today> Twyndyllyngs Chez Mosc
patch swapping for the a6 andromeda
Page 1 of 1 [11 Posts]
sunny pedaal
Audio files: 12
PostPosted: Tue Nov 16, 2004 3:17 pm    Post subject: patch swapping for the a6 andromeda Reply with quote  Mark this post and the followings unread
hereby two to start with (definitive versions)
please reply about if problems occur .for mac users the .syx extension might not be neccesary. otherwise just sent them over b.e . oms /syx loader or cakewalk to your a6,
just let me know what you think of it.
( by the way versions most certainly to work properly have been added from 02.14am 17-11)
048water.syx
water
made by modulating the oscilator by red noise( nz/ext-fm) and thereafter modulating the filter by the oscilator
 Filename:  048water.syx
 Filesize:  2.29 KB
 Downloaded:  1172 Time(s)
040 solina.syx
70's transitororgan
clocktempo=reverb
s/h tempo= vibr.delay
ribbon= preste-sound
 Filename:  040 solina.syx
 Filesize:  2.29 KB
 Downloaded:  1125 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Wed Nov 17, 2004 9:47 am    Post subject: two for today Reply with quote  Mark this post and the followings unread
johnny:syncing ska version
crumar ds2: also good as a start for default /performance synth
filters , envelops sound quite like the original monopfonic synth, oscilators were a bit more difficult. when tweaking i would suggest leaving the filter 1 untouched.
007 johnnie.syx
sync/ska sound, mod wheel and ribbon can be adjusted
 Filename:  007 johnnie.syx
 Filesize:  2.29 KB
 Downloaded:  1057 Time(s)
038 crumar ds2.syx
simple analog synth of 1975, just adjust filter2 and play
 Filename:  038 crumar ds2.syx
 Filesize:  2.29 KB
 Downloaded:  1093 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Wed Nov 17, 2004 9:53 am    Post subject: five is a good start Reply with quote  Mark this post and the followings unread
last patch for today , just to give an idea of how the a6 can make inconsistent patches.( when bored,quitte the sound by turning the eg3 release2 to zero before changing the patch)
109nikkebekkerly.syx
just inconsistent sound, when bored turn of envelop3 release2
 Filename:  109nikkebekkerly.syx
 Filesize:  2.29 KB
 Downloaded:  1017 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 19, 2004 2:55 am    Post subject: patch for the friday Reply with quote  Mark this post and the followings unread
just a simple stereo file sound begins on the left then moves to the right
slightly percussive/pianolike
120 Sur2.syx
stereosound moving from left to right
 Filename:  120 Sur2.syx
 Filesize:  2.29 KB
 Downloaded:  999 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sun Nov 21, 2004 5:43 am    Post subject: sunday Reply with quote  Mark this post and the followings unread
today a simple basspatch i use for a song called "the tune"
it sounds best in the range of a2-a3. the echo in fact is a modulation which can be switched off.
by the way feel free to post one or more of your patches, as the ones published sofar i've already heared before! after almost 200 hits at least there should be someone out there who makes his or her own sounds on the A6. come on, show the guts, don't be shy !
012 the tune-trem.syx
mod wheel=vcf resonce
ribbon=vcf cutoff freq.
 Filename:  012 the tune-trem.syx
 Filesize:  2.29 KB
 Downloaded:  1053 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sun Nov 21, 2004 5:51 am    Post subject: some feedback wanted Reply with quote  Mark this post and the followings unread
i wonder if the patchformat chosen for this forumsite (.syx)
works well , maybe someone could give a small feedback signal on if the patches are loaded and displayed properly via your computer , if other formats are required and afcoures (which would be nice) if they are liked a bit
greetings , sunny flower
.....................................................................................................................................transformer
sunny pedaal
Audio files: 12
PostPosted: Mon Nov 22, 2004 9:32 am    Post subject: monday Reply with quote  Mark this post and the followings unread
guess it must feel this way , awaiting responds from other insects Rolling Eyes
076 inside an insect.syx
tiktik
(when feeling tired of being lonely, just turn down env.3 release2 to zero)
 Filename:  076 inside an insect.syx
 Filesize:  2.29 KB
 Downloaded:  1015 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 26, 2004 3:36 am    Post subject: ringmod Reply with quote  Mark this post and the followings unread
just a patch when starting to experiment with ringmodulation.
what you hear is a playable basic ringmod sound . the effect is caused by osc2 , synced with osc 1 and modulated by env.1
030 A3.syx
kind of defaultpatch for experimenting with ringmodulation
 Filename:  030 A3.syx
 Filesize:  2.29 KB
 Downloaded:  985 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 26, 2004 3:41 am    Post subject: just crazy Reply with quote  Mark this post and the followings unread
guess one of the craziest patches i made , just good for nothing, therefore on this forum.(nice effects can be made by b.e. playing with pitch and mod.wheel at the same time)
just crazy106.syx
crazy !
try b.e. turning pitch and modwheel at the same time
 Filename:  just crazy106.syx
 Filesize:  2.29 KB
 Downloaded:  1036 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 10, 2004 4:28 am    Post subject: lin fm patch Reply with quote  Mark this post and the followings unread
hereby an example of the fm/osc
079 the defstrang2R2.syx
example of fm /osc. a simple appergiator is included
by turning the mod.wheel more voices are taking part in the sound( see voxmonitor). due to the inaccuracies in regard to fm with the A6 an interesting effect occurs
 Filename:  079 the defstrang2R2.syx
 Filesize:  2.29 KB
 Downloaded:  942 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 10, 2004 4:45 am    Post subject: performpatch Reply with quote  Mark this post and the followings unread
defaultpatch i use for performing live
realtimecontrollers like modwheel or ribbon can be routed to taste, so i left them out as default.
in fact this patch greatly resembles the previous crumar ds-2 patch (especially the filters), however effort has been made to improve the oscillator/wave to make a more fat sound. also a quick acces to filterfm by osc1 and a standart filterfm by noise is included.
would be nice to hear somebodies result working with this patch in futher.
other contributions to this side or questions/remarks afcourse are also greatly welcommed
solong.sunny
026waveds2.syx
live performance patch
 Filename:  026waveds2.syx
 Filesize:  2.3 KB
 Downloaded:  996 Time(s)
