latency
Page 1 of 1 [9 Posts]
stephenbloe
PostPosted: Mon Jul 06, 2009 4:50 am    Post subject: latency Reply with quote  Mark this post and the followings unread
what is the best way to solve latency issues when connecting to a nord rack 2 to laptop (ableton Cool? there is a tiny delay in the audio signal
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Jul 06, 2009 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the same delay there when cotrolling the synth using a Midi keyboard?
If not the problem is the laptop.
Wout
gearaholic
PostPosted: Mon Jul 06, 2009 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
all computers have latency....how many miliseconds is the issue
stephenbloe
PostPosted: Sun Jul 19, 2009 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hey
i'm still having problems with the sound when running the synth into ableton live. will this be due to the midi interface that i'm using or just settings in ableton?
BobTheDog
Audio files: 32
PostPosted: Sun Jul 19, 2009 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you talking about midi latency (midi notes recorded late) or Audio latency (Notes sounding late)?
stephenbloe
PostPosted: Mon Jul 20, 2009 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
when i map out midi notes on ableton and run it into the nord then the notes aren't responding in time to a 4/4 beat as they should be
BobTheDog
Audio files: 32
PostPosted: Mon Jul 20, 2009 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
How are you listening to the audio out from the Nord?
Is it going through Ableton like this:
Ableton Midi Track -> Nord -> to Ableton audio track -> to master and your monitors?
Or like this:
Ableton Midi Track -> Nord -> amp/monitors
stephenbloe
PostPosted: Tue Jul 21, 2009 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm running it midi track - nord - back to ableton audio track
is there something in the latency section in preferences that i can change to improve this?
BobTheDog
Audio files: 32
PostPosted: Tue Jul 21, 2009 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you looked in:
Live->preferences->Audio.
Here you can choose your audio device and set the buffer size, use the smallest setting you can that doesn't crackle.
