Recommended PSU
Page 1 of 1 [8 Posts]
Vayner
PostPosted: Sun Jun 21, 2009 12:07 pm    Post subject: Recommended PSU
Subject description: Which PSU to start with?
I'm starting my DIY modular experience with some CGS kits. I was told a PSU ordered from Curetronic would do the trick, but I've sent an order in several times without reply now.
Which PSU would you recommend for somebody starting with a relatively small setup? (currently a CGS VCO, Tube VCA, VCF and Dual LFO)
I'm looking for a built solution. Soldering these modules is one thing, not getting electrocuted while not understanding how to make a PSU is another.
Thanks in advance
- Bjorn
zthee
PostPosted: Wed Jun 24, 2009 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not the CGS66?
StoneRose
PostPosted: Wed Jun 24, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
my personal advice is to buy either two external, linear (not switching!) +15V or +12V power
supplies, which are able to provide at least 500mA, 1A is better
another option is to buy a AC converter which delivers 15 or 12v ac, you can then build the ac to dc converter yourself (see ray's wall wart power supply for schematics http://www.musicfromouterspace.com), both versions are safe
In my relatively small modular setup (2 vco, 2 filter, 2lfo's, 2 envelopes, s/h..) is use two external 12V/1A linear power supplies which work great!
Just remember that stable power supply is very important on a analog synth!
fluxmonkey
PostPosted: Wed Jun 24, 2009 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I use PowerOne dual output linear supplies, like their HBB15-1.5-AG (adjustable between 12 and 15 volts, 1.5 amps). they are easy to come by surplus or on eb*y, cheap. either the CGS or MFOS boards are fine, but by the time i source the transformer and all the parts it's not much cheaper. having solid, clean power is a good thing.
b
www.fluxmonkey.com
Vayner
PostPosted: Thu Jun 25, 2009 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the replies. Because of this thread, curetronic got in touch with me. Apparently my order ended up in the spam folder.
I also got some good advice on the chat of this site.
If curetronic can't help me, I'll probably build one myself. But I'm trying to find something that isn't kit. I got 4 untested modules that are ready to be powered. I don't want to blow a fuse by making a noob mistake.
These are alternative options that got suggested to me:
http://www.paia.com/proddetail.asp?prod=9770R-12&cat=12
http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY.php
Thanks for the help.
- Bjorn
Funky40
G2 patch files: 5
PostPosted: Thu Jun 25, 2009 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
why no switched PSUs ?
was there not a thread in the main DIY section where some geeks ( statemachine? ) stated that modern switching PSUIs will do the job ?
whats the advantage of lienar PSUs ?
are those little boards from CGS giving a linear PSU ?
Tasmanian Alkaloid
PostPosted: Fri Jun 26, 2009 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
- Bjorn
Also check out Blacet's ps500 power supply- it has 6 connectors for modules built in. You could also get their PSCONN board for a further 9 connectors, or one of Ken's MOTM distro pcb's.
http://www.blacet.com/store2.html
curetronic.com
PostPosted: Sat Jun 27, 2009 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
see also:
http://www.curetronic.com/curetrbau/neubau/power.htm
power supply
 Filesize:  692.07 KB
 Viewed:  392 Time(s)
