softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
xpmtl
Joined: Aug 10, 2007 Posts: 162 Location: Brussels, Belgium
Posted: Thu Nov 08, 2007 3:48 pm Post subject:
Pin 16 of IC 1 is not connected to anything. Shouldn't it be tied to +15v via a 56K resistor? _________________ http://sdiy.xpmtl.net |
softfin
Posted: Thu Nov 08, 2007 4:33 pm Post subject:
Thanks for pointing that out!
It seems I accidentally deleted R30 during my last modification of the layout. It's now corrected I also separated the pcb and overlay to two pages and improved the quality of the pdf. |
forbin
Joined: Jan 29, 2009 Posts: 120 Location: Fremantle, Australia
softfin
Posted: Thu Jan 29, 2009 10:16 am Post subject:
Glad to hear that!
Btw, welcome to electro-music! |
CJ Miller
Posted: Sun May 17, 2009 2:43 pm Post subject:
This VCO is very much like the first useful ones I made, but mine were only tri and square. I had made dozens of 555-based oscillators and also used those as linear VCOs. But my layout skills were so poor that my perfboard tries at better VCOs never worked - except as AM radios! I had never soldered any projects bigger than a couple of 555s and I was determined to make an ASM-1 VCO. This was before I had internet to ask anybody, eventually I did it like two years later.
I learned about the 13600 and thought that it looked like one of the most useful synth chips ever... I built a synth out of 13600 VCOs, VCFs, and VCAs. I never enclosed it, the boards just sat on the table. I only got around to experimenting with envelopes around when I moved and put it away, about 1999.
It's making me a nostalgic fool, but these are cool VCOs. Cheap, easy, and they sound great. Mine didn't track so well on the high end, but I was amazed that it even worked. They kept me from throwing in the DIY towel. Also, if you look at the 13600/13700 datasheet, you'll see that this is easily adapted to a quadrature VCO. |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Thu May 21, 2009 6:04 am Post subject:
Could you reupload the PDF. I've tried downloading it but it seems to be corrupted.
adam |
Junk Rhythm
Joined: Jan 07, 2008 Posts: 81 Location: San Francisco, CA
Posted: Thu May 21, 2009 7:39 pm Post subject:
| adambee7 wrote: | | Could you reupload the PDF. I've tried downloading it but it seems to be corrupted. |
Try downloading again. It just worked for me. |
adambee7
Posted: Fri May 22, 2009 12:51 am Post subject:
| Tried to dowload again but says file damaged or corrupted. I have updated acrobat but still computer says no. will try it on my mates pc later. |
Posted: Tue May 26, 2009 5:28 am Post subject:
| adambee7 wrote: | | Tried to dowload again but says file damaged or corrupted. I have updated acrobat but still computer says no. will try it on my mates pc later. |
i have these issue here at work from time to time for a few weeks now. did adobe publish a new version again? i am still using AAS 5 here.
but i can open above file without errors! _________________
Tech Buddy at Random*Source |
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Wed Jun 03, 2009 11:56 am Post subject:
Tried with Acrobat 5, and could not open the file (errors). Tried with Acrobat 8 and it opened no problem!
Tim (definitely NOT an acrobat) Servo |
