ilmolto
Joined: Apr 29, 2009 Posts: 26 Location: Melbourne, Australia
Posted: Wed May 06, 2009 6:33 am Post subject:
Wout you're a genius. It was indeed because I was using my Nord Lead 2X via MIDI. When I use the Nord Lead 2X without MIDI, I can disable LFO 2.
Awesome. I've learnt a lot so far on this forum. All I need now is to fix the damn CC 11 issue and somehow get a NordGenerator for Mac. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed May 06, 2009 8:43 am Post subject:
| ilmolto wrote: | | Wout you're a genius. | No, I'm not! W.T. showed us the solution to the not functional buttons. I just gave you the hint. It's the Internet community which is the genius
Well, now I start to think about it...
W.T. is Dutch too, so...  | Quote: | | ... Awesome. I've learnt a lot so far on this forum. All I need now is to fix the damn CC 11 issue and somehow get a NordGenerator for Mac. | All in its time, in its time...
Anyway, the conclusion could be there aren't that much differences between the '2' and the '2X' or at least they are both typical Nord related sensitive to Midi
Wout |
Oli
Joined: May 21, 2008 Posts: 250 Location: i think before i ambient
Posted: Wed May 06, 2009 12:43 pm Post subject:
Hm, special button functions, and hidden filters. Sounds like maybe there are some Easter eggs? Next time I do some patching, I think I will have to read on the tips and tricks sections. _________________ Good good study, day day up! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed May 06, 2009 1:08 pm Post subject:
May I be of some advice?
If you are interested in things like 'easter eggs', next time you are in front of the synth take a good look and ask yourself: "What does that thing do?" and "What can I do with it?" Surely there are some features you never use. I was wondering why the LFO's were able to produce those higher frequencies and what can I do with it. Why is there a Pulse in LFO1? What can I do with it? (Reading the values in the LCD screen after [Shift+LFO1-wave form] And setting it to the same Rate as the Arpeggiator it doubles the speed and it is nice to set the Amount to 73, which result in a switching lower and higher octave of the Osc, very useful if this is directed to Osc2 only)
Well, don't forget to read the sticky thread about the differences between the NordLeads in general, in which the high speed LFO plays an important role.
Go and look for boundaries and extremities. Stay away from the slightly detuned pulses, Pulse Width controlled by a slow LFO1 and a lot of Unison. Sound nice, but also boring
Drown yourself in the Arpeggiator and not to forget: Percussion mode!!!
See you in September
Wout |
Joined: Apr 24, 2009 Posts: 2525 Location: Bristol UK
Audio files: 512
Posted: Wed May 06, 2009 6:09 pm Post subject:
I had a similar problem as in the OP with my Nord Lead 2 - in my case it was the amp envelope sustain knob sending out data...
Also, since the Lead 1 I have never been able to get the full range of the pitch bend stick over MIDI - internally it worked fine, but over MIDI it fell a little short of the full range, either up or down, I can't remember now.
I really miss the stick, regardless of the problems.
Anyway, in my case the knob was faulty, so it was a hardware problem. The fact that the expression input sends out data is beyond me, I'm afraid. _________________ Muied Lumens Sub Forum
Bandcamp |
Oli
Posted: Sun May 10, 2009 9:37 am Post subject:
| Oli wrote: | | ...I'll send off a support request for you then. I'll need your serial number and OS version when I send the request... |
Hi ilmolto,
I haven't sent the support request yet. Could you post here, or PM me the details above. Im not sure if it's necessary, but I think Clavia like to have these details posted with the support request.
Cheers.
P.S. I'm sending you a PM as well _________________ Good good study, day day up! |
Oli
Posted: Mon May 18, 2009 8:10 am Post subject:
Thought I'd post back with an update. I got a reply from Nick Mitchel of The Electric Factory (ELFA) in Melbourne very soon after posting the support request.
ELFA are the Australian distributors for much electronic musical equipment in Australia, and presumably for Clavia. Nick was also CC'd on my previous support request to Clavia, regarding electro-music hosting depracated G2x OS versions, so I assume he is party to all contact between Australian customers and Clavia.
Nick was interested to know which service center had examined the synth. I have only just forwarded this message on to ilmolto (apologies for the delay). Hopefully Nick can shed some light on the matter.
| Wout Blommers wrote: | May I be of some advice?
If you are interested in things like 'easter eggs', next time you are in front of the synth take a good look and ask yourself: "What does that thing do?" and "What can I do with it?"... |
Yeah, thanks for the tip. I do indeed think along these lines, as to what can be achieved with the signal processing options available. I have some background in signal processing for communications systems, and do like to consider the extents of what is possible. I'm not against simple, and musically useful, sweet, sonorous timbres though.
edit - Forgot to mention; ilmolto has said that the issue appears to have subsided since he opened the synth, though he is not confident that anything has really been addressed. _________________ Good good study, day day up! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon May 18, 2009 9:36 am Post subject:
| Oli wrote: | | ... ELFA are the Australian distributors for much electronic musical equipment in Australia, and presumably for Clavia. ... | They surely are as Clavia site tells us:
Electric Factory Pty Ltd
188 Plenty Road
Preston Victoria 3072
Australia
Phone: +61 3 9474 1000
Email <mailto>
When you visit http://www.clavia.se/main.asp and select support your mail will be send directly to the distributor, but when using feedback your mail will be dropped into the mailbox of the Stockholm headquarters.
Wout |
jswff
Posted: Wed Sep 13, 2023 7:08 pm Post subject:
Nord Stage EX Compact Subject description: Same Issue — Different Keyboard |
Hey Guys!
I just stumbled across this page when I was looking for a solution for the same issue in my Nord Stage EX Compact.
A few differences:
— I'm using the 5-pin MIDI to connect to Mainstage via a Scarlett USB interface.
— The Nord is randomly outputting expression value at 0 rather than the 36 and 37.
— Lastly, I opened up the Nord and the Mod Wheel was completely disconnected. Thought that might be the reason why, haven't had the chance to check it again though. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Sep 14, 2023 9:01 am Post subject:
The Nord is a computer. When starting up it it will search all its content of the hardware. Surely in your case it can't find the wheel and it will stay in 'search mode'. I assume your Nord is second hand and there were already troubles with the Wheel. Disconnecting it could give a result the keys are working, so there is sound. But the North is still searching I don't own a Stage, but I think you can assign the Wheel function to a pedal or something.
If connecting the wheel doesn't work contact the distributor in your part of the world.
Wout |
