The Thomas Henry Mega Percussive Synthesizer
Page 21 of 31 [763 Posts]
Goto page: Previous 1, 2, 3, ..., 19, 20, 21, 22, 23, ..., 29, 30, 31 Next
PostPosted: Wed Jul 22, 2009 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I felt like I should have responded with a resounding "yes it is" (seeing as how I laid it out! Rolling Eyes )
But the fact was that I double guess myself so much that I quickly convinced myself that I just wasn't as sure as I thought I was! Laughing
Funky40
G2 patch files: 5
PostPosted: Wed Jul 22, 2009 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm very confused about the shell CV in and the optional CV ins ( impact/ Noise )
my shell CV in is definitly not working.
looking to Bugs wiring table it looks now to me as the switch should be a on-on-on and not on-on as i have.
I also messed up my panel while building the module because i added a CV input for the noise,
but then there was no J21 connector on the board....
buit now i remember that there was some disscussion somewhere back in this thread, and CV for noise and impact was omitted,
but then again i don't understand the lettering of the switch.
Is this switch thought to change the destination where that CV input goes to ?
i'm confused
the module sounds great, just wish to have a second one.
another faceplate is donne, another board too, but i have no connectors.......forgot to order those, shit ( must take them now over musikding )
thanks to Thomas, uncle K, Bugs and all the others involved in this project !
PostPosted: Wed Jul 22, 2009 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
There is only one CV in on the final board.
However, the "CV Source" or "shell modulation type" switch, lets you send the impact or noise signal into the CV summer for the shell. It's normaled to the Shell CV input jack.
Funky40
G2 patch files: 5
PostPosted: Thu Jul 23, 2009 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
so i indeed need just a single pole switch and i just have to connect the center of the switch to the switch of the jack ?
PostPosted: Thu Jul 23, 2009 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep
Funky40
G2 patch files: 5
PostPosted: Fri Jul 24, 2009 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
switch is replaced/rewired.
thanks
i had bleedthru from the impact to the noise mix when i tested the module.
now, placed in the sYnth i hear nothing. works again fine
only thing what is not running is the impact to CV shell modulation.
noise is working as modulation.
Have to check that wire......
great, happy that this 18 Pot module is running.
Thomas_Henry
PostPosted: Wed Aug 05, 2009 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi gang,
It's been ages since I posted. Due to various impedimenta, I wasn't able to broadcast a lot of new stuff this summer as in the old days. (Five new projects never made it beyond North Mankato). So not to spin my wheels, I went back to finish up some old projects.
I finally concluded my permanent MPS unit. Here's a pic of the unit. It's the top module in my new cabinet.
It's been a couple years since I heard it on the breadboard. Wow (if I do say myself)! The noise source and filter are pretty ordinary, but the impact tone generator and ring modulator really blew/blow me away. I can sense a new song on...
Thomas Henry
 Filesize:  68.15 KB
 Viewed:  713 Time(s)
Audio files: 235
PostPosted: Thu Aug 06, 2009 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome back, TH. Great to have you here. Hope to hear that new song that coming on...
droffset
PostPosted: Thu Aug 06, 2009 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Thomas, good to see you.
I purchased the electronic drum cookbook and am about to embark on a MPS build(or four), thanks for releasing this stuff, lots of possibilities to play with. Smile
rudypoochris
PostPosted: Thu Aug 06, 2009 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where are you all ordering reasonably priced potentiometers and corresponding knobs from (P/N's appreciated if available)? Thanks! =]
I just can't seem to figure out which knobs have "D-Hole" shafts and which don't.
Funky40
G2 patch files: 5
PostPosted: Mon Aug 10, 2009 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
My MPS Eurorack panel.
messed it up with that additional Noise CV socket
thanks again, i like it !
for best adjustments i suggest to use "something" Multiturn. Trimmers for example instead of pots.
Especially for those who like to build several units.
Shell Pitch and RM pitch have lots of sounds within very small amounts of turning the Knob. ( Or the expensvie multiturns )
also Impact pitch could be donne multiturn, but not really important.
2x MPS in euroformat ( runing on +-15V
 Filesize:  94.58 KB
 Viewed:  420 Time(s)
my MPS panel in more clear
 Filesize:  124.27 KB
 Viewed:  479 Time(s)
dnigrin
PostPosted: Thu Aug 20, 2009 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm considering building an MPS as a tabletop unit, as a standalone synth. I can get triggers/CVs to it from my other gear, but I'll need a power supply. I saw the previous post from Uncle Krunkus about using a Power One supply, but it seems those are ~$50 which is too expensive for me.
Could someone recommend a good power supply design that I could find online that would give me the +/- 15V necessary to power the MPS?
Thanks...
creatorlars
PostPosted: Thu Aug 20, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
CGS and Music From Outer Space both offer good power supply boards... but when it's all said and done, you can't beat this deal:
http://skycraftsurplus.com/index.asp?PageAction=VIEWPROD&ProdID=1100&strVarSel=&strCompare=
dnigrin
PostPosted: Thu Aug 20, 2009 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, thanks!
hobgob_inc
PostPosted: Sun Aug 23, 2009 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey yall
Just looking for some feed back on my panel design for the MPS. Thanks to all others who have posted theirs as inspiration.
I'm building two of these probably on blue anodize in a nice wooden casing. The size of the holes is actually representing the size of knobs, jacks etc. to give me an idea of the spacing, not the actual size of holes.
The main thing i've considered changing is dropping the send/receives. Any feedback would be great
Thanks, Luke[/img]
 Filesize:  61.44 KB
 Viewed:  400 Time(s)
MegaPerc.fpd].pdf
MPS panel
 Filename:  MegaPerc.fpd].pdf
 Filesize:  306.02 KB
 Downloaded:  504 Time(s)
hobgob_inc
PostPosted: Sun Aug 23, 2009 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure how to have the image showing on the page....
Edit: State Machine added image 8-27-09 .... saved the image in PDF as JPEG and used as attachment. The JPEG will automatically show up as an image in the post.
rudypoochris
PostPosted: Sun Aug 23, 2009 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am trying to figure out what the 1/4" jacks (J1-J10) connect to on the PCB? Any help would be much appreciated, sorry if this is a silly question, this is my first build. =]
http://electro-music.com/forum/phpbb-files/mps_layout_111.jpg
Additionally, are the NC jacks 2 conductor/3 contact like this:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SC1089-ND
rudypoochris
PostPosted: Wed Aug 26, 2009 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eeek got another question, what is the difference between all the different grounds? There is an A-Gnd a D-Gnd and a P-Gnd on the board. Can these all be tied together? If not is A-Gnd AC ground and D Gnd DC ground? If that is so, does the unit have to be grounded to the AC wall outlet? Thanks for any support.
creatorlars
PostPosted: Wed Aug 26, 2009 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
A-Gnd is analogue ground, D-Gnd is digital ground and P-Gnd is panel ground (wire to jack sleeves). I can't comment on the details of the wiring, but my guess is they are probably all connected on the board already at certain points.
PostPosted: Thu Aug 27, 2009 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes,
AGnd and DGnd are for systems which have separate Analogue and Digital ground run from their power supplies, so if you have only one ground from your PSU, just run it to the AGnd connection and leave J20 just as it is. (separate grounds need the link under J20 to be cut)
PGnd is just a termination I included for the wire which delivers ground to your front Panel.
rudypoochris
PostPosted: Thu Aug 27, 2009 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah okay got it, so leave J20 unsoldered since AGnd and DGnd will be joined?
Thanks for the assistance!
hobgob_inc
PostPosted: Mon Aug 31, 2009 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for doing that statemachine....
now anyone got any feedback for the MPS above??
Luke
janvanvolt
PostPosted: Fri Sep 04, 2009 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
creatorlars: are you able to provide a 1:1 mask for the MOTM design or even able to provide a panel ?
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
creatorlars
PostPosted: Fri Sep 04, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, attached is a 1:1 PDF for printing directly to transparency film.
The holes are spaced .875" apart horizontally and 1" apart vertically.
Unfortunately unless I have the panel here and ready to print when I'm doing mine, it's very impractical for me to do additional panels since it requires remaking the screen, etc. So I'm unable to provide a panel. ID Mark photosensitive aluminum may be a good option if you don't want to silkscreen.
lzx-megapercussivesynth-silk.pdf
 Filename:  lzx-megapercussivesynth-silk.pdf
 Filesize:  253.82 KB
 Downloaded:  672 Time(s)
janvanvolt
PostPosted: Tue Sep 08, 2009 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Can you outline where holes need to be made ? I'm still guessing on some of those..
