About Midi and Layers (special to the Rack)
Page 2 of 2 [45 Posts]
Goto page: Previous 1, 2
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jul 23, 2009 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
GavinR wrote:
... It is like one takes over from the other when triggered. ...
This taken over is mostly a property of the voices. When 4 Slots are used the NL2X distributes its 20 voices, which mean 5 voices per Slot. When also Unison is used half of the voices (per Slot/Program) is gone. which means only 2 voices are available in the Slots.
At the moment this is what I can think of, and tomorrow is another day...
Wout
Synthluver
PostPosted: Tue Aug 18, 2009 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I choose the Nord Rack2x over the keyboard version (already got too many keys) based on reputation for good sound.
Now I am totally confused and totally disappointed. I have many issues with it, but let's concentrate on what this thread is about : Midi and layers on the Rack2x.
I have read the instructions book many times (and now this thread many times also), spent many hours trying to figure things out, to no avail.
Can you or can you NOT use layers with midi? How? On one hand, the manual says to change midi channel to the same one for all the slots, and turn the slots on or off to get layers. It also says all slots respond to incoming midi (on the slot's channel all the time).
It seems to me it is the latter that prevails. Whatever slot(s) is lit up, they all play if all on the same channel. The only way to silence b-c-d is to assign their slot's channel to off.
In a case where a-b-c-d are assigned to channels 1-2-3-4, turn on only slot C for example, and you hear only slot a (on channel 1) even if it's not lit up.
The leftmost thing mentioned in this thread (but I am not there yet) is confusing also. What if i want a layer with slot C and D. Is slot A (not lit) the leftmost one? Again, before solving this point, I must solve the regular layer management.
So instead of having 4 syths in one, I either have a one slot synth or a totally unmanageable one. Clavia's site does not seem to offer an updated OS for the 2x
There must me something I am not figuring out right. Please help.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 18, 2009 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Synthluver
I think that’s the main reason to buy one!
Reading you other posting you’re surely not the stupiest on this forum…
I have read the instructions book many times (and now this thread many times also), spent many hours trying to figure things out, to no avail. Can you or can you NOT use layers with midi?
It should be, if all things work, like Midi cables and Midi interfaces…
How?
I’ll try to explain. In the first place I have to admit I also don’t understand it all Smile, but when trying to explore and explain we will come nearer to the solution! To tackle the thing is, I think, best to view it in situations one want to use the synth.
When connecting a Keyboard controller it transmit on one channel and that one is most of the time channel 1. Controllers able to split the keyboard are able to send more than one Midi channel, but that’s a different situation. So one can control Slot A when set to channel 1. Next step: I also want to play Slot B, producing another sound. Only Slot B is set to channel 2 and normally it won’t sound. This can be changed by pressing [Shift+Unison(=Midi Ch)] and scroll to Midi channel 1. This is how a normal synth would work. Here I drop in a special text…
    Important to understand Clavia designed a Performance synthesizer, which means this has to be viewed from that mode’s point! By just activating Slot B it will react to the Slot A Midi channel 1 too. Just one push on the button. This is the infamous ‘leftmost’ Slot Midi channel thing…
However, this works on my NordRack(1), NOT on my NordLead2, so it can be only a feature of the Rack version - but then it has to work on your Rack too – or it is only ‘the original thing’ thing and therefore is only works on my version 1…
So you are playing the synth, probably to find a nice sound to use in a song, controlled by a sequencer, and want to create a Layer. This is possible just by hitting Slot B. Good results, just save it all as a Performance by pressing [Store] > [Perf] > scroll to a location and press [Store] again. Next time you need the sound it’s there. Of course the same goes for adding Slot C and Slot D.
Of course, when all Slots are set to the same channel they will always react to that Midi channel. That’s why Clavia designed the leftmost feature, so you don’t have to change the settings all the time and also back again. Beware, all is looked at as one is creating a Performance.
    PLEASE! If the leftmost doesn’t working on your Nordrack2X, report it in this thread, because I can’t check it myself.
The Slots always react to incoming Midi, and you are playing channel 1, aren’t you? So you hear Slot A, even when Slot C is active.
    Just to try: activate Slot A too and you’ll hear both Slots. Slot A will be in focus, which means the LED is blinking and you can tweak the knobs. Turn the Patch Gain anti clock wise (mute the sound) and you’ll hear Slot C only, even when controlling it by channel 1…
    To make a Slot not reacting to Midi, scroll to off This setting can be saved in the Performance mode when needed.
Another way is not to send Midi on that particular channel Smile
Is there any use for the ABCD > 1234 configuration? It’s very handy when it is permanent connected when using a sequencer: just a fixed routing of Midi. Four Slots to be used as four separate voices or just a Performance controlled by one channel. Connecting the controller Keyboard to channel 1 and using the sequencers Midi Through function, all could stay in a fixed set up.
I hoped I explained…
No, it has to be active. Slot C is the leftmost one concerning Slot D, so no need to change Slot D midi channel.
I worked the other way around.
Shocked
There is no update for the NordRack2X
There is and I hope I helped you…
When you have it, come back to me to hear about the global Midi thing…
Wout
Synthluver
PostPosted: Tue Aug 18, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Woww!! Thanks for the prompt and elaborate answer. I gather from browsing around that you are kind of the main man around here. And a good job you are doing. It's all in the spirit of helping others without waiting for anything in return. It deserves commendation.
I think there's a little mistake in the wording of one line in my message above. Anyway, I'll make the most of your reply (thanks again) and report my findings as soon as I can. I will also try another keyboard. My test were made with an el-cheapo Kaysound keyboard, that has however never had any problems driving any midi stuff (within it's own limitations).
Synthluver
PostPosted: Tue Aug 18, 2009 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope... the leftmost thing does not work, same results as before.
Before starting, let's say that besides channel 1 to 16, most midi equipment use channel 0 to indicate ALL channels. No such thing on the 2x... off or 1-16
Now in order to simplify things when debugging, it's important to get things as simple as could be... So I did the following :
-silence slots C and D by setting their channel to off
-select for slots A and B a preset for which the unison l.e.d. is off (less osc's working) and that are mild and much distinctive from one another (slot A on 16, slot B on 93)
-concentrate on channel 1 (when active) for boths slots.
The results are :
slot A on channel off, slot B on channel Off : no sound, either slots lit up (that was expected)
Both A and B on channel 1... you can hear both patches, with either slots lit up
Slot A on 1, B off, you can hear slot A with either A or B lit up
Slot A off, B on 1, you can hear Slot B with either A or B lit up
I skipped a few results, but having been a methodical as i can, reducing the number of variables, my conclusion is just as earlier : using channel 1 only, you can hear all the slots that are set to this channel, no matter which slot is lit up.
A few more things :
- setting a slot to channel 2 (A or B) will silence that slot, no matter which one is the leftmost active one.
- I have noticed that performances don't (SEEM) to show this unfit behavior. I have not tested performances yet, sticking to the basic layering mode, not in performance mode, trying to solve that point first. That could very well be the culprit, although the manuals does not mention about having to be in performance mode to use layers.
- My global midi channel is set to 16, which is i believe, the way to go.
So that leads me to believe that layering can only be done in performance mode. Maybe that's what the manual wants to say when it says all slots share the same editing area (buffer).
Fiouuuu!!!!!
Will be doing the same tests as above now, in performance mode.
Hummmm... early tests (before posting this) are not encouraging... seems to behave exactly the same way. The thing is : unused slots are set to midi channels other than one. On the very first performance (and without saving changes), if you turn off (slot not lit up) A and B and activate C and D, you can still hear A and B.
Hard to know what to think any more. The last bunch of tests were performed with a Yamaha keyboard. I'll fish out my Roland PCR-800 (which i don't like all that much) but that I am sure can send to a specific midi channel instead of to all.
Synthluver
PostPosted: Tue Aug 18, 2009 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope again. Done pretty much all i can with an Edirol PCR-800.
Performances are the same. Maybe I am expecting too much. Layered slots do work when they are set up properly. Up to 4, with proper channel assignments.
However, the manual is wrong when stating you can turn slots on or off to select which one you want to use. The only way to achieve that is to turn the slot's channel off or to the exact channel the controller is using.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 18, 2009 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, that’s nasty!
… Slot A on 1, B off, you can hear slot A with either A or B lit up
So far nothing strange, I think.
Have to read this carefully… Seems also okay to me!
As long you set them all to channel 1, you will hear each Slot. That’s right.
A few more things :
If you are not switching on the controller keyboard to channel 2, this looks logical to me Smile
I should stick to the Program mode, because that’s the one where a sound design session will start!
It is, but of no importance right now…
No, I think you are not making a Layer right now Smile
Fiouuuu!!!!!
Take it easy!
Wait just a moment…
That’s because they will always react to Midi signals! To silence them, switch to Midi off!!! This setting can be stored with the rest of the data in Performance mode
The controller isn’t that important, just leave it on channel 1.
    My suggestion…
    Set all Slots to a different channel and at the moment 1, 2, 3 and 4 will do fine. Leave global Midi at 16. (Notice that channel is 16 to all four Slots… It’s global, isn’t it? Smile )
    Activate Slot A and play it > sound!
    Switch to Slot B only and play it > no sound, I hope… It only sounds when channel 2 is used!
    Set the controller keyboard to channel 2 > sound, right?
    That’s just normal behavior.
    Now switch the keyboard back to channel one, and activate Slot A > same as the first one above, I hope.
    Now while holding Slot A button also press Slot B, both will lit and Slot B will blink (pressed last) > you probably will be playing both Slots by only Midi channel 1.
Does this happen…? Please…!
If so, you are playing a Layer!
If due to our time differences I fail to answer, tomorrow I’ll be out of town the whole day and will arrive late (over here that is), so please be patient.
BTW culprit, what a word. Sounds a bit moisten too Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 18, 2009 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Synthluver wrote:
... Performances are the same. Maybe I am expecting too much. Layered slots do work when they are set up properly. Up to 4, with proper channel assignments.
I wait for a reaction to my earlier return mail Smile
Manuals are always wrong, because I didn't write them. Well, bull... The Manual to the Nord Modular Classic (Version 1) is still the best I ever read. It was written by Tomas Johanson, now-a-days Clavia's user-support-man.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 18, 2009 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just a reminder for myself (sorry, I use this thread as a note book for an article about this too)...
Why is a Layer saved with all Midi channels directed to 1? If they use 2, 3 and 4 too, these Slots will react to that Midi channels; so directing these all to channel 1 leaves 2, 3 and 4 free to use by the sequencer to control other midi gear.
(myself)
Synthluver
PostPosted: Tue Aug 18, 2009 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks 'Wout' for looking me over on this. I'll put the matter to rest for now, after saying this :
-tests were all made with direct connections (no MIDI hub or USB connection) and first grade short midi cable.
-true the manual is one of the nicest around, well printed.. etc... but is similar to the synth itself in the way that there are things in there that are not exacly as they should.
-all this began when I wanted to get deeper into the Rack2x, see what it's possibilities were for live performing as it has a lot of knobs to tweak. I'll put it back in its earlier role, which is good sounding polyphony for my DAW software. Not a tweaker's synth.
On the strong side for the 2x , well built, great sound overall, my best organ sounds machine, sounds even better the Kurzweil 2500x
Live tweaking will go on as usual the analog way with my Little Phatty, Mopho-BCR2000 combo, and live polyphony with the Blofeld (about which I was not totally crazy at first, but that reveals a few more good sides every time I use it).
Synthluver
PostPosted: Tue Aug 18, 2009 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
My suggestion…
That’s just normal behavior.[/list]
No. Layers only work with slots on the same midi channel. Leftmost slot, whether you consider the one that is active, or A which is the physical leftmost one (active or not), does zippo (nothing). Slots on the right don't sound if not on the channel of the controller.
The channel is the common denominator. All slots play if on the same channel as the controller, whether they are active (lit up) or not, or left, or right, or whatever.
That's my conclusion.
If you want me to run another very specific test to make sure, just ask, I'll be glad to.
melmac
PostPosted: Mon Aug 24, 2009 12:38 am    Post subject: Nord Rack 2X: How to make layers easily
Subject description: Another possibility without changing MIDI channels
Hello again,
After a week with my „new“ Nord Rack 2X and your very helpful information in this forum I have understood the principles of the specific “MIDI/slot-behaviour” of the Nord Rack.
My intensions are: Making sounds and playing music, and NOT reading manuals or to fiddle out how to “trick” the device. Nevertheless: The sounds of the (single) programs are great but it would be very nice to make layers easily (and without changing the MIDI channels all the time).
Therefore I checked the following possibility (perhaps someone other already had this idea):
- I have built a “silent” program and stored it at program number “1” (i.e. NO sound when pressing a key)
- MIDI global channel is set to “16”
- MIDI channel of all the 4 slots A, B, C and D is set to “1” (one!)
- the master keyboard (a Korg Triton 61 LE) is sending on channel “1”
How it works:
Case 1 - Playing single programs: Select on slot A a program (different from #1 – of course), and select on the other 3 slots the program #1 (= silence). When pressing a key you can only hear the single program chosen in “A”.
Case 2 - Playing layered programs: Select on two or more slots the programs you want to layer (again: different from # 1). When pressing a key you can hear all the programs chosen.
To “mute” slots you only have to select the program #1 again – that’s it!
For me, this is a very easy possibility to make layers.
Perhaps you can tell me your opinion about that and if there are some “faults” in my way that I have not thought about.
Have a good time!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 24, 2009 1:00 am    Post subject: Re: Nord Rack 2X: How to make layers easily
melmac wrote:
... - MIDI channel of all the 4 slots A, B, C and D is set to “1” (one!)...
About this there is a lot of confusion! In my NordRack(1) I can leave my Midi routing as in the factory settings, which is A=1, B=2, C=3 and D=4. So I don't have to change it all to the same channel to get it working as a Layer! As long as I keep Slot A active (LED lit) all other Slots will also react to channel 1 no matter if they are set as above.
On the NordLead2 this isn't working anymore, although it looks that way. No conformation from Sweden still...
Wout
Synthluver
PostPosted: Mon Aug 24, 2009 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
melmac : Thanks for your input.
Let me decipher your post and maybe make a few more tests. You have probably read my exchange from last week with Wout. My own test were focused on making layers work with Slot A on channel 1 (the midi controller on 1 as well) and the other slots on any which channel I could think of. The postings, as much as I tried to write them accurately can be confusing.
Let me state again, in resume, my conclusion : that layering DOES work BUT :
a) the manual is wrong on turning slots on or off by pressing their respective buttons
b) All slots you want to hear must be on the channel you want to use
c) All slots you don't to hear must be on a different channel
d) if you follow point b) and c), it does not matter which slot is lit (supposedly active), all those set on the controller channel will sound, all others won't.
My tests were extensive enough to be absolutely sure of the above, but who knows, is there something I have overlooked or some combinations I have not tried? It's not entirely impossible but I doubt it. I am ready to put a little bit more work, just in case.
I will add that I had the idea too of making a silent program to help manage things, but in the end, decided not to push things this way, using layers properly set with the rules as stated above. I will try and see what comes out.
Equipment used : Nord Rack2x, Kaysound, Yamaha or Edirol PCR800 controller plugged directly into the rack (no midi interfaces, no MIDI hub, no computer), global Midi channel on 16 on the rack.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 24, 2009 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Synthluver wrote:
... a) the manual is wrong on turning slots on or off by pressing their respective buttons
Which is because all Slots are directed to the same channel: a Slot always reacts to the Midi channel to which it is being set...
So if the leftmost active Slot rule is implemented, one should hear that particular Slot and all those active to the right of it. All those not active and being set to different Midi channel (also the active ones are set to different channels) should be silent. This works on the NordRack(1) V2.3. If this isn't possible on the NordRack2X it is simple not implemented...
And the Manual isn't adapted to that...
That's what I am trying to find out...
I started this thread using the Manual and my NordRack1.
Wout
PS my doubt were about the fact it doesn't work on the NordLead2 Key version, so is it either not implemented anymore or a Keyboard versus Rack thing...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 24, 2009 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
There4 is another configuration I like to ask you...
It may indicate a difference between the Keyboard version and the Rack. Which Rack owner wants to try to copy this and report his/her findings?
I set up a Performance, in which Slot A contains an Arp, which plays constant using the Hold function. I play a chord and the Nord breaks it up into the arpeggiation. Then I deactivate Slot A (no Led lit) and activate Slot B. This Slot is loaded by a mono lead sound. When I play the lead and use different notes than the Arp uses. I can play the lead and the Arp stays the same. The Arp doesn't even react to the ModWheel and the PitchStick Smile
BTW it isn't necessary to set Slot A into Hold: just switching to Slot B while holding the keys will have the same function: all controllers off! (Partly Local off) Hold only provides larger arpeggio's.
Wout
Synthluver
PostPosted: Mon Aug 24, 2009 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout...
Well the Nord Lead 2x manual (which also covers the Rack2x) says about layering, and I quote including bold style:
Layering
Layering means playing more than one program at a time. On the Nord Lead 2x you do this by simply selecting more than one Slot. Note that layering sounds work quite differently on the Nord Rack 2X. On the Nord Rack 2x all Slots you want to be layered should be set to the same MIDI Channel. It does not matter which slots are selected or not since all slots respond to incoming MIDI data all the time.
Once that is said, the manual goes on explaining Slots and Layering, but no more references on particular items as to differences between the Lead and the Rack.
Now back in retrospective, the paragraph quoted is exactly my conclusions, but before coming to that conclusion, I still had to grasp the concept, which was harder since many things did not work in the text that followed the quoted paragraph and i had to figure everything out.
So in a sense, I would say that the manual IS right, but since the working is so different than expected (other than the quoted text), I qualified it wrong in my previous post. I would say now it is not explicative enough for new Rack2x owners (and confusing) but not wrong.
If this isn't possible on the NordRack2X it is simple not implemented... And the Manual isn't adapted to that...
No mention about the lefmost active slot being the master or whatever or the fact than even unactive slots (not lit) will play anyway if on same channel as the controller.
I would imagine that things are more by the book on the key version. For the rack, obviously (to me), even with the channel thing, the manual lacks in explaining slots for the rack, plus some shortcoming in the OS implementation. I think things could rather easily be changed with an OS update, but there's none available.
A letter to Clavia came back with the following answer (from memory) : we are sorry about the difficulties you are experiencing with the Rack2x and we hope you will find a synthesizer that suits your needs.
No word about a possible forthcoming OS update.
I am short of time for the next few days, but I will try the Arp think a bit later on.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 24, 2009 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Synthluver wrote:
Wout...
You sound tired and I can imagine Cool
No mention about the leftmost active slot being the master or whatever or the fact than even not active slots (not lit) will play anyway if on same channel as the controller.
So the next quote isn't true?
Manual nord lead 2X ver1.0 (eng).pdf page 76 wrote:
All four Slots always receive MIDI, regardless of which one is selected, or if layering of one or more Slots is activated or not. However, all Slots used in a Layer (i.e. all Slots that are activated) will also receive on the MIDI channel set for the leftmost active Slot! This means that if you have a layer consisting of Slots A, B and D, and Slot A is set to MIDI channel 1, both Slots B and D will receive on MIDI channel 1, as well as on their respective set MIDI channels.
I think this text has to do with the Rack, because using the Keyboard version one doesn't bother about Midi...
And also I believe this is a relic from the NordLead version 1, because on my NordRack this works fine.
… No word about a possible forthcoming OS update.
Surely there will be no update anymore.
Thanks for taken your time on this matter.
I wonder if this has any use at all, because those who have the Keyboard version don't bother about it and those playing the Rack mostly use Program mode and dedicated Midi channels or use it as a tabletop synth running automatically by the Arpeggiator...
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 25, 2009 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
So, what’s left in this discussion is the question: “Why did Clavia changed the Midi implantation of the ‘leftmost Slot’ feature when creating the NordLead2?”
To answer this is to ask first: “Why did Clavia implemented it in the first place?”
The designers created a synthesizer for the performing artist, which can be used in the studio also. This means Performance mode is in that perspective much more important than Program mode, thev later is only for creating a single sound. Creating a Layer and therefore a Performance is on the Keyboard version rather easy, because it controls only active Slots. Those not active will not sound playing the Keyboard. Nothing to do with Midi at all; it’s just the way the Keyboard is implemented.
This way to create Layers and Performances the designers also implemented in the NordRack (note this is the first version!). When a Midi keyboard is connected set to channel 1, which is most likely Slot A, by just activating the other Slots the Midi controller has the same function as the NordLead Keyboard and easy creating Layers is secured…
However…
Most NordRacks were used in a studio set up, in which the Midi configuration would be (again most likely) Slot A to D directed to channel 1 to 4 respectively. At first sight no problem, as long if the user won’t activate other than Slots A, because these are always reacting to their own Midi channels.
But this also implies a stored Layer in Performance mode won’t work that easy.
    In short: using a Layer will lose three Midi channels!
The Layer is controlled by the channel of Slot A, so the other channels are free to be used to control other things. If Slot A to D are still on their dedicated Midi channel as if they were used as single sounds, B to D will react to the wrong data, so these Slots have to be set to channel 1 or their channels have to be muted on the controlling Midi device, not very nice in the studio. It’s better to set up a Layer to channel 1 in the first place. Just consider scrolling through the Performance mode memory (PCMCIA card or intern on the 2X) in search of a nice strings sound. Every upload has to be changed!!! And the user likes to hear it while playing the rest of the Midi channels at the same time.
Conclusion: the ‘leftmost active Slot’ rule isn’t necessary on the Keyboard version and a pest on the Rack version for which sake it was implemented in the first place.
It is wise Clavia dropped this feature, only they forgot to adapt the Manual too Smile
Wout
Synthluver
PostPosted: Tue Aug 25, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Once again, i feel dumb in this matter. The excerpt I quoted is early in the book. Who reads these things from cover to cover? The part you quoted is from the section on how to use the Lead2x with sequencer. So there IS mention of the leftmost-master thing in the manual. However, no mention about the rack. I would think it works for the key version, but it is certainly false (or not applicable) for the rack.
I don't agree with your statement that key version users don't use midi. The synth store is a long drive from me and when I was there, I picked up the same day the Mopho, the Rack2x and the Blofeld, the latter two in key version were not in stock. I've only be in synths for that last 10 months and this purchase was early in my synth endeavours. At first, I liked the racks, that meant less keys (and I had already too many of them). But not anymore. And this has nothing to do with what we are discussing here. From now on, all my synths will have keys.
My synth rig is flexible. Plug, unplug, configure for a certain set up, all are bound to be used with midi, with keys or not. My Little Phatty is sitting right on top of my Kurzweil. The LP keys don't show much finger grease.
As to why they changed the implementation for the rack version? I can see the logic from a distance far away, but my own preference would be to be just the same as the Lead2x.
If I can live with the rigidity of performance settings, it all blows up if, for any reason, I want to use the rack on a channel other than one.
I don't find it particularly encouraging when you say not to expect an OS update. It would solve many problems for me, I think it would for some others too. The way things are, the rack will be used for the organ sounds (my best so far) but very little else.
And although yes, I feel somewhat exhausted by all this, I have developed a high tolerance level for debugging things, otherwise I would find my life as a software programmer a living hell Wink
