wish: BBD Delay
Page 4 of 12 [292 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 10, 11, 12 Next
funkyfarm
PostPosted: Fri Apr 17, 2009 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Jurgen,
this project would rely on a single MN ? right ?
for a delay time between 100 and 800 mS ? Wink
TekniK
PostPosted: Fri Apr 17, 2009 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
Jurgen,
Excellent Question ! Wink
2thick4uni
PostPosted: Fri Apr 17, 2009 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've already bought my MN3005's, but at this stage it's just a request / wish - lets hope that at some point in time it becomes a reality.
Single or double MN3005 design is fine by me.................
sduck
PostPosted: Fri Apr 17, 2009 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think Jurgen has specified at any point how many MN2005's are needed. His last post said to get one (or possibly 2) - no indication of why 2, although many of the respondents such as myself tend to buy pcb's and such in 2's for whatever reason.
JoeMorris
PostPosted: Sun Apr 26, 2009 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like one of these too...
I'd ideally like a jh phaser, flanger and delay to add to my triple chorus.
inform3r
PostPosted: Thu Jun 11, 2009 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
This would be a dream come true! I'd be down for 2. I've searched the net and this site for a VC analog delay and came up only with Thomas Henry's Midwest project. It's a great project but it uses SAD chips which are as rare as hen's teeth and supposedly extremely unstable, i.e. You finally find ONE for $50-75 and more than likely it arrives D.O.A.
Hope this comes true. Is Smallbear the only reliable source? Is it right to assume anything on ebay is shady?
RKHobbs
PostPosted: Fri Jun 12, 2009 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I will take one when you offer it.
Thanks, Rob
TekniK
PostPosted: Mon Jun 15, 2009 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just let know Juergen,i did buy several 3005,so if u made pcb available i take 2 or 4 ,thanks!
so far interests for 23 a 26 pcb's! Very Happy
20 more to go..
dingebre
PostPosted: Mon Jun 15, 2009 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you do a search for a DOD585 delay, or an Ibanez ad100 delay, or go to tonepad.com and look at their Small Clone Chorus, there are several delays which use a MN3005 chip. (I picked up a few from Small Bear while there are still to be had.)
There are a bunch of schematics for different effects here:
http://www.schematicheaven.com/effects.htm
I can't speak for the EBAY sources personally, but have read some horror stories, though unverified.
On the other hand, Small Bear is a known source and I have always been happy with my purchases there and can recommend Small Bear without hesitation.
dingebre@3dphysics.net
Luka
PostPosted: Wed Jun 17, 2009 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
the deluxe memory man schematic is in there
great thanks
i might just build a clone of that with my mn3005s
problemchild
melbourne australia
delayed
PostPosted: Wed Jun 17, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
if you are counting. i would take one.
kenl666
PostPosted: Fri Jun 19, 2009 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for two boards!
"complexity is easy; simplicity is hard."
- Edmund Kean
strategy
PostPosted: Fri Jun 19, 2009 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be in for one for sure. Juergen, I know its a feature typical to the Memory Man but a vibrato feature to this project would be lovely in addition to whatever you are thinking- if it makes sense in the design.
- Strategy
community-library.net/strategyhome.htm
plord
PostPosted: Sat Jun 20, 2009 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have two 3005s right here I've been saving for a rainy day. By all means put me down for a board!!
jhaible
PostPosted: Sun Jun 21, 2009 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I read every new entry in this thread, even though I rarely reply.
Expect something, but don't expect it too soon.
JH.
ericcoleridge
PostPosted: Sun Jun 21, 2009 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I'd most like on a delay is a sync input for the delay time so it can be quickly synced up to rythmic sources.
Another thing that would be cool would be having more than one (maybe 2 or 3) taps that were rythmically related, so you could simultaneously get 1/4 note and 1/8 note delays, for instance. Or even a switch letting you quickly go between related taps.
jhaible
PostPosted: Sun Jun 21, 2009 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
TC Electronics D-Two.
JH.
TekniK
PostPosted: Mon Jun 22, 2009 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
only 17 MN3005 left @ smallbear..
Funky40
G2 patch files: 5
PostPosted: Mon Jun 22, 2009 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
+1
and i sync it to my modular Very Happy
i have a Clockdivider with selection Switch and patch from there directly to the D-Twos Footpedal input.
It syncs nice, but if you change speed it needs some time to follow
you hear it in this Jam with lots of speedchanges : http://funky40.podspot.de/post/16-visit-at-the-mars-zoo/
if you sync, you cannot adjust Feedback, it jumps allways back to tempopage,
so a muteswitch on the modularout would be best.
D-Two, theres nothing like thisone, very recommended !
Funky40
G2 patch files: 5
PostPosted: Sat Aug 08, 2009 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
got now my MN3005s too.
Packaging of the 3005 from small Bear was VERY unnice !
100$ worth within of 4 ICs, and they just throw those together with other ICs into a ( electrostatic) Bag, without any Foam.................. Shocked
hope they'll work
TekniK
PostPosted: Sat Aug 08, 2009 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
hope they'll work
I hope they work... ,he have had 17 left some weeks ago ,now u can buy 70 pcs again,so he did buy another stock.
I sadly cannot test them,would like to buy 6 more
jmejia
PostPosted: Sat Aug 15, 2009 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm definitely be in for 2 if you end up making the project. Very Happy
delayed
PostPosted: Sat Aug 15, 2009 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i got the last 3 before it reset back to 75. it reset the second after i bought the last 3. 2 tested fine and one came in with bent legs so i could not test the third chip. steve said they are mailing me a replacement chip now. before i got these i tried ebay. i went though 6 chips and all where bad/fakes.
dar303
PostPosted: Sun Aug 16, 2009 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for one or two.
The different taps ans syncing options would be perfect if they are included, I have always wished for those functions in my BBD delays!
jhaible
PostPosted: Sun Aug 16, 2009 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
- Strategy
Good point.
Also, the Dynacord SRS-56 benefits from a built-in modulation oscillator: instant "warmth" (I mean, more of it than from a straight BBD delay).
Definitely a must, in a JH Delay project. Very Happy
JH.
