today> Sorry, no program tonight. Chez Mosc
Audio IN to WSG?
Page 1 of 1 [9 Posts]
urribarbar
PostPosted: Mon Apr 06, 2009 4:57 am    Post subject: Audio IN to WSG?
Subject description: Audio IN to WSG?
Audio IN to WSG?
Is it possible?
Pehr
PostPosted: Mon Apr 06, 2009 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure!
1 MOhm resistor to the point 'odd' in the schematics. Just like R2 and R5.
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
urribarbar
PostPosted: Mon Apr 06, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pehr wrote:
Sure!
I mean for modulation ,not for filter
Pehr
PostPosted: Mon Apr 06, 2009 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
0k, via 100kOhm resistor to Q1 base then.
EDIT: and you need to AC-couple the signal via a 0.1 µF cap too before the 100k.
YouTube channel
flickr photostream
urribarbar
PostPosted: Tue Apr 07, 2009 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you ,I will try
Krinor
PostPosted: Tue May 12, 2009 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Pehr wrote:
Sure!
This was a bit cryptic to me... I'd like to try this out. The WSG filter is really nice IMO, and being able to run external audio through it would make this little box even more versatile. Do I run the input signal through that 1M resistor ?
RF
Audio files: 28
PostPosted: Tue May 12, 2009 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Exclamation
Post a clip of what you do with it when you are done, will you?
bruce
www.sdiy.org/rfeng
Krinor
PostPosted: Tue May 12, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will Smile
LeighKemp
PostPosted: Fri May 29, 2009 12:09 pm    Post subject: Modulation input Reply with quote  Mark this post and the followings unread
Hi Everyone ive just joined the forum nice to be apart of all this.
i just wanted to know if the picture below is the correct way to
add modulation input for the wsg if so do i conect the
output to the middle pin of the Q1 Transitor.
and What Capacitor Do i use ?
Also Is there any easy circuit bending connections you can make on the wsg to say make one of the voices modulate flter cutoff.
http://tinypic.com/r/288sbcp/5
Cheers.
Loving the wsg by the way great having a filter input.
