<on air> Twyndyllyngs - not canceled Chez Mosc
Moog or SSM filters for my Juno 106: worth trying?
Page 2 of 3 [75 Posts]
urbanscallywag
PostPosted: Fri Sep 19, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Samples please? Anyone? Confused
mome rath
PostPosted: Fri Jan 16, 2009 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
and tap the pliers with a larger set of pliers or small hammer. The pin will just pop out.
And when you're lazy you can just push them out with a hot iron Shocked
correct, sir!!
jeffery girlsbottom
PostPosted: Fri Jun 19, 2009 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
how is this going?
any hope this would still work on a juno or a jupiter 6?
radek tymecki
PostPosted: Sat Jun 20, 2009 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
any chance with making tutorial?
i have few ssm2044 and i'd like to use it instead of juno's vcf! Smile
thanks Smile
johans121
PostPosted: Sun Jun 21, 2009 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a fascinating thread! I have a friend who has an HS60 (juno 106 w/speakers) with a couple dead voices and this may very well be a solution worth pursuing. Please continue to post your progress!
Don't feed me Indian, you WILL regret it!
-Jim
radek tymecki
PostPosted: Mon Jun 22, 2009 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
agreed. mine has 2 dead voices.
Sebo
PostPosted: Tue Jun 23, 2009 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
Do you see this:
http://matrixsynth.blogspot.com/2009/03/possible-repair-technique-for-80017a.html
I will be trying that soon.
Sebo
My Music:
jeffery girlsbottom
PostPosted: Thu Jun 25, 2009 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
probably could start buying voice-dead Juno 106s and fix the chips like he has and sell them. hope this and the filter replacement can be more discussed by those with knowlodge.
Mooger5
PostPosted: Thu Jul 09, 2009 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Greetings
Well I´ve found the old samples! Thought they were lost but here they are, once again.
SSMJUNO-1.wav
 Filename:  SSMJUNO-1.wav
 Filesize:  4.73 MB
 Downloaded:  1164 Time(s)
Mooger5
PostPosted: Thu Jul 09, 2009 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Second sample...
SSMJUNO-2.wav
 Filename:  SSMJUNO-2.wav
 Filesize:  4.77 MB
 Downloaded:  1129 Time(s)
Mooger5
PostPosted: Thu Jul 09, 2009 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Third and final...
Awful playing technique, I know Smile
Comments are elsewhere in the thread, since it´s the same old samples.
Keep in mind I never got to finish the project; it´s just to show it works, in case somebody´s still interested.
SSMJUNO-3.mp3
 Filename:  SSMJUNO-3.mp3
 Filesize:  1.75 MB
 Downloaded:  1121 Time(s)
Mooger5
PostPosted: Wed Aug 05, 2009 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished prototyping the final version. The filter sounds clean now. And squelchy. Listen to the soundfile.
I´m still surprised how simple it turned out to be. I gotta go now. Tomorrow we´ll have a look at the schematic. I´m struggling with ExpressPCB (some things don´t seem to work), so I´ll just sketch it on paper.
ssmjunoV2.mp3
 Filename:  ssmjunoV2.mp3
 Filesize:  3.76 MB
 Downloaded:  1296 Time(s)
Mooger5
PostPosted: Thu Aug 06, 2009 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Here´s the schematic. As you can see the filter part is a blatant copy of what´s in the datasheet. It just sounds fine.
Ground connections from the SSM2044 and the TL081 go straight to pin 7 of the voiceboard. From the BA6110 to pin 8. Pin 3 of the OTA I left unconnected (N.C.).
Feel free to ask any questions, make any remarks. I´m still learning. Wink
 Filesize:  167.83 KB
 Viewed:  759 Time(s)
radek tymecki
PostPosted: Fri Aug 07, 2009 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
is there any chance for proto-pcb ?
it'll be easier 4 me Very Happy
jwilsey
PostPosted: Mon Aug 10, 2009 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet! I am all over this. I am glad that you found the time to work on this mooger, good stuff. Laughing
Mooger5
PostPosted: Mon Aug 10, 2009 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, what you see is not finished yet. And I´ll probably give up on this one. A few resistors are not yet soldered, still lots of traces to cut and due to the power rails and connections between the chips there´ll be lots of noodles flying around. This one would resemble the innards of an old japanese radio. There´s plenty of space, so no reason to cram the components in such small boards. Besides it won´t provide the best ventilation. I think I´ll make a neater solution.
 Filesize:  50.97 KB
 Viewed:  521 Time(s)
 Filesize:  46.41 KB
 Viewed:  502 Time(s)
radek tymecki
PostPosted: Tue Aug 11, 2009 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
ok we're waiting then! Smile
Mooger5
PostPosted: Fri Aug 14, 2009 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha just take your time then, as stripboard is still a bit messy. Regular perforated board less so, and this is the best I can do. Smile
"#$%&/ Just noticed two errors - IC3 pin 8 should be connected to voice board pin 10 and not connected to IC3 pin 7... (edit - it´s fine afterall, the wire was misrepresented by the program, running over the connection between pin 6 & 7).
My drawn schematic also has a few goofs in the graphic representation of the BA6110 Embarassed
 Filesize:  182.08 KB
 Viewed:  708 Time(s)
radek tymecki
PostPosted: Fri Aug 14, 2009 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i'm waiting for final protoboard and calibration procedure
Mooger5
PostPosted: Mon Aug 17, 2009 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, what final proto-board? The final layout is already posted there. Just populate the board exactly as pictured and it will work. Ok, there are a few errors: there is no IC4 (you can blame the program for that one) , one of the caps is not 180pf but 820 instead and one resistor is wired twice to ground, but they´re easily verified when compared to the drawn schematic.
As for the calibration procedure, just follow the service manual indications, but do it after all the six boards are installed. There will be six aditional active devices (the TL081s) that I expect will draw a bit more current, with possible voltage dropping, so it´ll be best to start by calibrating the power supply.
Mooger5
PostPosted: Mon Aug 17, 2009 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I finished one board last night and it worked first time. "Only" five to go now. Don´t hesitate to ask for help if necessary.
Mooger5
PostPosted: Wed Aug 19, 2009 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the first module. The solder side looks a mess but it´s working faultlessly. I used wirewrap wire and the components´ "legs" straight connected where possible. Finally I insulated the solder side with Plastik 70 spray.
It´s a tedious job. Takes more time to make one module than to populate six manufactured PCBs, so I´m already divaguing whether or not the filter directly linked to the vca would be a better option. At least getting rid of that extra opamp would make everything much easier to assemble. It was one of the initial attempts and it all sounded either weak or distorted, but I think I know where the fault lies, now. Tomorrow I´ll breadboard it (it will be the last attempt, I promise) and keep you all posted.
 Filesize:  486.89 KB
 Viewed:  581 Time(s)
 Filesize:  487.32 KB
 Viewed:  590 Time(s)
johans121
PostPosted: Thu Aug 20, 2009 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
THAT, sir, is F'ing awesome!
-Jim
mono-poly
PostPosted: Sun Aug 23, 2009 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
cool man!
Mooger5
PostPosted: Mon Aug 24, 2009 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Always good to hear words of approval! Thanks guys thumleft
Well, I was about to post my recent thoughts on the CEM3396 as a cheaper and far easier to assemble alternative for the project, but I better not get myself carried away by it. The 2044 sounds fantastic and it´s time to reckon the fun is over and the serious work awaits.
