I'm cleaning my D-50 and need help
Page 4 of 4 [89 Posts]
Gothboy
PostPosted: Wed May 09, 2007 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
roughly it means "Damn the difficulties", see, it worked in this case... Wink
Apple Mac Pro 2019 3.2 GHz 16-Core Intel Xeon W
96 GB Ram
15.6 Sequoia
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
PostPosted: Wed May 09, 2007 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nec Aspera Terrent indeed! Smile
My sig at the moment is an almost perfect translation! Shocked
BTW you did a very neat job on that soldering repair, well done.
Gothboy
PostPosted: Thu May 10, 2007 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, great minds think alike. Laughing I'm very happy with the way it turned out. It was tough though, the space on that board is sooo small.
96 GB Ram
15.6 Sequoia
fischek
PostPosted: Thu Dec 13, 2007 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
whatever happened to all the photos demonstrating the cleaning process?
PostPosted: Thu Dec 13, 2007 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
They got snuffed in the great server crash of August 07! Sad
I'll have a look to see if my ones are still sitting in a backup folder somewhere.
Gothboy
PostPosted: Sun Dec 16, 2007 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I reposted mine! Fischek is from the Roland Clan forum, let us welcome him and his D-50 that needs cleaning. Cool See if you can get those photos back up UK. Smile
96 GB Ram
15.6 Sequoia
PostPosted: Mon Dec 17, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
No, sorry, my photos have gone to the great "should have been backed up" folder in the sky. I have a file which covers all the main points of cleaning the keys. And if you'd like me to explain anything about the process, just let me know.
With appropriate tools and a bit of patience, I'm sure you'll be able to sort it out, with the help of Gothboy and myself. I'll post that file here now just in case, and stay in touch.
The D50 is actually a very hardy beast. You'll be fine. Put aside some time, and a well lit space, and we'll guide you through it. (Even if I have to pop the top on mine again and take some more photos!) Cool
vpv1952
PostPosted: Sun Oct 11, 2009 9:31 am    Post subject: Request to Uncle Krunkus and others in this topic.
Subject description: Need clarrification
Hello Uncle Krunkus, I have an old D50, i acquired in 1987 brand new. It now has two keys almost dead - they do not produce sound when you press them; sound is produced only when you release them. I opened the keyboard to start clean up procedures, but stoped from moving on with the cleaning. The reason: i saw a long transparent plastic strip that olds the keys to their position. My question: do i need to remove this plastic strip? I think I saw in theses forum some reference that it is ok to remove it, and some other reference saying that it is not needed. I was hoping to see some photos but your photos are lost.
I also see that you have a file with some tips. Can you please send it to me? And what about the plastic transparent strip? Is it easy to reinstall it back (with glue?)?
Thank you very much for your help.
Gothboy
PostPosted: Sun Oct 11, 2009 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
vpv,
Like you, I'm back to this same old issue with my D-50 as recently I started playing it(actually playing it's keyboard...I usually control it from my midi controllers) and discovered one of the same keys is again out. I thought I fixed it pretty good...what was it 2 years ago?
It's OK to remove the plastic strip. When I cleaned mine I just pulled it off and stuck it back on again when I was done(without glue). The thing is....why are those keys dead? Is it the rubber contacts?(probably) and no matter how much you clean them the problem will eventually return.
96 GB Ram
15.6 Sequoia
vpv1952
PostPosted: Sun Oct 11, 2009 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your quick reply. Let me just clarify one point you mentioned: no glue. Do you mean that the strip is self glued, or are there any straps or screws that hold the plastic strip in place?
I think that heat inside the keyboard is the reason for the dust that gets absorbed and sticks to the rubber contacts. And the fact that there is no physical isolation of the keyboard itself.
Do you have any cover to protect the D50 while not in use? I don't... would it improve this?
Gothboy
PostPosted: Mon Oct 12, 2009 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it was glued on at the factory 25 years ago....but I was able to just pop it off carefully and then it just sort of stuck back on when I put it back on there.
The most difficult part of the whole procedure was getting the main synth board out and removing the connecting cables.
Any keyboard cover definately makes a difference in keeping dust and spiders out. I have it draped with a cloth but do need a stretchy cover for it like my other synths.
96 GB Ram
15.6 Sequoia
odeon
PostPosted: Sun Jul 25, 2010 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
I just registered on this forum because I recently bought a used D-50 and found this thread when searching for information on the D-50 and problems with dead keys. Several keys had problems ranging from simply dead to velocity-related issues, and I managed to get them all working. I took the opportunity to clean everything, too. Smile
I wanted to say tanks to everyone who contributed to these instructions.
Cheers.
Gothboy
PostPosted: Sun Jul 25, 2010 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well good I'm glad it's working and you benefitted from our little everlasting thread here. Maybe it will go on and on through time helping all D50 owners!
I wish the keys on mine were all working. I'm thinking about taking it in to the shop.
96 GB Ram
15.6 Sequoia
odeon
PostPosted: Wed Jul 28, 2010 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The problems are back after cleaning and repairing your D-50?
When looking at and fiddling with the insides of the synth, I couldn't help thinking that for all of their brilliant design, Roland completely forgot to protect the PCB board and contacts below the keys. My synth had been taken apart on several occasions from what I could tell, yet there was so much dust and hair that had gathered since the last time. No wonder this happens.
I'm now trying to restore the original patches but it proves to be harder than I thought. My master synth, a Korg TR61, has talked to my computer through USB and I just discovered that I couldn't get the MIDI ports of my Audigy sound card to work in any of the OSs I can run. The TR's got MIDI connectors which I hooked up to the D-50, hoping for passing SysEx through the TR to the D-50, but apparently the TR's MIDI connectors stop working when the thing talks through USB.
My new solution is an ESI Juli@ card from eBay. Any day now... Smile
