Consul
Joined: May 05, 2007 Posts: 59 Location: Port Huron, Michigan, USA
Posted: Thu May 14, 2009 11:10 am Post subject:
Theory of operation info? Subject description: Warning: Hardcore math and physics nerd! :-) |
I was just wondering if anyone had ever discussed or written about the theory behind the hows and whys of the concepts behind the Lunettas. I just discovered these (and re-discovered electro-music.com) thanks to the Make Blog. I am, however, a big-time physics and math nerd, going for a degree in physics, and am most certainly not afraid of the occasional differential equation or discussion of Kirchoff's Law or other such things.
Eventually, though, I do want to get some parts and start playing around. Until my workspace and money issues are worked out, though, I thought I'd try to learn as much as I can.
Thanks for the help, and for the great forum, and especially for these simple synth ideas. _________________ Darren Landrum
"Never be afraid to try something new. Remember that a lone amateur built the Ark. A large group of professionals built the Titanic." - Dave Barry |
RF
Audio files: 28
Posted: Thu May 14, 2009 12:44 pm Post subject:
Hi Darren -
Nice to have you here!
Interesting - I just read a post about Lunetta's where the author was saying essentially "I need to think less and build more" Now here you are bucking that sentiment.
I don't know of anyone who has written much on the math/physics of these things. I've been searching out everything I can find on them and have only seen a few references from Stan Lunetta interviews on the math - and those were pretty sketchy.
I look forward to seeing what you come up with - Have at it!
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Consul
Posted: Thu May 14, 2009 1:51 pm Post subject:
Well, really, I was just hoping for an explanation on how these ideas work the way they do. I've never dove (dived? diven?) into digital logic electronics theory in any great depth, other than what I need to know for programming computers (which is really different knowledge).
But like it's said a lot around here, 4000-series chips are cheap as, well, chips, and it would probably easy enough for me to start playing around and figure a few things out. Thanks for the reply. _________________ Darren Landrum
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
Posted: Thu May 14, 2009 3:24 pm Post subject:
If someone wants to write articles here are some starting points.
My understanding is spotty at best, but I'll share what I can. If I type things you already know then skip ahead. Also correct me if I'm wrong.
Digital logic is basically:
- High and Low
- 1 and 0
- Full Voltage and No Voltage
? Rail to Rail
A Squarewave is an inherently digital function then?
A squarewave can be a clock, providing a timing reference.
A squarewave can be a musical tone, with the pitch determined by it's frequency.
A 40106 IC can make 6 squarewave oscillators with some added components. Others can too, but 40106 is very popular because it's easy to use.
So the different CMOS ICs each have a function. You input something and something else gets spit out the other end. There might be more that one input and more than one output. The outputs can either change/modulate) the pitch(frequency) of an oscillator or the same output can be used to clock another IC.
A Lunetta machine, then, is a way to study how these different functions can interact.
Some ICs just count up to a certain number. The 4017 IC counts up to ten over and over again. The input is a clock, just a squarewave of a tempo that you choose, and there are ten outputs (0-9). So every time a clock ticks it'll step through each of the outputs and make it go High. People build sequencers with this.
Some of them just add two signals together, some divide a signal by a certain amount(4040 is my favorite), some act as switches depending on whether the input is high or low. It can get really complex.
In a Stanley Lunetta Interview posted on this forum he described using the counter as the frequency base for a note's pitch.
People have also converted the high/low outputs into a variable stepped voltage stream that can interact with a voltage controlled oscillator.
It's a node-based approach to building a complex system. It's a fantastic educational tool because it's tactile, it's visual, you can get tangible results and a great deal of understanding in a short amount of time. It's fun because it's both simple and challenging and can make super cool sounds.
It's like Lego...Really awesome Lego... |
RF
Audio files: 28
Posted: Thu May 14, 2009 3:40 pm Post subject:
I misunderstood, Consul ;0
Drofset - nice job on the basics.
Yea, I really encourage you to build a few of these things. It's kind of hard to wrap your head around parts of it (at least it was for me) until you start using these chips in this way.
Ask questions and we'll all do the best we can answering them, though.
Posted: Thu May 14, 2009 4:38 pm Post subject:
It aint rocket science, so I don't know if you'll find any complicated maths or physics lurking in these circuits. Ironically, rocket science is not as complicated as a lot of other stuff which has been developed since. Rocket science hasn't really changed very much over the last 40 years, (basically because we stopped funding anything interesting which used rockets! )
Anyway,
Certain input states lead to certain output states with respect to time.
I think the real trick is to know the functions of as many chips as possible. This is where the "just get building and see where it leads you" philosophy pays off. There are some chips which can do things which you may never have thought of until you start playing around with them. Like many systems which are made up of simple building blocks, complex results are just a matter of time.
BTW, just because these are "digital" circuits, don't think they can't produce some very complex organic outputs. I've recently discovered this while playing with my ReAnimator circuit. The main stumbling point is how many chips are you willing to employ!
http://electro-music.com/forum/topic-33381.html |
Consul
Posted: Thu May 14, 2009 5:35 pm Post subject:
Thank you all very much for the information. I'm beginning to see that Kirchoff and differential equations, both essentially analog domain ideas, might be the wrong approach here. Putting together Lunetta Systems (I'm sure he'd love that term ) is definitely much more an exercise in logic and puzzle solving. And the first important puzzle is having an understanding of what each piece can do, as Uncle Krunkus has stated.
It starts with square waves, but it's easy enough to see how to get to pulse waves from there. PWM could be next, then.
I like thinking in terms of nodes in a directed graph, since that's something my mind can already grasp. Linear algebra was a favorite subject of mine. That's probably the approach to take with this. _________________ Darren Landrum
Posted: Thu May 14, 2009 6:07 pm Post subject:
| Consul wrote: | I like thinking in terms of nodes in a directed graph, since that's something my mind can already grasp. Linear algebra was a favorite subject of mine. That's probably the approach to take with this. |
I'm sure graphs are abstract enough to wrap the problems up here ... but in this case key words for theory would be Boolean algebra, Mealy and Moore state machines, Karnaugh diagrams, stuff like that.
But then again, it's also fun when the machines are made to perform out of specs, by power starvation or by using the resistance of the skin to make bad contacts & what not ... theory will be in your way there likely.
edit : and Quine–McCluskey of course, for optimizing logic circuits. _________________ Jan
amplex
Joined: May 26, 2008 Posts: 64 Location: sacramento, ca
Audio files: 6
Posted: Thu May 14, 2009 7:36 pm Post subject:
droffset: nice post!! really great explanations of the lunetta basics.
Blue hell: That wouldnt be the same Moore as Gordon Moore cofounder of intel and Moores law of exponentially accelerating IC transistor count would it? (kurzweil reader here =D)
mathmatically describing whats happening in a lunetta (or any other piece of complex electronic equipment) seems like more than a headache to me, even broken into stages. i applaud your attempt to explore the base mathematical/physical functions of these lunettas, if you figure out any mathmatically relationships that're easily explainable plz post it =]
if you are only interested in the workings of these lunettas, im sure they are simulatable in some sort of computer software, not really sure about circuit designing software so far, but there is probably something perfect for your needs out there already, and possibly free.. anyone? Would ChucK labs work? I know that you can build basic synths and it is basically an audio programming language (Csound comes to mind), and there is even a GUI for it for Mac. I've never really used either of them though, so i'm basically worthless in this thread =]] |
droffset
Posted: Fri May 15, 2009 3:23 am Post subject:
I hope you found that useful, hehe.
There's so much info on this forum that a really good introductory tutorial document could be put together, sort of a text, starting with general concepts and working through the first 3-4 blocks to build for your own Lunetta. After that you have enough knowledge to find your own path.
If you wanted to get into really deep theory you should look at some of this stuff through an oscilliscope and analyze the relationship dynamics between frequency and pitch, and how at really high speeds you can make sounds that seem like they're going through some crazy filter when it's not.
Or you can just build it and have fun.  |
Posted: Fri May 15, 2009 4:23 am Post subject:
| amplex wrote: | | Blue hell: That wouldnt be the same Moore as Gordon Moore cofounder of intel and Moores law of exponentially accelerating IC transistor count would it? |
Had to look it up, but no, the state machine guy is Edward F. Moore. _________________ Jan
Inventor
Audio files: 267
Posted: Fri May 15, 2009 4:41 am Post subject:
| Blue Hell wrote: | I'm sure graphs are abstract enough to wrap the problems up here ... but in this case key words for theory would be Boolean algebra, Mealy and Moore state machines, Karnaugh diagrams, stuff like that.
edit : and Quine–McCluskey of course, for optimizing logic circuits. |
Sigh, I Learned lots of that kind of stuff in college but that was 20 years ago and now it's all just a faded memory... _________________ "Let's make noise for peace." - Kijjaz |
Posted: Fri May 15, 2009 4:44 am Post subject:
| Inventor wrote: |
Sigh, I Learned lots of that kind of stuff in college but that was 20 years ago and now it's all just a faded memory... |
For me it faded too apparently ... not realizing that state machines usually are pictured as graphs (and I draw them like daily ...) _________________ Jan
Inventor
Audio files: 267
Posted: Fri May 15, 2009 4:58 am Post subject:
| amplex wrote: | | if you are only interested in the workings of these lunettas, im sure they are simulatable in some sort of computer software, not really sure about circuit designing software so far, but there is probably something perfect for your needs out there already, and possibly free.. anyone? Would ChucK labs work? I know that you can build basic synths and it is basically an audio programming language (Csound comes to mind), and there is even a GUI for it for Mac. I've never really used either of them though, so i'm basically worthless in this thread =]] |
As a ChucKist with an EE background, I really like the notion of using ChucK to simulate Lunettas. For one thing, ChucK has square wave oscillators with modulation inputs as well as filters and such. Also, since ChucK is a (nearly) full-fledged C-like programming language you can simulate pretty much any digital circuit excluding novelties such as the power-starving tricks that Jan mentions.
It would be tough to simulate the details of say an RC-inverter oscillator, but on a more macroscopic level ChucK would be a great tool for simulating Lunettas, given that you were inclined to take a programming approach rather than say a simulator approach.
In fact, if you'll see my nearby post about making a Lunetta-based eChucK synthesizer board, combine that with the notion of using ChucK to simulate Lunettas, and toss in the idea of interfacing ChucK to such a thingie, well, there seems to be some sort of merging of software, hardware, creativity and fun waiting in the wings. Ohh, I can hear the gears in my head beginning to turn... _________________ "Let's make noise for peace." - Kijjaz |
Consul
Posted: Fri May 15, 2009 6:06 am Post subject:
I guess it's time to find some bulk sources for banana cables and jacks, 4000-series chips, and the like.
Actually, what I should really do this weekend is get the basement finished so I can have my lab/workshop ready. _________________ Darren Landrum
RF
Audio files: 28
Posted: Fri May 15, 2009 6:25 am Post subject:
Glad to hear you are going to do this! Place the orders...then work on the basement.
Maybe you already have a good source, but FWIW I use
Digi-Key for the chips & resistors
Jameco for Pots and LEDS
Mouser for EF Johnson Banana Jacks
Radio Shack for all my cell phone needs.
Buy in bulk- or at least in larger numbers and you'll save a bunch.
Consul
Posted: Fri May 15, 2009 7:06 am Post subject:
Radio Shack truly has fallen from grace for home electronics hobbyists. Still, they're a convenient source of piezo discs, which I play around with a lot, and not just for musical uses.
Inspired by the idea of nodes in a graph, I think I'm going to build mine as small modules in Altoid tins. Discrete nodes which can then be connected in every which way. Powering them is the only issue I see. I'll probably build a common power bus which can feed power via minijacks or something like that. Just plug in one cable, and voila! Power. _________________ Darren Landrum
RF
Audio files: 28
Posted: Fri May 15, 2009 7:27 am Post subject:
"You've got questions...We've got Batteries" - Radio Shack.
It's almost painful for me to make fun of them. Many hours of my formative years were spent in the parts section of Radio Shack. Not a month went by that I didn't whip out my "Free Battery a Month" card to get a 9V battery to power whatever my current project was.
I love those little Altoids boxes..They are just begging to be used for something like this. Good idea.
The Johnson banana jacks won't fit in those, though - except maybe if you mount them on the sides. I recall someone mentioning mini-banana's somewhere in the forum - maybe they would fit? You could also use 1/8 jacks - those would work.
Keep us posted on your progress
Inventor
Audio files: 267
Posted: Fri May 15, 2009 7:50 am Post subject:
You know, the notion of putting separate Lunettas into Altoids boxes sounds an awful lot like an eChucK project (OK, I'm getting to sound like a broken record but that's what's on my mind this morning)... _________________ "Let's make noise for peace." - Kijjaz |
Consul
Posted: Fri May 15, 2009 8:11 am Post subject:
What would be really cool is if little Lunetta modules could be induction powered. Just plop them down on the induction pad, and they "magically" get the juice they need. Then the only wires will be the banana cables running signals everywhere. _________________ Darren Landrum
Consul
Posted: Fri May 15, 2009 8:20 am Post subject:
And then integrate accelerometers so that moving the boxes around affects the patch.
Okay, I'll stop now. _________________ Darren Landrum
droffset
Posted: Fri May 15, 2009 2:35 pm Post subject:
Nifty idea, i wonder if the famous BEAMbot photovore circuit would work, some big capacitors charge up on sunlight and periodically blurt out some bleeps and bloops.
Now I really want to try it, heh. |
Rykhaard
Posted: Fri May 15, 2009 2:44 pm Post subject:
| Consul wrote: | Radio Shack truly has fallen from grace for home electronics hobbyists. Still, they're a convenient source of piezo discs, which I play around with a lot, and not just for musical uses.
Save yourself some money and let Radio Shack fall it's over due way. (Like Bruce - '82 to '86, Rad.Scrap was my parts supplier. )
Get out to the local $ Store and buy yourself the digital alarm clocks. Piezo inside!
That's what I did earlier this year when I needed some to convert my Remo Practice Pads, into electronic drums. Alarm Clock piezo; coffee tin lid, done.  |
Inventor
Audio files: 267
Posted: Fri May 15, 2009 8:12 pm Post subject:
Very resourceful scrounging, Rykhaard. Me, I try to usually buy from DigiKey, but then I pay too much, don't I? Still, a great supplier for lots of goodies. _________________ "Let's make noise for peace." - Kijjaz |
Rykhaard
Posted: Fri May 15, 2009 9:03 pm Post subject:
| Inventor wrote: | | Very resourceful scrounging, Rykhaard. Me, I try to usually buy from DigiKey, but then I pay too much, don't I? Still, a great supplier for lots of goodies. |
Thankee muchlee! I used to buy my piezo's from Rad.Shack years ago, when I built my first electronic drum pads. Coming back to building a kit again earlier this year, I remembered that dig. alarm clocks had piezo's and tried it - successfully (buying 5 more, for $5. Instead of 1 piezo for $5 at Rad.Scrap.)
Digikey has been my main out of town supplier for a few years now. I LOVE them! Small Bear Electronics is my 2nd fave out of towner. The only real one here in the tri-city of 400,000 people has SOME stuff, but not a lot. Digikey and SBE are my saviours most of the time.
Except for LEDs - I get all mine now from www.superbrightleds.com . Wonderful pricing and shipping times up to Canada.  |
