<on air> Twyndyllyngs - not cancelled tonight Chez Mosc
Breakdown Filter Module
Page 2 of 2 [45 Posts]
Goto page: Previous 1, 2
TekniK
PostPosted: Mon Aug 10, 2009 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
yes its a lot of stuff to do one thing if u build it 'closed' in one box,but hes filters HAS all the patchpoints that could be bring out on the frontpanel,so u could insert fx or delay at different steps,and an elaborate sequenced vca morpher pcb that could be used also separately invites other posibilities,u can throw in what u want.
PostPosted: Mon Aug 10, 2009 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
very good points, you both.
since i wanted to build the "one trick pony" without any modular approach intended i think it is oky, this way.
BTW the filter boards provide additional inputs, so that i could use them as single filters (resonators Very Happy ). these single inputs and the step switch that limits the counters steps are not on the test pannel though.
i think i will have to take a closer look into the simple VCA thread (single transistor VCAs?).
and hasn't there been a thread about using FETs as variable resistors? i did not want to use 8 LM13700 for the ARs...
TekniK
PostPosted: Mon Aug 10, 2009 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
don't know ,could a waveshaper replace an ar function ?
PostPosted: Mon Aug 10, 2009 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
could you explain?
BTW maybe i could just use a fixed attack and a variable release? ideas? suggestions?
PostPosted: Mon Aug 10, 2009 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I reckon the single transistor VCAs sound good.
Maybe just 1 dual gang AR pot on each step, with one switch to shut off the Attack or Release or neither for that step/AR/filter.
That way you've just got 8 pots and 8 switches.
But then you still need to control trig lengths hey?
PostPosted: Mon Aug 10, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i actually would have wanted the ARs and VCAs on the control board, with one common attack and one common release control. i'd liked to keep it simple, not too much access on each single filters parameters. i fear the feature creep Shocked and i want to use my already etched filter PCBs. and maybe even fixed attack. i am actually happy with it as it is, but i don't like the pops!
TekniK
PostPosted: Mon Aug 10, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
could you explain?
If u want smooth morphing then ar should be able to set at the same time.
don't know ,but if we just need a fast or smooth transition between 2 steps a narrow or wide triangle would made the job?
I think if u wanna integrate possibility to have variable (so also zero) attack and release and u need to do for that implementing 8 ar circuits then it would be a shame not to have ar controls for each of the 8 vca's as this would create nice filter grooves,but then u get a huge board plenty of parts only to do that.
so to keep it simple 8 VC waveshapers that converts the trigger pulse with one control knob and external cv that controls all 8 transitions (vcas)?
TekniK
PostPosted: Mon Aug 10, 2009 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
yes,or only one dual gang pot that controls all 8 steps
Funky40
G2 patch files: 5
PostPosted: Mon Aug 10, 2009 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you gonna post any details about the controller board? Schems?
TekniK wrote:
nice,but would be great to have a smoother morph possibility ,would be great for moving soundscapes..
i am still thinking about the 'how'. as mentioned before the boards does not work that well for others than pulse waves, so i want to redesign it.
great project fonik !
In my opinion ONE full CV able SEM VCF is musically the better way to go.
you can not obtain everything then ofcourse, but as you guys are disscussing allready:
the Seq switched way will blow up extremly if you think thru.
with a +V / -V Sequenzer and lets say two lines you will get musically more less similar results........
Add another SEq line for the panning etc. . Reso.........etc. ........
concerning the switching have a look at this module and the description, and the BOM ( click above: technical )
or as allready said from Ian: Jürgens Interpolating Sanner is a way.
in my patching exeriences i was never "that" happy when seq switching VCFs on Jürgens Scanner.
On the other side i had a Semtex from Anyware Instrumnets which is a SEM clone who offers a VC-Morph.
Thats the ticket IMO !
with VC-Morph you get very very cool musical results in a much faster intuitiv way, IMHO.
so not speaking of theory
( the unit had too much bleedthru, HP filtermode was unusable, thats why i sold it, and i needed only the filter )
Having now two Oakely SVF VCFs i get again nice results, now with SEq switching on the fonitronic Sec switches .
Easier and more intuitiv then patching thousands of filters to my Haible Scanner.
Also my Dopfer morph a-107 made me never happy. morph is more a preset crossfade, not a 1:1 morph.
2 full blow up SEM clones are enough, IMO no need for all this extremly complex filtersequenzing to get THE music.
better invest the time in your somewhere mentioned +-V Sequenzer.
something a la MFB02 with +-V possibility is the ticket for lots, IMHO
CV-morph, it's all about CV-morph within the right VCFs, IMHO.( ok, etwas übertrieben/ exaggerated )
and now look to the Market......................... Laughing Laughing Laughing
wiard Omni is the only one i'm aware off. and then look that price: Laughing Laughing Laughing
1200.- / the Doepfer is cool, but i would not call it a morph filter
TekniK
PostPosted: Mon Aug 10, 2009 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Offtopic:funky40, i have a dual SEM multimode with VCQ pcb layout ready.
Its single sided ,allthought not tested it should be fully functional.
PostPosted: Mon Aug 10, 2009 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
i get you points, funky. however a SEM-style with all bells and whistles would be another project, and IMHO strictly private DIY, because:
http://www.retrothing.com/2009/06/tom-oberheim-new-sem.html
in fact it is the switching that gets my attention now. it shall be driven by clock (which is NOT overlapping), but it should cross-fade. that's the trick i want to solve here, i think. a sequential switch, that produces no pops. therefor i want it to be on the controller board, and therefor i want it to have just one or two controls (Attack/Release).
i get it resolved it would be very cool to use it with 8 filters, just as teknik mentioned: x-fades between the filters with different cutoff, resonance, mode, and pan settings...
Funky40
G2 patch files: 5
PostPosted: Mon Aug 10, 2009 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
yup, i get your point too.
diablojoy
PostPosted: Tue Aug 11, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I might not be getting my head round this correctly so please ignore this post if it is of no help but could you allow selective outputs through with vactrols AKA auto level to smooth the response that way it may be possible to get overlap[a held voltage on the vactrol control circuits ,same for all, controllable via one pot], however the trade off is speed of course . it may not be quick enough for somethings and you would lose separate A/R per step, but you do gain the ability to use CV to decide which filter , when and for how long. it could be run off a simple sequencer 0 -1 volts= filter 1, 1-2 volts= filter 2, 2-3volts=filter 3 and so on. the voltage quantized to 1 volt steps and run through comparators and logic gates and then to control ccts for the vactrols to do this.
the sequencer could supply a single A/R with the gate signals then or even another gate source could be used. a single VCA is then only
required as well. if the A/R is also voltage controlled you can gain back the A/R per step from the same or a different sequencer
yes i know it does mean at least 8 fast vactrols at more than $5.00 each
however i think that would be simpler and cheaper than 8 A/R's and
8 VCA's and less introduced noise and a lot less knobs
anyway may be something to consider
PostPosted: Tue Aug 11, 2009 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds very interesting, indeed. however my filters outputs are stereo, so this would require 16 vactrols - unless i would place them right before the pan control, but then i would touch the filter boards again. i did not wanted to do that.
i just tried a 2n5486 FET as a voltage controlled resistor in a spice model simulation. i did not get it working right. i tried to follow the description in the Siliconix AN105, but my approach is more trial&error Very Happy
diablojoy
PostPosted: Tue Aug 11, 2009 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
yes FETS would be quicker and cheaper to implement but like you
I would be doing trial and error. even more so as i know nothing on spice
modeling. I seem to remember reading about FET''s replacing vactrol's
for CV control in an echo module in a post on this site that may offer a helpfull clue in that direction
16 vactrols and associated circuitry would be getting a bit much perhaps
missed the stereo bit .
ah yes there try looking up scott bernardi's
pt2399 vc delay post
PostPosted: Tue Aug 11, 2009 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you very much for the hint. i will look into this thread.
thank you all for your kind suggestions. you all are very helpful. e-m is an incredible place, isn't it?
haxster
PostPosted: Thu Aug 13, 2009 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik did you notice the floppy action when you used the Single Pot grabbing technique with the alpha pots? It makes a grab but the pcb will kinda swing side to side. Perhaps if you ever do that approach again make yourself a template/library for the Dual Alpha Pot even though your not really using the other side of the pot. When strategically located even (1) dual pot makes a sick stable grab, no more swing. But I guess when it is all done and setup no one is really going to swing it on the back, unless you have mice or giant centipedes.
Those ribbon cables accross blow me away! Mad respect.
mono-poly
PostPosted: Sun Aug 23, 2009 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Mathias this is really sounds great man i hope you come up with a solution.
PostPosted: Sun Aug 23, 2009 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
i will.
however i will have to finish other things first: the LPG 292c expansion board (2nd and hopefully final prototype is on it's way) and the SDS3(!), which is currently growing on my breadboard.
mono-poly
PostPosted: Sun Aug 23, 2009 6:06 am    Post subject:   Reply with quote  Mark this post and the followings unread
SDS3!
wave
