onosendai
G2 patch files: 4
Posted: Tue Aug 25, 2009 12:59 pm Post subject:
Pitch stick problem ?! |
When i use the pitch stick, the sound bend but don't come back when i stop using it. I suspect the pitch to lose calibration. It's annoying ! I can't use this fabulous stick anymore !
Have you seen this before ? Does a solution exist ? |
Joined: Apr 03, 2004 Posts: 24538 Location: The Netherlands, Enschede
Audio files: 299
Posted: Tue Aug 25, 2009 1:02 pm Post subject:
Others have reported this problem as well, the solution is to replace the pitch stick. It might be possible to order one through the shop where you bought the synth and do the replacement yourself - I believe others did so. _________________ Jan
onosendai
G2 patch files: 4
Posted: Tue Aug 25, 2009 1:15 pm Post subject:
| Replace it fix the problem ? It is hard to do ? |
fairplay
Joined: Apr 13, 2009 Posts: 11 Location: Germany, near Munich
Posted: Thu Aug 27, 2009 9:15 am Post subject:
...might this be the same problem when the pitch-stick just doesnt do anything anymore (as well as the Mod-wheel)? - probably not, but if yes i'd be grateful for a hint...
TIA. |
Audio files: 299
Audio files: 299
Posted: Thu Aug 27, 2009 2:35 pm Post subject:
| fairplay wrote: | ...might this be the same problem when the pitch-stick just doesnt do anything anymore (as well as the Mod-wheel)? - probably not, but if yes i'd be grateful for a hint...
TIA. |
That would sound more like a loose cable ... maybe open the synth to see if you can find any, maybe pull some connectors and push them back on ... _________________ Jan
crueltwist
Joined: Aug 22, 2005 Posts: 26 Location: absolute elsewhere
Posted: Wed Oct 07, 2009 12:09 pm Post subject:
| the stick is very easy to replace if you can do basic soldering, but they aren't cheap - between about 70 and 100 euro including post if my memory serves correctly - the stick is really the most amazing pitch stick I've ever come across - the floyd rose of pitch sticks - but the design is a bit on the crap side - it's a pressure sensitive resistor (which is essentially a piece of tape with a circuit inside) stuck onto a piece of flexible metal - basically the resistor comes partially unstuck and doesn't track properly if the stick has been over-wanked - the worst thing is that when it goes wrong, the pitch of the synth can start wildly and randomly fluctuating, even when not using the stick at all - so once it starts going wrong it needs replacing - fortunately all the pitch sticks nord use are the same (aside from the length of the wires - the g2 uses shorter ones than the lead) so for now we don't need to worry about stocking up on replacements before they're all gone - |
fairplay
Posted: Wed Oct 07, 2009 12:31 pm Post subject:
| Blue Hell wrote: | | That would sound more like a loose cable ... maybe open the synth to see if you can find any, maybe pull some connectors and push them back on ... |
...turned out the motherboard was damaged and had to be replaced...
...luckily my G2 is still under warranty... |
