attaching PCB to module panel
Page 1 of 1 [8 Posts]
volumetrik
PostPosted: Fri May 01, 2009 9:29 am    Post subject: attaching PCB to module panel Reply with quote  Mark this post and the followings unread
Hi there
I'm planning to build a modular synth with the MFOS modules, some of the things I'm unsure about is, how do you attach a PCB board to a module panel , I would like to do it like in this pic, does anyone know where to get the L-brackets like these?
thanks
Wizard Mike
PostPosted: Fri May 01, 2009 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd just make my own honestly. A good starting point for dimensions can be found here, or you could just order them from Mr. Wilson's site:
http://www.musicfromouterspace.com/analogsynth/UNIVERSALPANEL2007/UNIVERSALPANEL2007.php
skylab76
PostPosted: Fri May 01, 2009 7:36 pm    Post subject: Re: attaching PCB to module panel Reply with quote  Mark this post and the followings unread
I use 1/2"x3/4"x3' aluminum angle from Home Depot. I cut off a 1/2" or 3/4" piece(using a hacksaw) depending on the PCB/Panel. Then drill holes in it. Even the smallest L-brackets are usually too thick and don't fit my PCB/panel configuration just right.
RF
Audio files: 28
PostPosted: Fri May 01, 2009 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I build my own also. I use thin scrap aluminium and drill a hole on one side for the pot shaft to go through, and drill a hold for the PCB mounting holes on the other end and bend them.
bruce
www.sdiy.org/rfeng
alieneYe
PostPosted: Mon May 04, 2009 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
here are some 4-40 right angle pcb mounts
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=1581530&catalogId=10001&freeText=1581530&storeId=10001&search_type=jameco&ddkey=http:StoreCatalogDrillDownView
PostPosted: Wed May 06, 2009 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
i make them myself from 0.5mm steel sheets. i cut them with tinsnips, drill them and finally fold/bend them using a vice and a hammer...
Audio files: 161
PostPosted: Thu May 07, 2009 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, joiners/ carpenters at work usually have loads of these kitchen base unit wall fixings left over, they are 20mm X 20mm. i used loads on my MFOS modular
David
 Filesize:  35.38 KB
 Viewed:  181 Time(s)
Audio files: 161
PostPosted: Thu May 07, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah i see, no bolts on the panel surface , yes , mines rough and ready Laughing
