Alternative power supplies (solar, wind, motion, etc)?
Page 1 of 1 [21 Posts]
macumbista
PostPosted: Tue Jun 02, 2009 6:36 pm    Post subject: Alternative power supplies (solar, wind, motion, etc)? Reply with quote  Mark this post and the followings unread
I'm near the end of a series of "Neanderthal Electronics" workshops right now, doing small battery powered 4093-based Lunetta synths with electronics n00bs in Northern Ireland, Germany, Norway and the Netherlands. This got me thinking about alternative power supplies beyond batteries and wallwarts.
It seems to me like the combination of simple Lunetta type circuits with solar or other alternative power would make interesting "eco-synths" for use in the half-flooded/half-desert habitat our planet will soon become. And the rather specific issues of such power (either a long slow voltage droop or quick sporadic discharges, for example) provide the kind of "problems" which lead to new kinds of sound synthesis and control systems.
Tom Bugs has a massive solar powered cabinet with those "gold" caps that basically charge/discharge a lot like a battery. And Ralf Schreiber does great solar noise makers as well using a small solar panel and a 74HC14/40106 wired for self-modulating feedback:
http://www.ralfschreiber.com/solarsound/solarsound.html
Anybody else try something similar? Solar, wind, water, walking, bicycle etc powered?
In line with this, does anyone have any tips about low power components (espc audio amps and speaker or piezo drivers) that could be used in our theoretical eco-synth? How about tips for charging/storage or dual supply? Ideas which exploit the issues of such power mentioned above in an interesting way (such as Schreiber's Solarsoundmodule)?
I guess it's time to start haunting the solar robotics forums...
Some first fruits:
http://www.ralfschreiber.com/suneater/suneater.html
http://www.solarbotics.net/library/circuits/se.html [great overview of solar circuit types, including nocturnal...]
http://en.wikipedia.org/wiki/BEAM_robotics
macumbista.net
RF
Audio files: 28
PostPosted: Thu Jun 04, 2009 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
macumbista -
Sorry, I got nothing for you on your topic Smile
...but thanks for posting those links. I put together one of those 40106 "solarsound" devices yesterday. Great fun, interesting idea. But a bit much experimentation for a class, perhaps.
Great concept on the neanderthal electronics classes, too. Wink
bruce
www.sdiy.org/rfeng
macumbista
PostPosted: Thu Jun 04, 2009 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bruce,
actually Ralf does the solar sound modules for afternoon workshops all the time, since it's such a simple circuit. Usually participants don't really even test the different values, they just throw in whatever's lying in front of them. The most interesting stuff happens when you test different gate outputs. I think they are perfect for a class!
best,
Derek
macumbista.net
macumbista
PostPosted: Thu Jun 04, 2009 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Another idea: what about those wind-up dynamos that get used in emergency radios and flashlights?
macumbista.net
RF
Audio files: 28
PostPosted: Thu Jun 04, 2009 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Odd you should mention those - I just looked at one a few days ago thinking that would be interesting to hack...
I think that's a great idea.
bruce
www.sdiy.org/rfeng
slacker
PostPosted: Thu Jun 04, 2009 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd just like to repeat what Bruce said, thanks for linking to those solar powered things. I too built one last night and they're pretty interesting, I haven't tried them with solar power just voltage starved them.
I've been thinking about trying solar power for my Lunetta, not really sure how at the moment though. It would probably have to be something using rechargeable batteries and a solar powered charger.
I think the wind up idea is a good one, if they can power a radio then they should be able to provide enough juice for a small synth or noise maker.
I've been to a few festivals where there's been small acts who use bicycles to power a dynamo that runs a amp and other things. Always looks like hard work though Smile
macumbista
PostPosted: Thu Jun 04, 2009 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
The thing I like about those solar modules are that the voltage created by the light is the only real control method, so they are actually only responsive to the environment.
Batteries and chargers is one solution, but that gives you an instrument that functions just like it might have before. As I wrote before, I'd like to explore systems which exploit the specific characteristics of their alternative power supply.
It's summer, maybe I need to run a friendly competition, a workshop or a little weekend festival on this idea... anyone living in or traveling through Berlin welcome to get in touch! Wink
macumbista.net
jochem
PostPosted: Fri Jun 05, 2009 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
How about the dynamo on a bicycle? You can get a synth on the go... Razz
PostPosted: Fri Jun 05, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Didn't I see a pic of this bike you built? Maybe a synth bike would be a nice new project Cool
Clack
PostPosted: Fri Jun 05, 2009 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
what is it like running stuff directly from solar?
I imagine the current is pretty low and very variant
yeah its an interesting idea the movement used to play an instrument also generates the power and puts it closer to an acoustic instrument
anyone know a good solar scource
I guess you could make a cheap dynamo by using a motor
Clacktronics.co.uk
toybox
PostPosted: Fri Jun 05, 2009 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i remember bugbrand building a solar powered synth.i think this is a good idea for a future project
mY MusIc
http://www.myspace.com/toyboxbastard
jochem
PostPosted: Sat Jun 06, 2009 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Synth-bike is a cool idea Cool You want to sponsor one Jan?
Possible solar supply could be from a cell phone charger? There are some gadgets for loading the battery when you are on the go, such as solar, wind-up, etc.
toybox
PostPosted: Sun Jun 07, 2009 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
bugbrands solar modular vary nice!
http://bugbrand.blogspot.com/2007/07/solar-power-modular.html
 Filesize:  49.3 KB
 Viewed:  7099 Time(s)
macumbista
PostPosted: Mon Jun 08, 2009 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Offlist reply from Bugs himself:
I'll try to collect my thoughts a bit and post something to the em forum --- I shamefully don't get in there much these days it seems...
Stupidly I never actually drove my modular DIRECT off the solar panels --- really ought to try that out though as I've still got those big panels.
Interesting things to bring up would be:
- good idea on the dynamo torches - you can get SHAKE ones too.
--- many simple electronic sound makers require really low power -- its the output amp that requires the most power!
- super caps (caps of 1farad or so - generally low voltage though) and memory protection batteries (that's what I used for the last solar-weevils (though these actually weren't so good 'cos I stupidly used SMD stuff and the 386 pwr amps turned out to have a lower output than the standard through hole ones I'd used before --- still I got to climb trees in Lisbon with them))
Oh yes and:::: http://www.flickr.com/photos/bugbrand/2655674860/
very, very simple...
Best!
D.
macumbista.net
macumbista
PostPosted: Wed Jul 22, 2009 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Some further research has focused on different kinds of power supplies. Super Cap/Gold Cap/Green Cap/Ultra Cap capacitors seem like the way to go, using them as a battery with something like a 20-25 Farad value. A very nice article on replacing 9v block batteries with a Super Cap is here:
http://www.mdk-design.com/docs/9v_capacitor_battery.pdf
Different kinds of "sun eater" circuits are here:
Supposedly, the best parts-count-to-power circuit out there is the Miller Solar Engine (it's super small!!!!):
http://www.beam-wiki.org/wiki/Miller_Solar_Engine
http://www.beam-online.com/Robots/Tutorials/Freeform/1381_SE/1381SE.html
http://www.beam-online.com/Robots/Circuits/1381.html
And here is a nice very basic "sun eater" assembled free-form:
http://www.ralfschreiber.com/suneater/suneater-free-form.pdf
Lastly, Ralf Schreiber recommends the following sun eater, using the (somewhat expensive) Maxim 8212 IC, when more current (such as the 100+ mA required to drive an LM386 amplifier!) is required:
http://www.bek.no/~flemming/flemmweb_current/details/mmmse_files/mmmse_all/solarbotics_MAX8212_soleng_bep-pm3-v2.pdf
All of these should be able to harness power from solar cells, wind turbines etc etc. There is always a trade off of how often you want your circuit to be active vs how long you want it to run (less frequent = longer activity, more frequent = shorter bursts).
I'll be experimenting with the Super Cap 9v battery a bit next week and will post more after that.
Best!
D.
macumbista.net
Luka
PostPosted: Wed Jul 22, 2009 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
how do i set up a generator to store power from a rat in a wheel Smile
problemchild
melbourne australia
macumbista
PostPosted: Wed Jul 22, 2009 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Just think how much energy you could be saving up from all those people working out at the gym!!!!
macumbista.net
Inventor
Audio files: 267
PostPosted: Wed Jul 22, 2009 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe we can harness the incredible force of people blowing hot air and jumpin to conclusions. Rolling Eyes
macumbista
PostPosted: Fri Jul 24, 2009 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Kenyans invent bike phone charger
"The device is so small you can put it in your pocket with your phone while you are on your bike"
...it takes an hour of pedalling to fully charge a phone...
"We took most of [the] items from a junk yard - using bits from spoilt radios and spoilt televisions"
http://news.bbc.co.uk/2/hi/africa/8166196.stm
Wink
macumbista.net
PostPosted: Fri Jul 24, 2009 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not use geothermal energy? Then you might get some unwanted side effects that will most probably be brilliant additions to your next Lunetta concert.
Geothermal energy and earthquakes
Wink
macumbista
PostPosted: Fri Jul 24, 2009 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Kinetic powered e-music:
“Chiptune Marching Band” (CMB) is a participatory DIY
workshop/performance. CMB is a public workshop and actual public
performance where participants make a sensor driven sound instruments,
self-powered by a kinetic power source, and perform with their
instrument with the band. With instruments at the ready, the group
heads outside, bringing an event to the streets as the Chiptune
Marching Band! The course invites any members of the general public,
offering them the opportunity to explore localized resource
communities, sound making circuitry, and collective sound performance
through their realization.
http://chiptunemarchingband.com/
macumbista.net
