today> Twyndyllyngs Chez Mosc
128 word virtual RAM memory
Page 1 of 1 [17 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Jun 14, 2009 5:54 am    Post subject: 128 word virtual RAM memory
Subject description: with read and store functionality
Here's something the G2 hasn't been able to pull off up to now, and brings it further into Reaktor-territory.
It's a dynamic memory array of 128 words that can be read from or stored into. Use for eg. dynamic lookup tables, live 128-note sequencers with record function, algorithmic stuff, etc.
Due to its design, it updates at most every 256 samples (it fluctuates when the read/write address is changed, but it's never more than 256). This equals max. 2.66 milliseconds, or 375 Hz, which still compares very well to the refresh rate of the mod engines of many synths. However, this means some precautions when integrating it into a circuit which clocks higher, depending on it has to be implemented.
With this technique, larger and smaller RAM memories which follow numerical row of the power of 2 (64, 128, 256, 512 etc) can easily be made. The update rate will go higher or lower accordingly, as well as the DSP usage, in the case when more than one clocked delay module is required. Eg., a 512 word RAM array would need 4 extra modules (3 delays, one for calibration) and refresh every 10.666 msec, which might still be usable for many applications.
The memory content is preserved over the variations. Naturally, it cannot be saved with the patch however.
The details are described in the patch itself.
DSP usage (the raw circuit without the demonstrational extras):
8.5% cycles, 9.4% memory. Not bad. Smile
tim
128 Word RAM TK.pch2
128 word virtual RAM memory with read and store functionality
 Filename:  128 Word RAM TK.pch2
 Filesize:  1.95 KB
 Downloaded:  1940 Time(s)
jksuperstar
G2 patch files: 18
PostPosted: Sun Jun 14, 2009 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice! They say Necessity is the Mother of Invention....so, what's the mother - are you working on more grainular synthesis engines? loopers?
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Jun 15, 2009 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha, you got me! Laughing Yes, this indeed is a subcircuit of something new I'm working on. Not granular -I think I've taken that as far as I can.
I won't tell yet because the chance of it working is still 50/50. But if it does, it's going to be a new step for the G2.
dorremifasol
G2 patch files: 49
PostPosted: Thu Jun 18, 2009 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
dorremifasol sets mode LURKER=ON
Albert
seb
PostPosted: Tue Jul 07, 2009 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim, that looks really nice! But unfortunately it doesn't work for me: I just loaded your patch and hit the store button and tried some addresses, but the memory readout is always 0. Do I need to change anything? I'm working on an unexpanded G2 version 1.40.
Sen
http://www.myspace.com/sebastianarnold
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Jul 10, 2009 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Seb,
Hmm, hard to say. It works fine for me on the demo version. I downloaded it again right now from this thread and tried it. Also, I'm already using it in other patches on the hardware. No problem.
The most probable issue is that you are not using the right pointer values for the store and write addresses. In order to access the 128 words, you have to use values 0-63.5 (equalling 128 steps) in discrete increments of 0.5, otherwise the circuit doesn't recognise them.
tim
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu Jul 16, 2009 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
is it possible to share us a Camtasia Studio tutorial:D some stuff of yours is way above my knowledge, as my mathematics are really low developed. But i do know how to use most of your patches.
Do you think a basic DIY tutorial can be found for the g2?
cappy2112
PostPosted: Thu Jul 16, 2009 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of your neighbors already has one available. Send a PM to Roland Kuit
It's easy for you to get to. Not so easy for the rest of us outside of Europe.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon Jul 20, 2009 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
true, i've noticed his tutorial a while ago. Ill see if i can order it. thnks
seb
PostPosted: Tue Jul 21, 2009 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
now I tried your patch in the demo version. I load the patch, hit "Store!" and the value (=frequency) changes, so all seems to be fine. On my G2 Key (v1.40) this does not work. I also tried saving the patch to the G2 and restarting it. But the RAM readout is always 0. What is going on...?
Seb
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Jul 21, 2009 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
seb wrote:
Hi Tim,
Seb
Shocked hmm, I'll look into this. I'm very busy right now, perhaps Friday.
stock
G2 patch files: 10
PostPosted: Fri Dec 11, 2009 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
like Seb, i had the same problem, the patch doesn't work with my modular (v1.40).
So i tried to fix the problem :
* the "counter" circuit made with 1-mixer was strange. i changed for a more predictable bit-counter and D/A converter...
* also change the calculation circuit of adress from level-multiplier to a more basic AND-gate (and i use the other gate to make a clock previously made with Logic-inverter)
now, it works for my modular.
gain 2% of cycle but lose 4% of memory
here is the patch :
in blue, the original patch from Tim
and, in yellow, the modification i made.
128_word_ram_cs_.pch2
modifications of the Tim Kleinert's 128 Word RAM memory.
bug fix for v1.40 modular version
 Filename:  128_word_ram_cs_.pch2
 Filesize:  1.91 KB
 Downloaded:  1494 Time(s)
stk
varice
Audio files: 29
G2 patch files: 54
PostPosted: Wed Dec 16, 2009 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
stock,
There is a bug with BinCounter module used in your patch. Read this topic for more information:
http://electro-music.com/forum/topic-23906.html
In your patch, you may be able to connect the unused 128 output the reset input on the BinCounter module to get around this bug. You should test this to see if that works.
varice
stock
G2 patch files: 10
PostPosted: Wed Dec 23, 2009 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
i tested it, and you were right : the patch crash after some time.
so, here the new patch with this bug fixed. it seems to work well now.
i also change the gate-module clock rate to 48kHz. The virtual memory will refresh faster than the previous one.
DSP usage :
6.7 % Cycle
13.3 % Memory
(excuse my bad english)
128_word_ram_cs__fixed.pch2
128 word virtual RAM memory. Bug fixed
 Filename:  128_word_ram_cs__fixed.pch2
 Filesize:  1.92 KB
 Downloaded:  1555 Time(s)
stk
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Jan 17, 2010 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sorting this out Cedric. Smile
Virtual ROM memory (yes) coming soon. Smile
3phase
G2 patch files: 141
PostPosted: Wed Jan 20, 2010 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
?? really? i would like to beef up my old sequencer concepts.. this might be the way...
do you know when this might be a reality?
3phase
G2 patch files: 141
PostPosted: Fri Jan 22, 2010 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
what is the reason this patch has to be fixed for Os1.40
is ir working in 1.62? are there other bug fixes or changes in 1.62 that should made us change to 1.62?
