Space Music
Page 1 of 1 [8 Posts]
Inventor
Audio files: 267
PostPosted: Fri Nov 06, 2009 4:17 am    Post subject: Space Music
Subject description: In the style of Shane Morris
Let's post our Shane-like music in this thread! If you make space music and you would like to share it with us, post it here.
This is a song I created using a space music program that I wrote in ChucK. It uses a banded wave guide model and a Rhodey model, both piped into an effects chain. I am attaching the ChucK file as well for your curiosity.
When I played it for Shane he said it was good enough for him to play on his show, so I think I did a good job on it. Enjoy!
Les
SpaceMusic.mp3
My first attempt at Space Music
 Filename:  SpaceMusic.mp3
 Filesize:  7.33 MB
 Downloaded:  3306 Time(s)
SpaceMusic6.ck
The ChucK Program
 Filename:  SpaceMusic6.ck
 Filesize:  3.35 KB
 Downloaded:  1139 Time(s)
shanemorris
Audio files: 92
PostPosted: Fri Nov 06, 2009 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm honored Les! xxsun welcome
listening now...
All Ears
ElectroCasa
shanemorris
Audio files: 92
PostPosted: Fri Nov 06, 2009 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Les I like your use of tonal relationships in this piece a lot. Very nice balance between sound and silence.
You should make more Wink
ElectroCasa
Inventor
Audio files: 267
PostPosted: Fri Nov 06, 2009 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Shane, I will!
Les
Inventor
Audio files: 267
PostPosted: Sun Jan 10, 2010 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I created a 700 line program to make space music for the Ambient 3 event that Shane invited me to. Here is an audio sample.
Les
Nicecast Archived Audio 20100110 0957.mp3
The demo
 Filename:  Nicecast Archived Audio 20100110 0957.mp3
 Filesize:  16.23 MB
 Downloaded:  3370 Time(s)
shanemorris
Audio files: 92
PostPosted: Mon Jan 11, 2010 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
wow Les ... this is excellent! amazing what you can do with code.
thanks a lot for sharing this Very Happy
im looking forward to your set at Ambient 3
shane
ElectroCasa
Inventor
Audio files: 267
PostPosted: Sat Feb 11, 2012 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
non-mac version created for Shane...
spacemusic7 Shane edition.ck
 Filename:  spacemusic7 Shane edition.ck
 Filesize:  1.96 KB
 Downloaded:  979 Time(s)
Inventor
Audio files: 267
PostPosted: Wed Mar 14, 2012 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made an ambient program and played it on electro-music radio for Shane. He gave it high praise, so I was quite happy with that. Here it is, works cross platform (no MAUI). I also attached the OSCulator config file for using two WiiMotes to control the program, highly recommended though not necessary. The program runs just fine without the WiiMote control, it's just ten times better with it. enjoy.
Les
WiiMote2.oscd
OSCulator Patch Document (config file for OSCulator)
 Filename:  WiiMote2.oscd
 Filesize:  27.22 KB
 Downloaded:  969 Time(s)
Ambient 3.ck
The ChucK source code
 Filename:  Ambient 3.ck
 Filesize:  4.82 KB
 Downloaded:  1128 Time(s)
