davep
Joined: Jul 05, 2004 Posts: 467 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 5:52 pm Post subject:
CHROMA templates |
Hi all,
As mentioned in the G2 forum discussion on detuning oscs, here is the set of Chroma template patches I made a while back to replicate the Chroma sound, along with a few complete patches based on these templates.
Note that the Uni Lead and Uni Bass patches are a little different - they don't replicate the Chroma filter sound exactly, but they are attempts to replicate the Chroma's massive 'unison' mode. To use these, load the same patch into two slots on the NM1, and use knob1 to set each slot to a different amount of detuning. Huge!
Howard & Jan - It seems that I can only attach three files at a time (hence the multiple emails). Is that intentional?
Dave Peck
Description: |
 Download (listen) |
Filename: |
CHROMA 12dB res=2.pch |
Filesize: |
1.05 KB |
Downloaded: |
316 Time(s) |
Description: |
 Download (listen) |
Filename: |
CHROMA 12dB res=4.pch |
Filesize: |
930 Bytes |
Downloaded: |
304 Time(s) |
Description: |
 Download (listen) |
Filename: |
CHROMA 12dB res=6.pch |
Filesize: |
1.22 KB |
Downloaded: |
333 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:47 pm; edited 1 time in total |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 5:54 pm Post subject:
More Chroma |
more...
Description: |
 Download (listen) |
Filename: |
CHROMA dual filter min res.pch |
Filesize: |
1.21 KB |
Downloaded: |
300 Time(s) |
Description: |
 Download (listen) |
Filename: |
Chroma Pad mode 1+warmth.pch |
Filesize: |
2.87 KB |
Downloaded: |
319 Time(s) |
Description: |
 Download (listen) |
Filename: |
Chroma Pad mode 13.pch |
Filesize: |
2.63 KB |
Downloaded: |
320 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:48 pm; edited 1 time in total |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 5:57 pm Post subject:
more... |
more...
Description: |
 Download (listen) |
Filename: |
Chroma Pad mode 13+warmth1a.pch |
Filesize: |
2.95 KB |
Downloaded: |
303 Time(s) |
Description: |
 Download (listen) |
Filename: |
Chroma Res 6+2 Pad.pch |
Filesize: |
3.31 KB |
Downloaded: |
302 Time(s) |
Description: |
 Download (listen) |
Filename: |
Chroma Rez Brass1.pch |
Filesize: |
2.42 KB |
Downloaded: |
306 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:50 pm; edited 1 time in total |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 5:59 pm Post subject:
more... |
more...
Description: |
 Download (listen) |
Filename: |
Chroma Saw Pad1.pch |
Filesize: |
2.96 KB |
Downloaded: |
276 Time(s) |
Description: |
 Download (listen) |
Filename: |
CHROMA series filters res=2.pch |
Filesize: |
1.47 KB |
Downloaded: |
283 Time(s) |
Description: |
 Download (listen) |
Filename: |
CHROMA series filters res=0.pch |
Filesize: |
1.11 KB |
Downloaded: |
292 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:52 pm; edited 1 time in total |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 6:00 pm Post subject:
more... |
more...
Description: |
 Download (listen) |
Filename: |
CHROMA series filters res=4.pch |
Filesize: |
1013 Bytes |
Downloaded: |
269 Time(s) |
Description: |
 Download (listen) |
Filename: |
CHROMA series filters res=5.pch |
Filesize: |
1.14 KB |
Downloaded: |
283 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:53 pm; edited 1 time in total |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jan 03, 2005 6:01 pm Post subject:
last two Chroma patches |
Last two...
Description: |
 Download (listen) |
Filename: |
Chroma Uni Bass.pch |
Filesize: |
3.6 KB |
Downloaded: |
276 Time(s) |
Description: |
 Download (listen) |
Filename: |
Chroma Uni Lead.pch |
Filesize: |
2.75 KB |
Downloaded: |
270 Time(s) |
_________________ Dave Peck Last edited by davep on Wed Sep 16, 2009 8:55 pm; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24485 Location: The Netherlands, Enschede
Posted: Mon Jan 03, 2005 6:15 pm Post subject:
Re: CHROMA templates |
davep wrote: |
I don't know about that, Howard will have to answer it.
And wow, once you get the hang of it you for sure can post faster than anyone can download :-)
I'lm going to cross link the topics a bit, the one and only usefull contribution I can make right now, thanks Dave !
Also see : http://electro-music.com/forum/post-28464.html
Jan. |
Joined: Jan 31, 2003 Posts: 18252 Location: Durham, NC
Audio files: 227
Posted: Mon Jan 03, 2005 9:02 pm Post subject:
The forum software has a limit that is adjustable that is set to 3 by default. I think the low number is to protect the server from an attack that loads zillions of attachments. I tend to think 3 is probably all one should reasonably expect to work reliably over an HTTP connection. _________________ --Howard
my music and other stuff |
varice
Audio files: 29
G2 patch files: 54
Posted: Mon Jan 03, 2005 9:23 pm Post subject:
Hmmm... somehow the patch files I downloaded got corrupted, the Modular Editor would not load them. I opened a couple with a text editor and found that they had extra carriage return / line feeds between each line. I deleted the extras and now the patches will load.
Thanks Dave for posting these CHROMA templates! They are very good example of a different hardware synth architecture. People unfamiliar with the CHROMA can "get a look under the hood". Even if the patches are not used directly, the templates may be used as inspiration for new unique modular patches.
I've also enjoyed many of the other patches that you have posted for both the G1 and the G2. Keep up the good work! _________________ varice |
davep
Audio files: 10
G2 patch files: 73
Wout Blommers
Audio files: 123
G2 patch files: 12
davep
Audio files: 10
G2 patch files: 73
Posted: Wed Sep 16, 2009 9:49 pm Post subject:
Hi Wout!
It looks like they are the same patches in that location, maybe one exception. But I just checked several of them in that location and they all download & open OK, no need to replace them.
...Not sure why it says "Polaris" in that location, these templates are based on the big Chroma, not the Polaris. But a minor detail. _________________ Dave Peck |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Sep 16, 2009 11:26 pm Post subject:
davep wrote: | ... But a minor detail. | Which I will take care of in a, hopefully soon, next update.
Wout |
