions grounding the input and leaving the output unconnected when it specifies the electrical characteristics.
yup
non-inverting = +
Clacktronics.co.uk
creekree
PostPosted: Sun Apr 20, 2008 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the answer Mr Clack, this info helps me a lot.
Luka
PostPosted: Sat Apr 18, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
im looking to do the opposite of creekee here
i have a stockpile of 3080s and wish to convert a simple 13700 design to use 3080s. Will adding 2 matched 4148s be a reasonable substitute for the diode bias input on the 13700?
problemchild
melbourne australia
CJ Miller
PostPosted: Sat Apr 18, 2009 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another option is to just use the 13600 instead and not worry about the diodes at all. Incidentally, National lists the LM13x00 as obselete, but the Japanese NJM versions are fine also. I bought 100x NJM13600 from Mouser for a good price.
andrewF
PostPosted: Sun Apr 19, 2009 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a good topic, especially as 3080s are now more expensive and rarer than 13700s.
Had a look around, found this page -
http://www.musicianshotline.com/archive/monthly/pedal_power/0605.htm
and
http://machines.hyperreal.org/categories/DIY/chips/3080.vs.13700.txt
