 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Any way I can map MIDI controls to regular Win apps?
Page 1 of 1 [6 Posts]
jlounge
PostPosted: Sat Jun 24, 2006 12:43 pm    Post subject: Any way I can map MIDI controls to regular Win apps? Reply with quote  Mark this post and the followings unread
I was wondering if there is any way I could map midi controls to standard Windows applications.
It'd be nifty to be able to scroll my Winamp playlist with one of my sliders, or scroll down in Firefox, or even adjust my PC's volume.
Audio files: 227
PostPosted: Sun Jun 25, 2006 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
That would be nice, but I've never seen such a thing.
klangumsetzer
Audio files: 37
PostPosted: Mon Jun 26, 2006 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, there is: midi translator (can translate midi messages into key strokes)...
look here:
http://www.bome.com/midi/translator/
best regards
eike
jksuperstar
G2 patch files: 18
PostPosted: Mon Jun 26, 2006 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Someone wanted to add this to KeyKit. Don't know what ever happened with it. But it seemed he was also toying with Bome's Midi Translator along with PowerPro (a tool to control programs). Here's his post on the KeyKit forum:
http://nosuch.com/keykit/mailarchive/msg03432.html
TonE
PostPosted: Tue Sep 08, 2009 9:55 pm    Post subject: Re: Any way I can map MIDI controls to regular Win apps? Reply with quote  Mark this post and the followings unread
Yes, this is possible. There are multiple options:
1. AutoHotkey with the available midi input library (search in the AutoHotkey forum)
2. Bome's Midi Translator which was already mentioned above.
3. GlovePIE should be able to do this also.
I would use the first option as AutoHotkey gives you a lot more power than a newbie might imagine in the beginning, if following midi event types are enough for you:
- note.pitch
- cc
- pitchbend
which are supported by the midi input library for AutoHotkey. In the case of Winamp you can have very extensive control via the Winamp API, AutoHotkey can access this API and you can do anything you want what this API allows.
I hope this helps a little.
Audio files: 227
PostPosted: Wed Sep 09, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info, TonE and
welcome
