tweaker
Posted: Sun Jun 14, 2009 8:57 am Post subject:
Are these hidden features? Subject description: New NR2X owner |
I bought a new NR2X a week ago and read about the following button combination on these forums:
SHIFT + LFO1 shape button = Shows knob value in display
After some tweaking I found these other button combinations, I don't remember reading about them in the manual. Are these hidden features? Are there any more of them?
SHIFT + Filter Type button = Some kind of band-reject filter, all three leds are lit
SHIFT + Mod Env button = Skips to the first program/performance of the first bank
SHIFT + Velocity to Filter button = Dump all programs and performances maybe? (I haven't checked I there is any midi activity going on...)
SHIFT + Filter KBD track = Runs through some numbers and then 547 is shown in the display (I'm not sure what its doing)?
SHIFT + OSC2 KBD track = Cycles trough program 4.A0 ~ 4A5 |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jun 14, 2009 1:14 pm Post subject:
tweaker
Nou, nou...
Wat heb je gevonden
(What did you found)
| Quote: | | I bought a new NR2X a week ago | Congrats! | Quote: | and read about the following button combination on these forums:
SHIFT + LFO1 shape button = Shows knob value in display | It shows the value indeed, but it is used to test the knobs when in service. I use it to set parameters to a value I need  | Quote: | | After some tweaking I found these other button combinations, I don't remember reading about them in the manual. Are these hidden features? Are there any more of them? | Not really... | Quote: | | SHIFT + Filter Type button = Some kind of band-reject filter, all three leds are lit. | This is a Notch+HP. Not that exiting... But liked the first one it could be useful... | Quote: | | SHIFT + Mod Env button = Skips to the first program/performance of the first bank | It goes to a certain memory location, but how to set this...? Never found out and what could be the use...? | Quote: | | SHIFT + Velocity to Filter button = Dump all programs and performances maybe? (I haven't checked I there is any midi activity going on...) | Special made to download factory presets to another NordLead. It also dumps the cards in the NL and NL2 | Quote: | | SHIFT + Filter KBD track = Runs through some numbers and then 547 is shown in the display (I'm not sure what its doing)? | Not here, though. | Quote: | | SHIFT + OSC2 KBD track = Cycles trough program 4.A0 ~ 4A5 | Also nothing here...
There are more combinations, but you've found the two most useful ones already (Value and SecretFilter) There are combinations which wipe out the complete memory... Don't try those, but I won't tell you Well, just a tip: | Quote: | | You have to use both hands and most females have some troubles reaching for it... | Wout |
