today> Twyndyllyngs Chez Mosc
Gate Control Expansion Board for LPG 292 (Thomas White PCB)
Page 2 of 8 [190 Posts]
PostPosted: Mon Aug 17, 2009 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
adambee7 wrote:
yep! that's made my mind up. I'll def have 2. I've built four lpgs so two will have this I think. Very Happy Very Happy
good to know. the response has been a little bit weak, seems there is not that much interest in a PCB for this. however it is summer time... anyways, i will order the 2nd prototype board soon (made some minor changes), build it, and then ask for interest in professional manufactured PCBs for this project.
meanwhile i will work on the SDS3 single voice PCB Very Happy
janvanvolt
PostPosted: Mon Aug 17, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik: I take two Smile
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
gwaidan
PostPosted: Mon Aug 17, 2009 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just a question-are the mounting holes on the board the same width apart as on the 292c so it can piggyback on the board using a couple of spacers? It would be really cool if it didn't need a separate mounting bracket Very Happy
Junk Rhythm
PostPosted: Mon Aug 17, 2009 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in a few. Once there is an estimate for the price I'll know how many I want.
[twitter] [blog] [flickr] [toppobrillo] [buzz]
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
gwaidan
PostPosted: Mon Aug 17, 2009 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be up for at least two, possibly 6
PostPosted: Tue Aug 18, 2009 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
that's the idea, and that's exactly how i did it. i am currently waiting for the exact data from thomas, since my prototype does not fit exactly (due to odd distance?).
gwaidan
PostPosted: Tue Aug 18, 2009 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Well in that case I'd be up for 6!
intercorni
PostPosted: Wed Aug 19, 2009 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
@Fonik: I take two!
pcp2020
PostPosted: Wed Aug 19, 2009 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy Crap! this thing sounds awesome!
being a newbie I dont really understand what this does but i do know I want one.
count me in for four. I have four 292 boards so i figure I should get four of your boards.
TheAncientOne
PostPosted: Fri Aug 21, 2009 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Lovely work Fonik. If you do go ahead with a run, I would like two.
Thanks
Mike
ach_gott
PostPosted: Thu Aug 27, 2009 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Updated for pre-order as listed by Matthias below: I am ordering 4.
kitsch-bent
PostPosted: Sat Aug 29, 2009 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'd be up for at least 6 of these (:
haricots
PostPosted: Mon Aug 31, 2009 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, I'll take one for sure (maybe 2) if you promise to help us relative newbs out and supply a nice list of parts and wiring diagram so I don't screw it up. Very Happy
PostPosted: Mon Aug 31, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure!
the 2nd proto is supposed to arrive this week. i will build it up, test it, and then set pricing and a deadline for advance orders. so there is enough time for me to come up with nice building docs.
PostPosted: Wed Sep 02, 2009 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
the prototype is tested now and it works fine. you could mount it piggyback style on your TH LPG 292c PCB, even the mode switch pads are in the correct position, so one could use long pins instead of headers/cables to connect the boards.
however, i brought the actual switch terminals of the IC to pads, so this board could be used as gate controlled 3-pol on-off-on switch for other projects.
switching audio can always be a problem, i believe. so it is here: you might experience little pops when switching audio, depending on the signals you are switching. you will have experienced this with professional modules, too.
i will write up some building docs soon, boards should be available end of september.
i am taking advance orders until 16 SEP 09, 12:00 UTC
PRICING:
(under the assumption of minimum advance orders for 50+ PCBs):
PCB 7.-USD/5.-EUR
+ packaging & postage
deutschland: 2.-EUR
europe: 3.-EUR
worldwide: 1 PCB 4.-USD, more than 1 PCB 8.-USD[/b]
ChrisR
PostPosted: Wed Sep 02, 2009 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! I'll take two boards.
What's the "correct" way to order, Matthias? PM, email?
Chris
PostPosted: Wed Sep 02, 2009 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
there is no incorrect way actually. email, PM, post here... whatever serves you the best.
magman
PostPosted: Wed Sep 02, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,
Can you out me down for 2 boards as well please.
Regards
Magman
adambee7
PostPosted: Wed Sep 02, 2009 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
oh what the hell matthias i'll go for 4 instead of 2 boards please.
cheers man
adam
monokinetic
PostPosted: Wed Sep 02, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi matthias,
great news, thanks for another great project Smile
Please put me down for three PCBs.
David
clickmrmike
PostPosted: Thu Sep 03, 2009 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, two here as well!
clickmrmike
jojjelito
PostPosted: Fri Sep 04, 2009 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias, two PCBs for me please! This will make the LPG top dog for chopping things up. Thanks for a great mini-project Cool
gwaidan
PostPosted: Sat Sep 05, 2009 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Six for me!
LektroiD
PostPosted: Tue Sep 15, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me please Smile
LektroiD
creatorlars
PostPosted: Tue Sep 15, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 2 as well, please!
